Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 10-12-2017, 14:40   #136 (permalink)
Member: 2767141
Thanks Meter: 18
Originally Posted by calitox View Post
Hello everyone I confirm now that code *5005*7672*0# can work at the activation windows with rsim 11+ ios 11.0.3 but only when iPhone have signal bar but if signal bar says No service code not working test at at&t, sprint T-Mobile iPhone.
In my case always I got address error because I was usin the code with iPhone not signal bar
i cant use the code ios 11.0.3 ip5s
Old 10-12-2017, 15:09   #137 (permalink)
Member: 2767323
Good day I have a 5s on T-mobile after the action of r-sim managed to get the Internet and a network, but the signal is not active and not calling help..
Old 10-12-2017, 17:21   #138 (permalink)
Member: 1938435
Thanks Meter: 208
Originally Posted by AM NAAT A RAPPE View Post
After many many hours of testing with the RSIM 11+
here's how i figured out how to make it work.
RSIM 11+
128K (4G) Simcard
iPhone 6S locked to UK Orange
Steps:
I put the rsim + sim on the phone
I picked my carrier
I picked i5 i7 4G USIM
I picked mode 1
and then accept (open the simcard tray and close again you apply the settings)
The phone will unlock but you will get no service after a while so,
right after iPhone gets unlocked you go into Phone then sim apps
you press Unlock 1
the signal will restart
keep the data on all the time otherswise you will only be able to make calls, ppl cant call you.
Great work to solve this if it's true. I will test it soon.
Old 10-12-2017, 17:34   #139 (permalink)
Member: 2596108
Thanks Meter: 58
Regular rsim 11+ don't even have these modes so it's impossible for people like me to use this solution
Sent from my SM-G950F using Tapatalk
Old 10-12-2017, 18:22   #140 (permalink)
Member: 2765770
Thanks Meter: 6
Iphone 5S locked to T mobile.
rsim + local sim (LTE) in phone.
From menu: (USSD *5005*7672*0# started working. Can't explain why).
T Mobile
i5i7 4G USIM
Mode 1
Seetings succeeded - accept - (remove and re-insert sims)
Phone goes back to "Update completed" (Ready for activation)
CAN'T GET THROUGH ACTIVATION. SIM NOT VALID
Signal shows 4G but I can't activate or go into phone settings.
ANY HELP PLEASE!!
Thanks
Jacques
Old 10-12-2017, 18:55   #141 (permalink)
Member: 2357447
Sonork: dosrun
wait few month everything will be ok ! do not panic people ! 4g sims will work !
now turbo sims can work only with 3g cards and please wait future new turbo sims !
Old 10-12-2017, 20:03   #142 (permalink)
Member: 2767422
So after "Update completed", you should remove and re-insert the sim tray, at that point looks like phone should idle for a while then pop up a message saying "Offline, unlock now?", then you confirm to proceed and move on to settings. You may need to wait quite a few ten seconds.
What do you observe?
T Mobile
i5i7 4G USIM
Mode 1
ANY HELP PLEASE!!
Thanks
Jacques
Old 10-13-2017, 07:57   #143 (permalink)
Member: 2765617
solution not working in sprint iphone 7 plus, keep waiting.
Old 10-13-2017, 09:52   #144 (permalink)
Member: 2767596
I'm using Rsim 11+ on IOS 11.0.2, luckily I activated it before update.
Should I update to IOS 11.0.3, will it require sim activation?
Please Help
Old 10-13-2017, 09:57   #145 (permalink)
Member: 2765925
Do not update the phone will be blocked !!
Old 10-13-2017, 10:02   #146 (permalink)
Member: 2765770
Thanks Meter: 6
SIM CARD NOT SUPPORTED with signal bars and 4G symbol.
Old 10-14-2017, 04:08   #147 (permalink)
Member: 2575858
Thanks Meter: 20
Hey guys again as you can see on the menu that they are using on Sim applications is completely different than the menu we have on Sim applications even though it shows the video of the guy getting it straight from rsim 11 plus case, we are still getting a different menu....
Is there anybody out there that has a menu like this on their iPhone that has successfully bypass????
Sent from my SM-N950U using Tapatalk
Old 10-14-2017, 12:37   #148 (permalink)
Member: 2718431
Thanks Meter: 2
Originally Posted by kinglock View Post
Settings SIM Applications
Hello,
Solution partialy works, Phone activated but not work incoming call when phone is screen lock.
Any solutions?
The Following User Says Thank You to misamd For This Useful Post:
Old 10-14-2017, 14:24   #149 (permalink)
Member: 2767141
Thanks Meter: 18
hai all try not to use Rsim 11+ but use Rsim 11...work 100%
i have screen shoot to proof it but icant upload pic to this forum always upload of file failed,
work ios 11.0.1 - 11.0.3 ip5s au kddi & ip6 softbank
sory for my bad english
Old 10-14-2017, 16:39   #150 (permalink)
Member: 2768042
Hello everyone, write a video and a way to go through the activation and unlocking of rsim 11, thank you in advance! I wish everyone a good evening!
Page generated in 0.20100 seconds with 9 queries
