12-29-2016, 19:28 | #46 (permalink) | |||
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Quote:
The Following User Says Thank You to Dr_Wolodya For This Useful Post: |
01-04-2017, 14:18 | #47 (permalink) | |
Crazy Poster Join Date: Apr 2016
Member: 2553855 Status: Offline Thanks Meter: 5 | Quote:
Sent from my SAMSUNG-SM-G870A using Tapatalk | |
01-06-2017, 14:55 | #49 (permalink) |
Member: 2553855 Status: Offline Thanks Meter: 5 | First I would recommend to download the original files of your phone from download section. Your Cid values are all 111111 . For s-off what option you selected? Sent from my SAMSUNG-SM-G870A using Tapatalk |
01-06-2017, 15:30 | #51 (permalink) | |
Junior Member Join Date: Feb 2015
Member: 2346185 Status: Offline Thanks Meter: 4 | Quote:
if i remember correctly it didnt want to read s-off & cid file of the SD but it did see that the card is inserted, so i made cid and s-off from the software using the usual method and tabs ... by original files what do you mean ? the original Sprint A9 or European A9 it now thinks its Euro ... | |
01-13-2017, 18:34 | #55 (permalink) | |
Follow the instructions exactly and there will be no problem! | |
The Following User Says Thank You to Greenwoo For This Useful Post: |
01-14-2017, 18:38 | #56 (permalink) |
Member: 2346185 Status: Offline Thanks Meter: 4 | UPD I tested on a second phone convertion went well i do have Euro rom also But i cant recieve OTA's like everyone else in this thread I tried relocking the bootloader and change cid to HTC__A07 but still gives error any advice ? someone had defeated this problem? |
01-28-2017, 17:14 | #58 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2678252 Status: Offline Thanks Meter: 1 | Need assistance with converting my HTC A9 sprint to European version. S-OFF and CID 11111111 done, have copied files to clip sd card, inserted it into the phone and went in FTM mode but nothing happens. Please help |
01-31-2017, 14:15 | #60 (permalink) |
Freak Poster Join Date: Jan 2013 Location: RUSSIA
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | Trying to connect in Sprint mode... Trying to connect on COM76 Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Please wait, generating unlock hash... Process finished SUCCESSFULLY Please restart your phone for the changes to take effect Note: If your phone is M7 - please do S-OFF first and then unlock again In case of calls/network problems, please do reset by: Open phone dialer, type ##786#, wait for the menu to appear Press MENU in top right corner and select RESET Enter SPC code Wait for the phone to verify the code and reboot Opening special menu Please check your phone screen: DM Command Service Should appear Choose '1. DM ON' and press SELECT You will be asked to enter MSL code Enter SPC code from last step We will try to do it automatically, but if something will go wrong - please enter manually. At the end you should see 'Diag enabled' or 'Have enabled before' Please wait... If you see 'Diag enabled' - please press to Step 4. Otherwise try to perform operation manually. Phone DISconnected the htc-set is still locked |
