11-13-2019, 08:57 | #3766 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Printing phone history Patch Certificate 11/12/2019 7:05:31 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Sales Code: XFV Country Code: South Africa Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Apr 1 18:10:53 KST 2019 PDA Version: A105FDDU1ASD2 [april 2019, rev2] Phone Version: A105FDDU1ASC9 [march 2019, rev9] CSC Version: A105FOJM1ASCB [march 2019, revB] Product Code: XFV HIDSw Version: A105FDDU1ASD2/A105FOJM1ASCB/A105FDDU1ASC9/A105FDDU1ASD2 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RF8M40R9B2W Imei: 350009876544443 Unique Number: CBJ003550470226 Connections: AT,MTP Battery Status: 3.84V (38%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-02-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 21.0:MAGISKSU Previously installed patchcert detected. Previously installed patchcert successfully removed. An old patchcert detected on the phone. Suggestion: Install a new firmware then re-run the pathcert process. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.12.19 09:11:53] |
11-13-2019, 11:21 | #3767 (permalink) |
Junior Member Join Date: Feb 2018 Location: Mandi bahuddin Panjab
Member: 2807129 Status: Offline Thanks Meter: 15 | Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Sales Code: PHE Country Code: SPAIN Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Oct 1 14:51:25 KST 2019 PDA Version: G960FXXU7CSJ1 [october 2019, rev1] Phone Version: G960FXXU7CSI6 [september 2019, rev6] CSC Version: G960FOXM7CSJ1 [october 2019, rev1] Product Code: PHE HIDSw Version: G960FXXU7CSJ1/G960FOXM7CSJ1/G960FXXU7CSI6/G960FXXU7CSJ1 Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: R58K34BTSRF Imei: 357171092914033 Unique Number: CE0218222412DC870C7E Connections: AT,MTP Battery Status: 4.22V (93%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-10-01 Data Encryption State: encrypted Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 357171092914033 Repaired imei: 355727082914036 Current imei2: 357172092914031 Repaired imei2: 355727082914044 Successfully finished. Finished at local time: [11.11.19 14:21:03] WorkID: 78945290 |
11-13-2019, 11:23 | #3768 (permalink) |
Member: 2807129 Status: Offline Thanks Meter: 15 | G960F U7 Imei Repair And PATCH DONE Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Sales Code: PHE Country Code: SPAIN Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Oct 1 14:51:25 KST 2019 PDA Version: G960FXXU7CSJ1 [october 2019, rev1] Phone Version: G960FXXU7CSI6 [september 2019, rev6] CSC Version: G960FOXM7CSJ1 [october 2019, rev1] Product Code: PHE HIDSw Version: G960FXXU7CSJ1/G960FOXM7CSJ1/G960FXXU7CSI6/G960FXXU7CSJ1 Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: R58K34BTSRF Imei: 357171092914033 Unique Number: CE0218222412DC870C7E Connections: AT,MTP Battery Status: 4.22V (93%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-10-01 Data Encryption State: encrypted Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 357171092914033 Repaired imei: 355727082914036 Current imei2: 357172092914031 Repaired imei2: 355727082914044 Successfully finished. Finished at local time: [11.11.19 14:21:03] WorkID: 78945290 |
11-13-2019, 11:25 | #3769 (permalink) |
Member: 2807129 Status: Offline Thanks Meter: 15 | Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Sales Code: PHE Country Code: SPAIN Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Oct 1 14:51:25 KST 2019 PDA Version: G960FXXU7CSJ1 [october 2019, rev1] Phone Version: G960FXXU7CSI6 [september 2019, rev6] CSC Version: G960FOXM7CSJ1 [october 2019, rev1] Product Code: PHE HIDSw Version: G960FXXU7CSJ1/G960FOXM7CSJ1/G960FXXU7CSI6/G960FXXU7CSJ1 Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: R58K34BTSRF Imei: 355727082914036 Unique Number: CE0218222412DC870C7E Connections: AT,MTP Battery Status: 4.07V (90%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-10-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 21.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. |
11-13-2019, 11:25 | #3770 (permalink) |
11-13-2019, 15:26 | #3772 (permalink) |
Junior Member Join Date: Dec 2014 Location: south africa
Member: 2310097 Status: Offline Sonork: 100.113643 Thanks Meter: 7 | Chimera Mobile Phone Utility version: 22.94.1309 @ 2019-11-13 Printing phone history Repair IMEI 11/13/2019 1:03:01 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Sales Code: XFV Country Code: South Africa Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Jul 2 17:03:00 KST 2019 PDA Version: A105FDDU3ASG2 [july 2019, rev2] Phone Version: A105FDDU3ASG2 [july 2019, rev2] CSC Version: A105FOJM3ASG2 [july 2019, rev2] Product Code: XFV HIDSw Version: A105FDDU3ASG2/A105FOJM3ASG2/A105FDDU3ASG2/A105FDDU3ASG2 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RF8M72TNLCA Imei: 354062100399197 Unique Number: CBJ00C27D8DC066 Connections: AT,MTP Battery Status: 3.83V (27%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.13.19 16:21:46] WorkID: 79245647 |
11-14-2019, 15:15 | #3773 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 22.94.1309 @ 2019-11-14 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G930F Sales Code: DBT Country Code: Germany Timezone: Africa/Johannesburg Android Version: 7.0 [NRD90M] [SDK 24] Build Date: Mon Jan 15 17:03:31 KST 2018 PDA Version: G930FXXS2DRA9 [january 2018, rev9] Phone Version: G930FXXU2DRA9 [january 2018, rev9] CSC Version: G930FDBT1DQJ1 [october 2017, rev1] Product Code: DBT HIDSw Version: G930FXXS2DRA9/G930FDBT1DQJ1/G930FXXU2DRA9/G930FXXS2DRA9 Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58JB3DM22B Imei: 350009876543320 Unique Number: CE10171A0A8B9F3705 Connections: AT,MTP Battery Status: 4.16V (85%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-01-01 Data Encryption State: unsupported Preparing... Checking root access. The phone is rooted by: 2.82:SUPERSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.14.19 09:51:53] |
11-14-2019, 15:16 | #3774 (permalink) |
11-16-2019, 16:43 | #3775 (permalink) |
No Life Poster Join Date: May 2005 Location: Tirana Age: 43
Member: 143851 Status: Offline Thanks Meter: 162 | N976b unlocked ok Chimera Mobile Phone Utility version: 22.97.1505 @ 2019-11-16 Printing phone history Read Codes Online 11/16/2019 3:34:05 PM Read codes started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N976B Sales Code: VOD Country Code: UK Timezone: Europe/Tirane Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Sat Jul 20 17:00:12 KST 2019 PDA Version: N976BXXU1ASGO [july 2019, revO] Phone Version: N976BXXU1ASGQ [july 2019, revQ] CSC Version: N976BOVF1ASGO [july 2019, revO] Product Code: VOD HIDSw Version: N976BXXU1ASGO/N976BOVF1ASGO/N976BXXU1ASGQ/N976BXXU1ASGO Board Platform: EXYNOS5 Modem Platform: SHANNON50005100 Serial Number: RFCM80065LJ Imei: 358782100265736 Unique Number: CE071937AD67B9501E7E Connections: AT,MTP Battery Status: 4.21V (100%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-07-01 Data Encryption State: encrypted Reading codes online... Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for the server to respond. Master Lock: 13537361 Network Lock: 68414131 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Successfully finished. Finished at local time: [11.16.19 16:39:08] WorkID: 79611714 |
11-18-2019, 09:58 | #3776 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,708 | G950F last patch security patch cert done Code: Chimera Mobile Phone Utility version: 22.97.1505 @ 2019-11-17 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Sales Code: XEU Country Code: TURKEY Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Sep 30 16:18:03 KST 2019 PDA Version: G950FXXS5DSJ1 [october 2019, rev1] Phone Version: G950FXXU5DSH3 [august 2019, rev3] CSC Version: G950FOXM5DSHC [august 2019, revC] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF********* Imei: 357************ Battery Status: 4.09V (81%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-10-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.17.19 17:25:37] WorkID: 79702245 |
The Following User Says Thank You to bk.gsm For This Useful Post: |
11-18-2019, 10:00 | #3777 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,708 | A305FN last patch security patch cert done Code: Chimera Mobile Phone Utility version: 22.97.1505 @ 2019-11-16 Printing phone history Repair IMEI 11/16/2019 10:14:08 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A305FN Sales Code: CAC Country Code: Central Asia Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Oct 10 17:25:54 KST 2019 PDA Version: A305FNXXU2ASJ2 [october 2019, rev2] Phone Version: A305FXXU2ASJ2 [october 2019, rev2] CSC Version: A305FNOEM2ASJ2 [october 2019, rev2] Product Code: CAC HIDSw Version: A305FNXXU2ASJ2/A305FNOEM2ASJ2/A305FXXU2ASJ2/A305FNXXU2ASJ2 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R5*********** Imei: 35**************** Unique Number: CBJ00468A617766 Connections: AT,MTP Battery Status: 3.72V (15%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-10-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.16.19 16:16:15] WorkID: 79593385 |
11-19-2019, 11:06 | #3778 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 22.97.1505 @ 2019-11-19 Printing phone history Patch Certificate 11/9/2019 10:02:12 AM Knoxguard Unlock 11/9/2019 9:28:18 AM Repair IMEI 11/9/2019 9:26:32 AM Repair IMEI 11/9/2019 9:01:30 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A750F Sales Code: XFA Country Code: India Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Sep 17 14:48:08 KST 2019 PDA Version: A750FXXU2BSI2 [september 2019, rev2] Phone Version: A750FNXXU2BSI1 [september 2019, rev1] CSC Version: A750FODM2BSI2 [september 2019, rev2] Product Code: INS HIDSw Version: A750FXXU2BSI2/A750FODM2BSI2/A750FNXXU2BSI1/A750FXXU2BSI2 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RZ8M11RPDZD Imei: 35 Unique Number: CCU00B86D5B5BC5 Connections: AT,MTP Battery Status: 3.69V (4%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-09-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 18.1:MAGISKSU (topjohnwu) Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.19.19 11:55:16] |
11-19-2019, 11:07 | #3779 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 22.97.1505 @ 2019-11-16 Printing phone history Knoxguard Unlock 11/16/2019 1:20:41 PM Patch certificate started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J600F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Apr 12 19:59:07 KST 2019 PDA Version: J600FXXU3BSD6 [april 2019, rev6] Phone Version: J600FXXU3BSD6 [april 2019, rev6] CSC Version: J600FOJM3BSD6 [april 2019, rev6] Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RZ8K81G7RTK Imei: 35 Battery Status: 4.20V (90%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-03-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.16.19 15:25:26] |
11-19-2019, 11:09 | #3780 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 22.97.1505 @ 2019-11-19 Printing phone history Repair IMEI 11/19/2019 7:49:44 AM Repair IMEI 11/19/2019 7:27:46 AM Repair IMEI 11/16/2019 11:37:57 AM Repair IMEI 11/16/2019 11:18:50 AM Repair IMEI 11/16/2019 11:17:22 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Sales Code: XFA Country Code: India Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Jul 2 17:03:00 KST 2019 PDA Version: A105FDDU3ASG2 [july 2019, rev2] Phone Version: A105FDDU3ASG2 [july 2019, rev2] CSC Version: A105FODM3ASG2 [july 2019, rev2] Product Code: INS HIDSw Version: A105FDDU3ASG2/A105FODM3ASG2/A105FDDU3ASG2/A105FDDU3ASG2 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R58M77VNQ2F Imei: 35 Unique Number: CBJ004CC9940776 Connections: AT,MTP Battery Status: 3.89V (57%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.19.19 10:17:17] |
