Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 02-11-2018, 22:40   #226 (permalink)
Member: 2765412
Thanks Meter: 12
Please explain
Originally Posted by kinglock View Post
Please do as the video
RSIM12
https://www.youtube.com/watch?v=6dqXXFjxLlE
https://www.youtube.com/watch?v=F0R-URnMu9Q
video1:RSIM11+ Unlock For iOS11
https://www.youtube.com/watch?v=rW_a1Tb1YZI
video2:
https://www.youtube.com/watch?v=fHg095L240Q
video 3:
https://www.youtube.com/watch?v=J7mePcuAY2k
video 4:
https://www.youtube.com/watch?v=cFbL...ture=*********
The instructions for RSIM11+ return to unlock menu
3th Home button Emergency Call
4th Call *5005*7672*0#
5th:
Settings SIM Applications
Lock Carrier
Return to TMSI unlock mode. Mobile Operation Flow Method①Ignore WiFi, open cellular data, data roaming, close 4G.
First adjust the card patch operator, insert the card + mobile card, input *5005 * 7672 * 11 # mobile phone will automatically find the mobile 2G signal, then open 4G on the OK method②good card paste. Close 4G, insert the card separately, and automatically jump to the upper-left corner of the activation screen to display 3G or E. Emergency dialing 112 to remain on and back out. Plug in the card and the phone card. Wait for 2G signal to appear, open 4G then. (Switch flight mode if a hollow signal appears during operation)
Methodology③
Switch on the card, insert the mobile card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off thoroughly). Then pull out the card and install the card and the mobile card. Turn it on and wait for the signal.
Method④There are many methods to move 4G, but I wont go through them here.
Unicom 4G operation method
Method①Put the card in place, insert the 4G card separately, appear 5 points plus 4G, emergency dialing 112, hold 112 for 5-8 seconds, switch to 5 points plus 3G, pull out the card directly, plug in the card sticker and the card, automatically send out the signal.
Telecom 4G Operation Method
Method①Adjust the card, dial the *5005*7672*11# code, and then prompt a message to restart the machine.
Methodology②
Switch on the card, plug in the card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off completely). Then pull out the card and install the card and the card. Turn it on and wait for the signal.
Operator Boot Directive *5005*7672*00#
Search signal instruction*5005*7672*11#
Carrier code:
R-SIM12,GPP,GEVEY,HEICARD,HEISIM,RSIM 10,RSIM11+,RSIM 9 PRO mini air Unlock,iPhoneX,iPhone8,Firmware,Any version, No jailbreak
Can someone explain this to me in simple steps?
Also, what are the limitations if I set it to this method, thanks.
Old 02-19-2018, 15:03   #227 (permalink)
Member: 2232587
Thanks Meter: 2
have a problem with this iphone5s Japan sim not supported set it stuck at Setting succeeded, Service Centre Address, No Address here *5005*7672*99# or 0# or 00# i also already preesed still cant go in with rsim new version anyone know how to fix ?
Old 02-26-2018, 10:54   #228 (permalink)
Member: 2728280
iphone 5s problem
i cant typ code couz no have emergency call my iphone how ican typ a code
Old 02-26-2018, 10:57   #229 (permalink)
Member: 2767141
Thanks Meter: 18
Press home button then there is options emergency call
Sent from my iPhone using Tapatalk
Old 03-01-2018, 01:19   #230 (permalink)
Member: 2816320
not working for iphone 5s when type this *500 bala bala it's do nothing please help me my phone only have no service
Old 03-01-2018, 01:44   #231 (permalink)
Member: 2179862
Thanks Meter: 17
It works only for iPhone X and 8+ at this moment.
Enviado desde mi MHA-L29 mediante Tapatalk
Old 03-01-2018, 01:56   #232 (permalink)
Member: 2767141
Thanks Meter: 18
Try to change sim card then try again
Old 03-13-2018, 23:33   #233 (permalink)
Member: 1560521
Sonork: junioramaya2005
Thanks Meter: 9
Return to unlock menu mode
active again . call *5005*7672*00# pop-up menu window on emergency call interface or *5005*7672*imsi(7 numbers)# and
then reset is okay. for example, *5005*7672*4405081# set to softbank carriehgvr .
i try this method whit iphone 7 plus tmo usa and dont work
Old 03-21-2018, 04:10   #234 (permalink)
Member: 2806283
Is there a new ICCID code yet?
Old 03-30-2018, 16:13   #235 (permalink)
Member: 474604
Thanks Meter: 11
Good day I insert the R-sim with my sim into the phone it goes to the activation screen I then bring up emergency dialer type in *5005*7672*0# or *5005*7672*00# or any of the others I keep getting the same
"Setting Succeeded
No Address"
Can someone tell me a solution?
The Following User Says Thank You to aldean2000 For This Useful Post:
Old 03-30-2018, 18:02   #236 (permalink)
Member: 1484663
Thanks Meter: 344
"Setting Succeeded
No Address"
Is that R-Sim 12? Or in case it's. Is an original R-Sim?
Old 03-30-2018, 18:15   #237 (permalink)
Member: 1484663
Thanks Meter: 344
For all those that are having problems with activation here's what to do:
1- First make sure you have ORIGINAL R-sim 12. (verify code on back of package)
2- Put the R-Sim 12 in the phone with desired Sim
3- Press home butom (side butom on iPhone X) and get emergency call
4- Input *5005*7672*0# and press call
5- Once the menu shows click on selec carrier (Be patience I'll explain)
6- Select ANY carrier and you'll pass to another settings menu. here select First choice "Supreme Sharp Mode " and reboot
7- After reboot dial all again an this time on go to edit ICCID and enter 20 digits code:
8901 4103 2795 2915 5450. Reboot phone.
8- Connect to wifi or itunes and ENJOY.
Some times R-sim 12 are set to other mode different than 'Supreme sharp mode" That's why I'm explaining how to put it back on that mode.
Old 04-04-2018, 06:06   #238 (permalink)
Member: 2032636
"Setting Succeeded
No Address"
I have common problem too with R-SIM 12, i have iphone 6 with newest ios 11.3, but when dial *5005*7672*00# get
"Setting Succeeded
No Address"
Can you guys help me to resolve this.
Sent from my Redmi 3S using Tapatalk
Old 04-04-2018, 06:31   #239 (permalink)
Member: 2767141
Thanks Meter: 18
"Setting Succeeded
No Address"
Try use other sim card bro
The Following User Says Thank You to Ryudisa For This Useful Post:
Old 04-04-2018, 07:09   #240 (permalink)
Member: 2032636
I've already tried 3 different simcards, but no results at all
Page generated in 0.24237 seconds with 9 queries
