10-24-2022, 16:48 | #4381 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Thank you for the feedback! Good job! Best regards Sab Chimera team Quote:
10-25-2022, 08:16 | #4382 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G930F repair imei and patch done ********** IMEI Check Model: iPhone SE (2nd generation) 64GB Red Cellular [A2296] [iPhone12,8] Description: IPHONE SE RED 64GB-GBR IMEI Number: 354430716521290 Serial Number: DX3FQ5YMPLJT IMEI2 Number: 000000000000000 MEID Number: 354XXXXXXXXXXXXX Estimated Purchase Date: June 9, 2021 Warranty Status: Out Of Warranty Device Age: 1 Year, 4 Months and 16 Days Replaced Device: No Country: United Kingdom SIM-Lock: Unlocked |
The Following User Says Thank You to qasir_amz For This Useful Post: |
10-25-2022, 11:31 | #4383 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Qasir, Thank you. Good work from you once again. Best regards Sab Chimera team Quote:
10-27-2022, 08:37 | #4384 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Sudan
Member: 1648903 Status: Offline Thanks Meter: 158 | Frp amn-lx9 testpoint Chimera Mobile Phone Utility version: 33.71.1332 @ 2022-10-27 Autodetect features Initializing... Identifying... Reading data from the phone... Autodetect features Reading data from the phone... Reading data from the phone... Couldn't mount userdata Original IMEI1: 868877043573346 Original IMEI2: 868877047073301 Couldn't mount userdata Supported procedures: Store/Restore Backup Bootloader Update Firmware Remove FRP lock Repair IMEI Root Finished at local time: [10.27.22 09:31:37] WorkID: 200703424 Chimera Mobile Phone Utility version: 33.71.1332 @ 2022-10-27 Removing Huawei-ID Protection from the device... Unlocking bootloader... Removing factory reset protection... Removing Huawei-ID Protection from the device... Factory reset the device... Waiting for the phone to restart... Please reboot your phone by long-pressing the power button! Finished at local time: [10.27.22 09:32:41] WorkID: 200703672 |
10-27-2022, 09:30 | #4385 (permalink) |
Member: 1648903 Status: Offline Thanks Meter: 158 | Frp a125fxxu2 Chimera Mobile Phone Utility version: 33.71.1332 @ 2022-10-27 Printing phone history Reset FRP Lock 10/10/2022 7:45 AM Device Info 10/10/2022 7:38 AM Reset FRP lock started Resetting FRP... Operation in progress. Be patient! Do NOT disconnect the phone! Model: SM-A125F SW Version: A125FXXU2BVB3/A125FOJM2BVB3/A125FXXU2BVA5/A125FXXU2BVB3 Serial: RZ8R801FBPV IMEI: 350766965313135 Product Code: AFR Unique Number: CDV005B54E47F68 Please 'Allow USB debugging' in the popup window Waiting for ADB device... Please 'Allow USB debugging' in the popup window Waiting for ADB device... Resetting FRP... To complete resetting FRP, go to 'Settings/General management/Reset' then select 'Factory data reset' Restarting phone Successfully finished. Finished at local time: [10.27.22 10:24:39] WorkID: 200708722 |
10-27-2022, 12:38 | #4386 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G950f patch Chimera Mobile Phone Utility version: 33.71.1332 @ 2022-10-27 Printing phone history Repair IMEI 10/27/2022 8:17 AM Repair IMEI 10/27/2022 8:14 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Carrier ID: BTU Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Apr 6 19:15:03 KST 2021 PDA Version: G950FXXUCDUD1 [april 2021, rev1] Phone Version: G950FXXUCDUD1 [april 2021, rev1] CSC Version: G950FOXMCDUD1 [april 2021, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8K52B1S2L Imei: 3556XXXXXXXXXX Battery Status: 3.87V (54%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-04-01 Em Did: 02B4AF107B92 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.27.22 13:19:26] WorkID: 200708259 |
10-27-2022, 13:00 | #4387 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Qasir, Thank you for the feedback! Good work! Best regards Sab Chimera team Quote:
10-28-2022, 10:13 | #4388 (permalink) |
Crazy Poster Join Date: Jan 2011 Location: FRANCE Paris
Member: 1485505 Status: Offline Thanks Meter: 2 | redmi note 10 pro sweet update problem!!!! Hello team please help with this problem about update redmi note 10 pro sweet thanks https://ibb.co/WFg33VN Last edited by vindiesele; 10-28-2022 at 10:14. Reason: for add photo |
10-28-2022, 11:50 | #4389 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear vindiesele, What is the problem exactly? Please explain it, so we can work on the request. Best regards Sab Chimera team Quote:
10-28-2022, 14:11 | #4391 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear vindiesele, Yes, unfortunately, the Programmer that the Tool provided to your phone is not compatible. However, we do update the Tool with new Programmers almost every two weeks so we can expect a solution for this within a short amount of time. Best regards Sab Chimera team |
The Following 4 Users Say Thank You to Chimera Tool For This Useful Post: |
10-28-2022, 14:57 | #4392 (permalink) | |
Member: 1485505 Status: Offline Thanks Meter: 2 | Big thanks for all team best regards for you Quote:
10-31-2022, 08:25 | #4393 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G935F Successful Patch Chimera Mobile Phone Utility version: 33.74.1311 @ 2022-10-31 Printing phone history Repair IMEI 10/31/2022 7:22 AM Reboot 10/31/2022 7:11 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935F Sales Code: XEU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Wed May 26 17:17:07 KST 2021 PDA Version: G935FXXU8EUE1 [may 2021, rev1] Phone Version: G935FXXU8EUE1 [may 2021, rev1] CSC Version: G935FXEU8EUE1 [may 2021, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: RF8HB09NGGB Imei: 35XXXXXXXXXXXXXXX Battery Status: 3.84V (74%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.31.22 12:24:26] WorkID: 201144720 |
11-01-2022, 11:11 | #4394 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G930F U8 Patch cert Success with Chimera Chimera Mobile Phone Utility version: 33.74.1311 @ 2022-11-01 Printing phone history Repair IMEI 11/1/2022 10:03 AM Reboot 11/1/2022 9:53 AM Reboot 11/1/2022 9:43 AM Get Info 11/1/2022 9:33 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G930F Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Mon Jul 25 17:43:02 KST 2022 PDA Version: G930FXXU8EVG2 [july 2022, rev2] Phone Version: G930FXXU8EUE1 [may 2021, rev1] CSC Version: G930FOXA8EUE1 [may 2021, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58J14EVANK Imei: 352XXXXXXXXXXX Battery Status: 4.05V (94%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.01.22 15:04:49] WorkID: 201295115 |
11-02-2022, 07:02 | #4395 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Qasir, Thank you very much for the report, good work. Best regards Sab Chimera team Quote:
