Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 02-04-2011, 21:21   #61 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
Unfortunately i can't see the solution, maybe i need some rest , i have all this for vb.net and is working but porting to delphi doesn't gives me positive result, no matter what GUID i use, i always get INVALID _HANDLE, =Thanks anyways
Old 03-04-2011, 18:09   #62 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
Hi, i could finally read the BlackBerry's MEP and IMEI without RIMRADIOCOMM been involved, here is log:
Phone found @ \\?\usb#vid_0fca&pid_8004&mi_00#7&34ebb32b&0&0000#{80375827-83b8-4a51-b39b-905fedd4f118}\MAIN
BBPIN: 2128CFC7
IMEI: 355931034930070
MEP: MEP-20669-001
All info needed is available in this forum most of it in this thread, luck
The Following User Says Thank You to y3kt For This Useful Post:
Old 03-05-2011, 05:50   #63 (permalink)
Member: 1088970
Thanks Meter: 5
Imei + mep reader
How to read Blackberry MEP and IMEI Solution BlackBerry Logger Instructions-IMEI & MEP Reader
1- Please make sure BlackBerry Drivers are already installed on your PC.
If you never installed BB Desktop Manager or Drivers, click here so you can downloadand install the drivers
2- Click here to download and save BB-MEP-Reader (Windows Xp, Vista, 7 supported)
3- Power your BlackBerry phone ON and connect it to the PC
4- Start Logger.exe and click on Read Info
5- You will see your IMEI and MEP Data displayed
6- Finally upload the resulting MEP & IMEI to your order page by logging into your GSMLiberty account
I don't have the USB cable for my phone.
Please click here to get your MEP code with out a USB cable
MAC version of the Berry Logger - IMEI & MEP Reader
If you never installed BB Desktop Manager or Drivers, please install the BB Desktop Manager using the CD that came with your phone
2- Click here to downloadand save BB-MEP-Reader (MAC version), Unzip ALL contents to your MAC Desktop
4- Start BB-Logger and click on Read Info
6- Finally upload the resulting MEP & IMEI to your order page or send it to [email protected]
Logger Trouble Shoot
If the BB Logger is unable to read your phone info, make sure to do the following:
1- BB Desktop Manager is NOT running. Desktop Manager icon must be shut down next to the time on the bottom right corner of the screen
2- On your BB phone go to Options => Media Card/Memory Card and make sure the following is set:
a. Media Card Support: off
b. Mass Storage Mode Support: off
c. Auto Enable Mass Storage: no
d. Save the settings and exit
3- Disable any password on the phone. To do so go to Options => Security Options => General Settings => password off
4- If your keypad AUTO-LOCKS, please make sure to disable this option, go to Options => Auto Lock => Disable
Old 03-05-2011, 12:23   #64 (permalink)
angel25dz's Avatar
Member: 315181
Sonork: 100.1593455
Thanks Meter: 301
BBPIN: 2128CFC7
MEP: MEP-20669-001
can u put commands for read infos ??
i tried using rimradiocomlib with c# but no success !!, many pbms (invalid cast) so i prefer to use winapi's , now i can handle BB device using its GUID without any pbms.... need just commands to do tests
Old 03-05-2011, 16:00   #65 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
If you use any sniffer over any mep reader you will have what you need, waht you need to read is:
http://forum.gsmhosting.com/vbb/f83/...ction-1184114/
and
http://forum.gsmhosting.com/vbb/f83/...ml#post5834221
and
http://forum.gsmhosting.com/vbb/f489...mmands-747009/
plus you need to sniff any mep reader to get final idea.
Any doubt you can tell me over here so i can help you further if you need it.
Luck
The Following 2 Users Say Thank You to y3kt For This Useful Post:
Old 03-05-2011, 21:58   #66 (permalink)
Moderator
Member: 73
Thanks Meter: 537
in CreateFile add Devicepath+'\MAIN'
Old 03-05-2011, 22:10   #67 (permalink)
Moderator
Member: 73
Thanks Meter: 537
specialy see here:
http://forum.gsmhosting.com/vbb/6808115-post4.html
i explain here on francesco...
regards: Victor
The Following 2 Users Say Thank You to Victor For This Useful Post:
Old 03-06-2011, 01:49   #68 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
I will make some test and let you know, thanks for your time.
Luck!
Old 03-06-2011, 12:43   #69 (permalink)
angel25dz's Avatar
Member: 315181
Sonork: 100.1593455
Thanks Meter: 301
my PBM was here :
in c# add "\\MAIN" as simple string to device path don't work because the real path of handled device is like this :
\\\\?\\usb#vid_0fca&pid_8004&mi_00#6&208ab18b&0&00 00#{80375827-83b8-4a51-b39b-905fedd4f118}\018}\0
so to get it working w must add "\\MAIN" in the correct place, i solved it by adding this line after handle device:
 string devpath = GetDeviceHandle(0);
           devpath= devpath.Substring(0,(devpath.Length-5)) + "\\MAIN";
now read/write work fine
thanks to, fr3nsis, y3kt and victor
Old 03-07-2011, 00:22   #70 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
Now it's time to get unlock codes any info on this or any idea on what to look for?
Old 06-21-2011, 04:38   #71 (permalink)
darmiles's Avatar
Member: 177036
Thanks Meter: 934
in nokia bb5 like this VID
procedure TForm1.Button1Click(Sender: TObject);
begin
if BB_USB_ScanAndOpenConnection('BB5', '*VID_0421*IF_OTH*',true) then BB_usb_scan;
end;
end.
IN BLACKBERRY what is the correct vid
thanks
Old 06-21-2011, 07:50   #72 (permalink)
darmiles's Avatar
Member: 177036
Thanks Meter: 934
hi guys my problem solve. thanks to
*VID_0FCA*mi_00*
Old 06-24-2011, 15:34   #73 (permalink)
Member: 921477
Thanks Meter: 7
Source code for Visual Bacic please
Old 06-24-2011, 15:46   #74 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
With all explanations found here you will be able to write your own code, luck
Old 08-05-2011, 13:44   #75 (permalink)
Member: 1610809
Sonork: 100.1616347
Thanks Meter: 23
how to write imei
Iwriteimei.execute(strimei);
any can help me please
i'm writen imei in bb, but not work
thanks
MEPSERVER - 1ST IN WORLD - BLACKBERRY MEP READER built for MAC users FuriouS TeaM FuriousGold 35 06-09-2010 09:56
ALL BlackBerry Meps Level & HTC qualcomm/Omap code reader ! Professional Services !! MB code Main Sales Section 0 03-03-2010 02:33
Page generated in 0.22459 seconds with 10 queries
