GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
02-04-2011, 21:21 | #61 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | |
03-04-2011, 18:09 | #62 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Hi, i could finally read the BlackBerry's MEP and IMEI without RIMRADIOCOMM been involved, here is log: Code: Phone found @ \\?\usb#vid_0fca&pid_8004&mi_00#7&34ebb32b&0&0000#{80375827-83b8-4a51-b39b-905fedd4f118}\MAIN BBPIN: 2128CFC7 IMEI: 355931034930070 MEP: MEP-20669-001 |
The Following User Says Thank You to y3kt For This Useful Post: |
03-05-2011, 05:50 | #63 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1088970 Status: Offline Thanks Meter: 5 | Imei + mep reader How to read Blackberry MEP and IMEI Solution BlackBerry Logger Instructions-IMEI & MEP Reader 1- Please make sure BlackBerry Drivers are already installed on your PC. If you never installed BB Desktop Manager or Drivers, click here so you can downloadand install the drivers 2- Click here to download and save BB-MEP-Reader (Windows Xp, Vista, 7 supported) 3- Power your BlackBerry phone ON and connect it to the PC 4- Start Logger.exe and click on Read Info 5- You will see your IMEI and MEP Data displayed 6- Finally upload the resulting MEP & IMEI to your order page by logging into your GSMLiberty account I don't have the USB cable for my phone. Please click here to get your MEP code with out a USB cable MAC version of the Berry Logger - IMEI & MEP Reader 1- Please make sure BlackBerry Drivers are already installed on your PC. If you never installed BB Desktop Manager or Drivers, please install the BB Desktop Manager using the CD that came with your phone 2- Click here to downloadand save BB-MEP-Reader (MAC version), Unzip ALL contents to your MAC Desktop 3- Power your BlackBerry phone ON and connect it to the PC 4- Start BB-Logger and click on Read Info 5- You will see your IMEI and MEP Data displayed 6- Finally upload the resulting MEP & IMEI to your order page or send it to [email protected] Logger Trouble Shoot If the BB Logger is unable to read your phone info, make sure to do the following: 1- BB Desktop Manager is NOT running. Desktop Manager icon must be shut down next to the time on the bottom right corner of the screen 2- On your BB phone go to Options => Media Card/Memory Card and make sure the following is set: a. Media Card Support: off b. Mass Storage Mode Support: off c. Auto Enable Mass Storage: no d. Save the settings and exit 3- Disable any password on the phone. To do so go to Options => Security Options => General Settings => password off 4- If your keypad AUTO-LOCKS, please make sure to disable this option, go to Options => Auto Lock => Disable |
03-05-2011, 12:23 | #64 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: ..::DZ-25::..
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | Quote:
i tried using rimradiocomlib with c# but no success !!, many pbms (invalid cast) so i prefer to use winapi's , now i can handle BB device using its GUID without any pbms.... need just commands to do tests | |
03-05-2011, 16:00 | #65 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | If you use any sniffer over any mep reader you will have what you need, waht you need to read is: http://forum.gsmhosting.com/vbb/f83/...ction-1184114/ and http://forum.gsmhosting.com/vbb/f83/...ml#post5834221 and http://forum.gsmhosting.com/vbb/f489...mmands-747009/ plus you need to sniff any mep reader to get final idea. Any doubt you can tell me over here so i can help you further if you need it. Luck |
03-05-2011, 22:10 | #67 (permalink) |
Moderator Join Date: May 1999 Location: Blagoevgrad, Bulgaria Age: 52
Member: 73 Status: Offline Thanks Meter: 537 | specialy see here: http://forum.gsmhosting.com/vbb/6808115-post4.html i explain here on francesco... regards: Victor |
03-06-2011, 12:43 | #69 (permalink) |
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | my PBM was here : in c# add "\\MAIN" as simple string to device path don't work because the real path of handled device is like this : \\\\?\\usb#vid_0fca&pid_8004&mi_00#6&208ab18b&0&00 00#{80375827-83b8-4a51-b39b-905fedd4f118}\018}\0 so to get it working w must add "\\MAIN" in the correct place, i solved it by adding this line after handle device: Code: string devpath = GetDeviceHandle(0); devpath= devpath.Substring(0,(devpath.Length-5)) + "\\MAIN"; thanks to, fr3nsis, y3kt and victor |
03-07-2011, 00:22 | #70 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Now it's time to get unlock codes any info on this or any idea on what to look for? |
06-21-2011, 04:38 | #71 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Resign
Member: 177036 Status: Offline Thanks Meter: 934 | in nokia bb5 like this VID procedure TForm1.Button1Click(Sender: TObject); begin if BB_USB_ScanAndOpenConnection('BB5', '*VID_0421*IF_OTH*',true) then BB_usb_scan; end; end. IN BLACKBERRY what is the correct vid thanks |
08-05-2011, 13:44 | #75 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Australia/Melbourne
Member: 1610809 Status: Offline Sonork: 100.1616347 Thanks Meter: 23 | how to write imei Iwriteimei.execute(strimei); ....... ........ any can help me please i'm writen imei in bb, but not work thanks |
MEPSERVER - 1ST IN WORLD - BLACKBERRY MEP READER built for MAC users | FuriouS TeaM | FuriousGold | 35 | 06-09-2010 09:56 |
ALL BlackBerry Meps Level & HTC qualcomm/Omap code reader ! Professional Services !! | MB code | Main Sales Section | 0 | 03-03-2010 02:33 |
