GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
09-18-2011, 22:38 | #92 (permalink) |
Freak Poster Join Date: Aug 2009 Location: E G Y P T Age: 26
Member: 1102520 Status: Offline Sonork: 100.1617999 Thanks Meter: 94 | the on;y tutorial i can find is in C++ if there's any othe solution please help me with it. btw i really want to thank you for the huawei algo i used it to do a calculator for blackberry devices so i can calculate any code even if i'm out. Thanks and please help me to find a solution |
09-19-2011, 03:51 | #93 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Rome , Italy
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | Find my source about Nokia connection over usb need only to change virtual path Inviato dal mio HTC Desire S usando Tapatalk |
The Following User Says Thank You to fr3nsis For This Useful Post: |
09-19-2011, 16:43 | #94 (permalink) | |
Member: 1102520 Status: Offline Sonork: 100.1617999 Thanks Meter: 94 | Quote:
i kept searching for 3 hours for this but i didn't fin anything in vb.net except Code: Imports Microsoft.Win32.SafeHandles Imports System.Runtime.InteropServices Imports System.Threading '////////////////////////////// Friend Const FILE_ATTRIBUTE_NORMAL As Int32 = &H80 Friend Const FILE_FLAG_OVERLAPPED As Int32 = &H40000000 Friend Const FILE_SHARE_READ As Int32 = 1 Friend Const FILE_SHARE_WRITE As Int32 = 2 Friend Const GENERIC_READ As UInt32 = &H80000000UL Friend Const GENERIC_WRITE As UInt32 = &H40000000 Friend Const OPEN_EXISTING As Int32 = 3 Thanks in Advance | |
09-19-2011, 16:59 | #96 (permalink) |
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | http://forum.gsmhosting.com/vbb/f83/...5/#post4808463 path is Code: \\?\usb#vid_0fca&pid_8004&mi_00#7&34ebb32b&0&0000#{80375827-83b8-4a51-b39b-905fedd4f118}\MAIN |
09-19-2011, 20:13 | #97 (permalink) | |
09-19-2011, 20:19 | #99 (permalink) | |
Member: 1102520 Status: Offline Sonork: 100.1617999 Thanks Meter: 94 | but i get this device path Quote:
is that normal?? Thanks | |
09-23-2011, 14:19 | #102 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Inside Vb.Net Age: 41
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | Tnahks to Mr, Francesco i can connect using USB, BUT still have problems. exist some differences between the founded path and the fr3ncis one. Mr. Fr3ncis one: \\?\usb#vid_0fca&pid_8004&mi_00#7&34ebb32b&0&0000# {80375827-83b8-4a51-b39b-905fedd4f118}\MAIN Founded one: \\?\usb#vid_0fca&pid_0001#5&1865e169&0&2#{80375827-83b8-4a51-b39b-905fedd4f118} so, i allwayse get the same error : "Phone not found" i am using just a part of string: {80375827-83b8-4a51-b39b-905fedd4f118} cause GUID don't let me put the full path (format not accepted) i try to add this string : Dim devicePathName As String = find_device() deviceHandle = CreateFile(devicePathName & "\MAIN", GENERIC_READ Or GENERIC_WRITE, FILE_SHARE_READ, IntPtr.Zero, OPEN_EXISTING, _ FILE_ATTRIBUTE_NORMAL, 0) but still NOT WORKING What can I do?? thanks in advance Last edited by josedavido; 09-23-2011 at 14:24. |
09-23-2011, 14:40 | #103 (permalink) | |
Code: devicePathName = Marshal.PtrToStringAuto(pDevicePathName) + "\MAIN" if i am wrong please anyone tell us what's the right solution Thanks | |
09-23-2011, 16:40 | #104 (permalink) |
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | Still persist the same problem. Here with device connected: \\?\usb#vid_0fca&pid_8004&mi_00#7&34ebb32b&0&0000# {80375827-83b8-4a51-b39b-905fedd4f118}\MAIN <-- fr3ncis \\?\usb#vid_0fca&pid_0001#5&23991be5&0&1#{80375827-83b8-4a51-b39b-905fedd4f118}\MAIN <-- Device answer Here with device disconnected \\?\usb#vid_0fca&pid_8004&mi_00#7&34ebb32b&0&0000# {80375827-83b8-4a51-b39b-905fedd4f118}\MAIN <-- fr3ncis 픑㨊ĉ疐秫锰#㰈$数$Ď疐秫提$땰!䕐$ ij㹨$䕄䉐\MAIN <-- Device answer in both cases, wrong answer .... I love programming, cause when we get succes, it makes me really happy i will keep working on it till i finish |
The Following User Says Thank You to josedavido For This Useful Post: |
09-24-2011, 12:49 | #105 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
why you not use detect by GUID? in this way you will have right device path when windows will detect new device with specified guid '80375827-83b8-4a51-b39b-905fedd4f118' . it's not recomended to use constant's when you conecting device, conection path will not be same all times. | |
The Following 3 Users Say Thank You to orbita For This Useful Post: |
MEPSERVER - 1ST IN WORLD - BLACKBERRY MEP READER built for MAC users | FuriouS TeaM | FuriousGold | 35 | 06-09-2010 09:56 |
ALL BlackBerry Meps Level & HTC qualcomm/Omap code reader ! Professional Services !! | MB code | Main Sales Section | 0 | 03-03-2010 02:33 |
