GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
11-25-2011, 15:16 | #125 (permalink) | |||
Banned Join Date: Feb 2011
Member: 1523375 Status: Offline Sonork: TITAN Thanks Meter: 8 | Quote:
11-26-2011, 05:30 | #126 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Inside Vb.Net Age: 41
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | MEGAUPLOAD - The leading online storage and file delivery service Here is my software: Read general information Read Language list Get Screenshots Reset and wipe phones all using javaloader, i just establish an USB connection to detect connected phones BUT I STILL CAN'T READ MEP if some one can help me to send and recibe commans by USB i'll be thanksfull I am not a fool that wants the solution ready, i just want to learn. Br, Josedavido |
The Following User Says Thank You to josedavido For This Useful Post: |
11-30-2011, 19:43 | #127 (permalink) |
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | First Test on 8520 Fist Test on 9300 Still have some troubles reading MEP. but i am working on it. thanks to my friend to hep Me. Br, Josedavido |
11-30-2011, 22:07 | #128 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Here my old example: For to receive MEP and others data, you need send to phone: 01 00 10 00 38 FF 08 00 00 00 00 00 00 00 00 00 In Delphi: copy(buffer,pos('MEP',buffer),13) where: MEP = MEP-XXXXX-XXX (13 characters) In VisualBasic i dont know similar function to "copy" in Delphi Good luck brother br elcapitel |
The Following User Says Thank You to elcapitel For This Useful Post: |
12-01-2011, 02:52 | #129 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Quote:
Code: Dim mep_data() As Byte mep_data = read_write_byte(deviceHandle, MEPData, MEPData.Length) Dim enc As New System.Text.UTF8Encoding() mep_info = enc.GetString(mep_data) If mep_info.IndexOf("MEP") > 0 Then mep_info = mep_info.Substring(mep_info.IndexOf("MEP"), 13) ListBox1.Items.Add("MEP: " & mep_info) Else ListBox1.Items.Add("No Valid MEP Found. Please Reconnect Device and Try Again.") End If Code: Public Function read_write_byte(ByVal devicehandle, ByVal command, ByVal commandlenght) As Byte() Dim inputReportBuffer(1000) As Byte unManagedBuffer = Marshal.AllocHGlobal(inputReportBuffer.Length) numberOfBytesRead = 0 numberOfBytesWritten = 0 success = WriteFile _ (devicehandle, _ command, _ commandlenght, _ numberOfBytesWritten, _ IntPtr.Zero) Thread.Sleep(100) success = ReadFile _ (devicehandle, _ unManagedBuffer, _ inputReportBuffer.Length, _ numberOfBytesRead, _ unManagedOverlapped) Marshal.Copy _ (unManagedBuffer, inputReportBuffer, 0, numberOfBytesRead) ReDim Preserve inputReportBuffer(numberOfBytesRead - 1) Return inputReportBuffer End Function Last edited by y3kt; 12-01-2011 at 03:00. | |
12-01-2011, 17:05 | #130 (permalink) |
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | Big Thanks to Mr. Y3KT and El_Capitel ... My two ASERES Good news, finally full code works fine tested on different PC's 8520 9780 9800 9300 Now i am working on a new function. Br, Josedavido |
12-01-2011, 18:24 | #131 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Suggestion: why some parts in english and other in spanish? Better remove spanish from buttons or to make multilanguage By the way.. try to use with OS7 models: Blackberry 7 devices: BlackBerry Bold series (2011): BlackBerry Bold 9900/9930/9790 BlackBerry Torch series (2011): BlackBerry Torch 9810 BlackBerry Torch series (2011): BlackBerry Torch 9850/9860 BlackBerry Curve series (2011): BlackBerry 9350/9360/9370/9380 br elcapitel |
12-02-2011, 21:22 | #133 (permalink) |
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | Well, the work is finished, I have an ad¡tion to the software, for identify MEP's but my MEP's list is wrong. so, doesn't matter what appears onn the software Here is the BETA Version Br, Josedavido |
MEPSERVER - 1ST IN WORLD - BLACKBERRY MEP READER built for MAC users | FuriouS TeaM | FuriousGold | 35 | 06-09-2010 09:56 |
ALL BlackBerry Meps Level & HTC qualcomm/Omap code reader ! Professional Services !! | MB code | Main Sales Section | 0 | 03-03-2010 02:33 |
