Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 05-25-2016, 14:51   #46 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up G520-T10 slow when opening solved by flash via nck
Flash files count is :14
Action : Firmware update.
Selected Model: 0-By CPU: MT6589
Exe version: NCKBox AndroidMTK 1.8.6.7
Scenario: Full Flash
Reinsert phone battery.
Battery must be charged.
Phone must be off with battery inside.
Please insert USB cable now...
Detected : MediaTek PreLoader USB VCOM Port (COM6)
Phone detected...Please wait
Sending DA agent, please wait...
BaseBand CPU :MT6589_S01
BaseBand CPU Secure Version : FF
BaseBand CPU Bootloader Version : 01
INT RAM: 128 KB SDRAM
EXT RAM: 512 MB DRAM
EMMC: (28Gb+4096Mb) HYNIX 0x483447316404
EMMC FW VERSION: 86:00:00:00:00:00:00:00
EMMC CID: 90014A48344731 : 000000000000000000
EMMC UA SIZE: 0xe7000000
BOOT STYLE: EMMC BOOT
FULL LENGTH: 0xe7600000 [3.615 GB]
Detecting high speed port, wait......
If driver not installed, install high speed port driver.
If not need high speed port, disable it.
After repeat opperation.
Detected : MediaTek DA USB VCOM Port (COM30)
Flash EMMC Algo Start.
Preloader saved in firmware directory.
Starting flash.
FORMAT EMMC FLASH : BEGIN: 0x50780000 - LEN: 0x7e00000
FORMAT EMMC FLASH : BEGIN: 0x58580000 - LEN: 0x8db80000
Send preloader...
Download firmware to flash now...
Wait untill phone will start charging.
All done.
thank u nck team
The Following 2 Users Say Thank You to dereje For This Useful Post:
Old 05-25-2016, 15:54   #47 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up Y520-u22 recovery only solved by nck
when power on the set only opens on recovery mode
after firmware write phone works perfect
thanks nck team
The Following User Says Thank You to dereje For This Useful Post:
Old 05-25-2016, 16:09   #48 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up Wiko LENNY privacy unlock done via nck
it is supported by generic
Selected model: MT6572_EMMC
Action: Reset Privacy
BaseBand CPU :MT6572_S00
EMMC: (29Gb+4096Mb) HYNIX 0x483447316404
EMMC FW VERSION: 05:00:00:00:00:00:00:00
EMMC UA SIZE: 0xe9000000
FULL LENGTH: 0xe9c00000 [3.652 GB]
Dumping data, wait.
Value found, procesing[010c][00460000]
Resetting phone.
FORMAT EMMC FLASH : BEGIN: 0x44540000 - LEN: 0xa41c0000
Phone can start slow at first power on
If phone stuck on logo, perform wipe from recovery.
First start can take up to 5 min on some phones.
All done.
cheers nck team
Old 05-26-2016, 10:26   #49 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up lenevo A316i hung logo done by generic via nck box
Flash files count is :12
Selected Model: 0-By CPU: MT6592
Scenario: Safe Flash
Detected : MediaTek PreLoader USB VCOM Port (COM256)
BaseBand CPU :MT6592_S00
EXT RAM: 2 GB DRAM
EMMC: (117Gb+16384Mb) HYNIX 0x484147326504
EMMC CID: 90014A48414732 : 000000000000000000
EMMC UA SIZE: 0x3ab800000
FULL LENGTH: 0x3ac400000 [14.691 GB]
Detected : MediaTek DA USB VCOM Port (COM376)
Warning, flashing preloader disabled!
If you change android version, preloader must be flashed.
Starting flash.
All done.
thanks nck team
Old 05-28-2016, 16:09   #50 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up Huawei Ascend Y330-U11 boot loop fixed via nck
Selected Model: Huawei: Ascend Y330-U11
Parsing firmware, wait.
[22]Rom Count.
Connecting phone.
BBCHIP MT6572_S00
EMMC FW VERSION: 51:00:00:00:00:00:00:00
EMMC CID: 11010030303447393051CC5C042F1227
EMMC UA SIZE: 0xec000000
Partitions count: 22
Dumping preloader.
Preloader backup already exist, skip saving.
Start Flashing.
Send preloader...
MBR checksum is executing ...
EBR1 checksum is executing ...
UBOOT checksum is executing ...
BOOTIMG checksum is executing ...
RECOVERY checksum is executing ...
SEC_RO checksum is executing ...
LOGO checksum is executing ...
EBR2 checksum is executing ...
ANDROID checksum is executing ...
CUST checksum is executing ...
CACHE checksum is executing ...
USRDATA checksum is executing ...
Wait untill phone start charging.
All done.
nck box
Old 05-30-2016, 09:28   #51 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up SM-G361H frp fast in a second unlock done via nck sam tool
Device detected OK.
Bypassing data, wait....
Bypass ok.
Reading Data,wait....
Done
Chipset: SPRD8735
Data Found, processing...
Resetting FRP, wait..
FRP OFF... Done
Now you can wipe phone to remove remaining data...
Restarting Phone
Restart Ok
All Done
Done.
Log saved to: C:\Users\dereje\Documents\nck_samsung\logs\SM-G361H_frp_reset__1.txt
thanks nck team
Old 05-30-2016, 12:21   #52 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up samsung SM-J100H original simlock unlock done via nck sam tool
unlocking log yes it is fast unlo king
Detecting phone, wait..
Detected: Modem (COM76)
Port: Modem (COM76)
Phone Detected.
SM-J100H
Model: SM-J100H
Base: SM-N900
Version: J100HXCU0AOD1/J100HSWR0AOD1/J100HXCU0AOD1/J100HXCU0AOD1
PRD: SM2J100HZKASWR
SN: RV1G822AWFY
IMEI: 353010075141103
SIMLOCK:LOCKED
Unlocking, wait.
Unlock Done.
If Phone Ask For Code, Enter 00000000.
For check lock use: *#7465625#
Log saved to: C:\Users\dereje\Documents\nck_samsung\logs\SM-J100H__unlock__1.txt
Done.
thanks to nck team
Old 05-30-2016, 13:49   #53 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up SM-G531F frp unlocked as SM-G531H suported
SM-G531F frp unlocked as SM-G531H supported
Device detected OK.
Bypass ok.
Done
Chipset: PXA1L88
FRP OFF... Done
Restarting Phone
Restart Ok
All Done
Done.
Log saved to: C:\Users\dereje\Documents\nck_samsung\logs\SM-G531H_frp_reset__1.txt
Old 06-01-2016, 06:46   #54 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up SAMSUNG SM-E700F boot loop fixed by nck sam tool 0.8.3
flash log
Model Selected: SM-E700F
Device detected OK: Modem (COM8)
Downloading..
Total Size: 2035153108
Get PIT for mapping..
Chipset: MSM8916
Firmware update start..
Loading: aboot.mbn, wait.
Processing: aboot.mbn Size: [1.11 MB] [1160604]
Loading: sbl1.mbn, wait.
Processing: sbl1.mbn Size: [271.24 KB] [277748]
Loading: rpm.mbn, wait.
Processing: rpm.mbn Size: [179.7 KB] [184008]
Loading: tz.mbn, wait.
Processing: tz.mbn Size: [390.04 KB] [399400]
Loading: hyp.mbn, wait.
Processing: hyp.mbn Size: [52.32 KB] [53576]
Loading: NON-HLOS.bin, wait.
Processing: NON-HLOS.bin Size: [9.83 MB] [10307328]
Loading: sec.dat, wait.
Processing: sec.dat Size: [684 bytes] [684]
Loading: boot.img, wait.
Processing: boot.img Size: [10.07 MB] [10559760]
Loading: recovery.img, wait.
Processing: recovery.img Size: [11.38 MB] [11927824]
Loading: system.img.ext4, wait.
Processing: system.img.ext4 Size: [1.7 GB] [1826687188]
lastSequenceBytes: 2164948
Loading: modem.bin, wait.
Processing: modem.bin Size: [43.53 MB] [45647616]
lastSequenceBytes: 14190336
Loading: cache.img.ext4, wait.
Processing: cache.img.ext4 Size: [97.77 MB] [102514896]
lastSequenceBytes: 8143056
Loading: hidden.img.ext4, wait.
Processing: hidden.img.ext4 Size: [24.25 MB] [25432476]
Resetting, wait until phone restart.
Log saved:
C:\Users\dereje\Documents\Avengers\Saved_Logs\SM-E700F_flashing_log_1.txt
Total Time: 00:03:02
NCK BOX - Reaching Above & Beyond For YOUR Business
Rock N Roll with Hot Summer Update ;-)
Old 06-03-2016, 09:17   #55 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up GT-i9100 update to 4.1.2 sucsesfully
Model Selected: GT-I9100
Downloading..
Total Size: 974131296
Loading: boot.bin, wait.
Processing: boot.bin Size: [128 KB] [131072]
Loading: data.img, wait.
Processing: data.img Size: [34.82 MB] [36512528]
lastSequenceBytes: 5055248
Loading: factoryfs.img, wait.
Processing: factoryfs.img Size: [462.87 MB] [485352648]
lastSequenceBytes: 13493448
Loading: hidden.img, wait.
Processing: hidden.img Size: [386.88 MB] [405670364]
lastSequenceBytes: 28183004
Loading: param.lfs, wait.
Processing: param.lfs Size: [1.22 MB] [1277952]
Loading: Sbl.bin, wait.
Processing: Sbl.bin Size: [1.25 MB] [1310720]
Loading: zImage, wait.
Processing: zImage Size: [8 MB] [8387840]
Processing: modem.bin Size: [12 MB] [12583168]
Loading: cache.img, wait.
Processing: cache.img Size: [21.84 MB] [22905004]
Old 06-04-2016, 10:18   #56 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up Samsung Gt-i9300 flash done via nck sam tool
Samsung Gt-i9300 flash log
Model Selected: GT-I9300
Downloading..
Total Size: 1312883316
Chipset: Mx
Processing: boot.img Size: [5.27 MB] [5525760]
Loading: param.bin, wait.
Processing: param.bin Size: [760 KB] [778240]
Processing: recovery.img Size: [5.95 MB] [6236416]
Loading: sboot.bin, wait.
Processing: sboot.bin Size: [866.25 KB] [887040]
Loading: system.img, wait.
Processing: system.img Size: [1.04 GB] [1120434788]
lastSequenceBytes: 19429988
Loading: tz.img, wait.
Processing: tz.img Size: [156 KB] [159744]
Processing: cache.img Size: [53.67 MB] [56279524]
lastSequenceBytes: 24822244
Processing: hidden.img Size: [104.9 MB] [109998636]
lastSequenceBytes: 15626796
Old 06-07-2016, 15:45   #57 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up samsung note 3 SM-G900t unlock in a second in nck sam tool
Unlock metod[1].
Port: SAMSUNG Mobile USB Serial Port (COM140)
Build id: M8974A-AAAANAZM-2.0.10059
Version info: Nov 12 201418:56:26May 09 201420:00:00AAAAANAZ:d
IMEI: 358021059455554
Unlocking, wait....
Job done, if phone not restart, restart manually
nck sam tool
Old 06-07-2016, 18:41   #58 (permalink)
Member: 2095587
Thanks Meter: 36
GiONEE M5_LITE
Gionee M5_Lite imei repair Done
Selected connection metod: SpMeta Connection
Exe version: NCKBox AndroidMTK 1.8.6.9
Selected phone: MT6571_EMMC
Action : IMEI REPAIR.
IMEI for write : 354630507145236
Curent Platform: MT6571
[20]Detected: MediaTek PreLoader USB VCOM (Android) (COM20)
\\?\usb#vid_0e8d&pid_2000#6&28ef1981&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Starting META mode, wait...
Restarting to meta,wait....
If drivers missing, please install CDC drivers.
This can take up to 5 min on slow phones.
If take too long, check device manager for drivers.
[58]META Port Detected: Gadget CDC VCOM Driver (COM58)
USB\VID_271D&PID_0006\6&28EF1981&0&2
Start sync target, waiting responce.....
Starting META using port[COM58], wait...
Brand: GiONEE
Board: unknown
Model: M5_lite
Release: M5_lite
Version: 5.1
Platform: MT6735
BUILD_ID: BBL7353IF_0204_T5184
NVRAM Dumped OK.
C:\Users\National\Documents\Android_MTK\nvram_back up\META_MODE_NVRAM_MT6735_M5_lite_06_07_2016_23_36 _02.zip
Using MT6735 Algo.
IMEI[1] TO UPDATE: 35463050
Calculated checksum: f53f8fe0
Writing data, wait....
IMEI repair OK.
All done.
The Following User Says Thank You to hamim ctg For This Useful Post:
Old 06-08-2016, 10:09   #59 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up This is howe the new & fast sp meta mode works
SM-J100H MT6572 NAND IMEI REPAIR WITH NEW FAST SP META MODE
IMEI 1 REPAIR LOG
Selected phone: MT6572_NAND
IMEI for write : 353407100108968
Curent Platform: MT6572
[46]Detected: MediaTek PreLoader USB VCOM (Android) (COM46)
\\?\usb#vid_0e8d&pid_2000#5&f86e282&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[141]META Port Detected: MediaTek USB VCOM (Android) (COM141)
USB\VID_0E8D&PID_2007\5&F86E282&0&4
Starting META using port[COM141], wait...
Brand: samsung
Board: sc7727s
Model: SM-J100H
Release: ALPS.KK1.MP7.V1
Version: 4.4.2
Platform: MT6572
BUILD_ID: ALPS.KK1.MP7.V1
NVRAM Dumped OK.
C:\Users\dereje\Documents\Android_MTK\nvram_backup \META_MODE_NVRAM_MT6572_SM-J100H_06_08_2016_11_55_16.zip
IMEI[1] TO UPDATE: 353407100108968
Calculated checksum: d11e1a74
IMEI repair OK.
All done.
IMEI 2 REPAIR LOG
IMEI for write : 355780440214011
Brand: samsung
Board: sc7727s
Model: SM-J100H
Version: 4.4.2
Platform: MT6572
NVRAM Dumped OK.
C:\Users\dereje\Documents\Android_MTK\nvram_backup \META_MODE_NVRAM_MT6572_SM-J100H_06_08_2016_11_58_06.zip
IMEI[2] TO UPDATE: 355780440214011
Calculated checksum: bd5b59b7
IMEI repair OK.
All done.
THANKS TO NCK TEAM
Old 06-09-2016, 10:12   #60 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 933
Thumbs up SAMSUNG GT-I8262 slow when opening fixed by nck sam tool
flash log
Model Selected: GT-I8262
Downloading..
Total Size: 1266172700
Chipset: MSM8x25
Loading: appsbl, wait.
Processing: appsbl Size: [518.09 KB] [530520]
Processing: boot.img Size: [5.02 MB] [5263616]
Loading: persist.img.ext4, wait.
Processing: persist.img.ext4 Size: [4.18 MB] [4378760]
Processing: recovery.img Size: [5.7 MB] [5980416]
Processing: system.img.ext4 Size: [1.01 GB] [1081899884]
lastSequenceBytes: 12352364
Loading: userdata.img.ext4, wait.
Processing: userdata.img.ext4 Size: [22.7 MB] [23802760]
Loading: fat.bin, wait.
Processing: fat.bin Size: [19.51 MB] [20452608]
Processing: cache.img.ext4 Size: [71.1 MB] [74551696]
lastSequenceBytes: 11637136
Processing: hidden.img.ext4 Size: [46.33 MB] [48578864]
lastSequenceBytes: 17121584
Page generated in 0.38037 seconds with 9 queries
