Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 04-30-2016, 12:13   #1 (permalink)
Member: 2416253
Thanks Meter: 4,162
Sprint conversion FAQ
Dear customers,
This guide will explain you how to use the new "A9 Sprint" conversion feature:
WARNING! This procedure will erase your data. We are not responsible for any damage made to the phone
during this process! Please make it at your own risk!
1. Set your phone to S-OFF and CID to 11111111
2. Connect XTC 2 Clip to your PC, run XTC 2 Tool and open "Special unlock / IMEI" tab.
3. Select "A9 / A9 Sprint" and check the "Convert Sprint A9 to European A9" checkbox
4. Press "Copy files"
5. Follow the "Step 2." instructions as usual (insert XTC 2 Clip into A9 and reboot to FTM).
6. Now flash this flash file #458831 (download from our support site)
7. Do master reset
8. Done. Wait for the phone to boot up.
WARNING! To receive OTA you should change CID to original, for example BS__US001
The Following 6 Users Say Thank You to xtc2clip For This Useful Post:
Old 05-05-2016, 18:24   #2 (permalink)
Member: 2420279
Thanks Meter: 22
Can the conversion go in the other direction, or be reversed?
Old 05-07-2016, 23:22   #3 (permalink)
Member: 2545921
Thanks Meter: 7
Wow. That's awesome work. Any such luck with Sprint M9?
Thanks
Old 05-08-2016, 13:29   #4 (permalink)
Member: 2416253
Thanks Meter: 4,162
At this moment no, but if there will be a demand on this - we will add to our ToDo list for sure.
Old 05-08-2016, 13:30   #5 (permalink)
Member: 2416253
Thanks Meter: 4,162
Thanks
We didn't try to convert Sprint M9 yet, because as far as we know there is no problem with using M9 after unlock anywhere in the world.
Old 05-08-2016, 17:41   #6 (permalink)
Cheater -Don't Deal with him-
Member: 1965371
Thanks Meter: 441
Very clearly understand thank you sor posting the proceder
Old 05-08-2016, 19:02   #7 (permalink)
Member: 2111064
Thanks Meter: 21
tks for the update, is it possible to convert 626 sprint to 626 EU? as this phone sprint uses a different MID A32E_WHL compared to A32_UL 626 european one!
pls inform!
WBR
Old 05-11-2016, 07:47   #8 (permalink)
Member: 2545921
Thanks Meter: 7
Yes, no problem with getting phone service etc. But the Sprint firmware is not very GSM friendly. An option to change to GSM firmware would be amazing.
I tried the process above for the A9 (with BS_US001 M9 firmware) and after the install the baseband is lost and so is the IMEI. This is easily restored with Sprint firmware though.
Hope that helps and looks forward to further development
Thanks
The Following 2 Users Say Thank You to Deeblog For This Useful Post:
Old 05-17-2016, 06:13   #9 (permalink)
Member: 2484103
Thanks Meter: 3
thanks for the procedure it worked fine,i would like to know if i can install otas,it will make the search and notify but i dont want to end with a brick .
it will install it like any other phone with any other update??
or should i first turn s-on??
Old 05-17-2016, 11:23   #10 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
After the conversion the phone will behave like normal, so you should be able to receive & install OTA.
S-OFF does not usually prevent from receiving OTA, so no need to set S-ON.
Old 05-21-2016, 21:26   #11 (permalink)
Member: 1654760
Thanks Meter: 21
I get an OTA Update but can install the OTA update cause It say I have a defference ROM version.
So can us update OTA this A9 Sprint Conversion?
Anw thanks for awesome conversion.
Old 05-23-2016, 13:19   #12 (permalink)
Member: 2416253
Thanks Meter: 4,162
After conversion your phone become a fully European, so I don't know why you must get any messages like "different ROM version", can you provide an exact message or screenshot ?
From our point of view after conversion you should be able to get and install OTA with no problem.
Old 05-23-2016, 18:43   #13 (permalink)
Member: 2484103
Thanks Meter: 3
it says:we have determined that your phone may be running a modifies version of its system software,for your protection we caannot update your phone,please revert your phone to the offical htc system to update your phone ,if you did not modify your system software or would like help reverting your system ,please contact us via the support section at HTC United States
Old 05-26-2016, 11:40   #14 (permalink)
Member: 2469862
Thanks Meter: 3
Dear,
Where i can find the flash file (#458831)?
Thanks,
Old 05-26-2016, 15:32   #15 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by aliali87 View Post
Dear,
Thanks,
Please do NOT duplicate your questions both here and to PM.
You can get the files from support.xtc2.net
Page generated in 0.20987 seconds with 8 queries
