08-21-2015, 20:58 | #76 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
08-22-2015, 10:27 | #77 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: Sudan
Member: 219803 Status: Offline Sonork: 1582317 Thanks Meter: 38 | Quote:
I tested it with 2 HTC M8 which was installed TWRP and formatted system and can not boot to system at all. I S-offed and Super CID through direct mode then run Normal RUU L50 and worked perfectly. | |
08-22-2015, 11:45 | #78 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Guys please this isn't right thread for to talk about these issue...we are Off Topic in FULL. @zozo2 good for you report, but i had write above that XTC2CLIP work in Hboot/Fastboot so can be possible...but if this user want more clairment can open his own new thread... BR allumts |
08-24-2015, 15:21 | #79 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | hTC Desire 300 (G3U) S-off super CID Done with Direct Mode Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 1.16.0002 (bootloader) version-baseband: 14.10.36Q4.13 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: HT39XWL05617 (bootloader) imei: 358887xxxxxxxx (bootloader) meid: (bootloader) product: g3u (bootloader) platform: HBOOT-8225 (bootloader) modelid: 0P6A20000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 4120mV (bootloader) partition-layout: HTC (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-2ee15b5d5a (bootloader) hbootpreupdate: 12 (bootloader) gencheckpt: 0 Execution time is 15(ms) all: Done! |
08-25-2015, 10:32 | #81 (permalink) | |
http://forum.gsmhosting.com/vbb/f961...eader-1964692/ BR allumts | |
08-30-2015, 21:05 | #83 (permalink) |
Insane Poster Join Date: Feb 2014
Member: 2131029 Status: Offline Thanks Meter: 4 | 30/08/2015 09:49:54 م Phone connected [FA51DWM01765] 30/08/2015 09:49:55 م Sending oem writesecureflag 0 30/08/2015 09:49:55 م ... (bootloader) SecuritySDInit: counter = 2 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 30/08/2015 09:49:56 م (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078256 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found 30/08/2015 09:49:59 م (bootloader) writesecureflag: KeyCard remain count 10000 (bootloader) PID:272 (bootloader) Start Verify: 3 30/08/2015 09:50:00 م (bootloader) [PGFS] partition_update_pgfs: pg1fs_security (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery Execution time is 4309(ms) OKAY 30/08/2015 09:50:00 م Operation finished 30/08/2015 09:50:08 م Sending reboot-bootloader 30/08/2015 09:50:08 م Execution time is 13(ms) rebooting into bootloader... OKAY 30/08/2015 09:50:08 م Operation finished 30/08/2015 09:50:09 م Phone DISconnected 30/08/2015 09:50:13 م Phone connected [FA51DWM01765] 30/08/2015 09:50:18 م Sending oem writecid 11111111 30/08/2015 09:50:18 م ... (bootloader) Start Verify: 0 (bootloader) Input CID is super CID (bootloader) Start Verify: 0 Execution time is 32(ms) OKAY 30/08/2015 09:50:18 م Operation finished |
09-03-2015, 22:50 | #84 (permalink) |
Freak Poster Join Date: Aug 2010 Age: 38
Member: 1382268 Status: Offline Thanks Meter: 71 | HTC One M8_UL----->>>S-Off---Super CID Done Device Info Before Operation: Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.18.0.0000 (bootloader) version-baseband: 1.19.21331147A1.09G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.22.401.5 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: HT49JWM01872 (bootloader) imei: 3578710xxxxxxxx (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8_ul (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B10000 (bootloader) cidnum: HTC__102 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 5e4b24e4 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Execution time is 15(ms) all: Done! Reading secure flag information (bootloader) secure_flag: 3 Execution time is 0(ms) OKAY Operation Done : [IMG][/IMG] Device Info After Operation: Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.18.0.0000 (bootloader) version-baseband: 1.19.21331147A1.09G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.22.401.5 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: HT49JWM01872 (bootloader) imei: 3578710xxxxxxxx (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8_ul (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B10000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 5e4b24e4 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Execution time is 20(ms) all: Done! Reading secure flag information (bootloader) secure_flag: 0 Execution time is 14(ms) OKAY Reading CID information (bootloader) cid: 11111111 Execution time is 13(ms) OKAY |
09-05-2015, 07:53 | #85 (permalink) |
Cheater -Don't Deal with him- Join Date: Sep 2011 Location: XTC2 CLIP Age: 34
Member: 1664659 Status: Offline Sonork: 100.1615261 Thanks Meter: 228 | HTC one x successfully s off cid change by xtc2 clip [IMG]http://s5.postimg.org/b0cr47***/image.png[/IMG] XTC2 CLIP IS BEST TEAM |
09-10-2015, 07:53 | #86 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Htc Desire X unlock with direct mode Code: Sending oem clearsimlocktype ... (bootloader) AMSS is ready (bootloader) clearsimlocktype: keycard remain count 10000 (bootloader) clearsimlocktype: SimLockType: 1 (bootloader) buf_addr:2FC300,buf_size:6000,start_sector:1779C (bootloader) HWIO_SDC1_MD_REG_ADDR=0xA86000A0 (bootloader) HWIO_SDC1_NS_REG_ADDR=0xA86000A4 (bootloader) HWIO_SDC3_MD_REG_ADDR=0xA86000B0 (bootloader) HWIO_SDC3_NS_REG_ADDR=0xA86000B4 (bootloader) phys_to_virt(HWIO_SDC1_MD_REG_ADDR)=0xD32000A0 (bootloader) phys_to_virt(HWIO_SDC1_NS_REG_ADDR)=0xD32000A4 (bootloader) phys_to_virt(HWIO_SDC3_MD_REG_ADDR)=0xD32000B0 (bootloader) phys_to_virt(HWIO_SDC3_NS_REG_ADDR)=0xD32000B4 (bootloader) HWIO_SDC1_MD_REG_ADDR=0xA86000A0 (bootloader) HWIO_SDC1_NS_REG_ADDR=0xA86000A4 (bootloader) HWIO_SDC3_MD_REG_ADDR=0xA86000B0 (bootloader) HWIO_SDC3_NS_REG_ADDR=0xA86000B4 (bootloader) phys_to_virt(HWIO_SDC1_MD_REG_ADDR)=0xD32000A0 (bootloader) phys_to_virt(HWIO_SDC1_NS_REG_ADDR)=0xD32000A4 (bootloader) phys_to_virt(HWIO_SDC3_MD_REG_ADDR)=0xD32000B0 (bootloader) phys_to_virt(HWIO_SDC3_NS_REG_ADDR)=0xD32000B4 (bootloader) [ERR] Cmd5 polling status timed out, MCI_STATUS: 0x400000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0x400000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0x400000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0x400000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd55 polling status timed out, MCI_STATUS: 0x400000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) sdcc_init_memory_device done (bootloader) HWIO_SDC1_MD_REG_ADDR=0xA86000A0 (bootloader) HWIO_SDC1_NS_REG_ADDR=0xA86000A4 (bootloader) HWIO_SDC3_MD_REG_ADDR=0xA86000B0 (bootloader) HWIO_SDC3_NS_REG_ADDR=0xA86000B4 (bootloader) phys_to_virt(HWIO_SDC1_MD_REG_ADDR)=0xD32000A0 (bootloader) phys_to_virt(HWIO_SDC1_NS_REG_ADDR)=0xD32000A4 (bootloader) phys_to_virt(HWIO_SDC3_MD_REG_ADDR)=0xD32000B0 (bootloader) phys_to_virt(HWIO_SDC3_NS_REG_ADDR)=0xD32000B4 (bootloader) Finish write sector address 1779C ... (bootloader) clearsimlocktype: UnlockSimLockbySmartCard success!!! Execution time is 8703(ms) OKAY Operation finished |
09-12-2015, 22:11 | #87 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | Same: Desire X Direct mode commands Clear simlock success:-) Sending oem clearsimlocktype ... (bootloader) readsecureflag: secure flag: ON (bootloader) AMSS is ready (bootloader) clearsimlocktype: keycard remain count 10000 (bootloader) clearsimlocktype: SimLockType: 1 (bootloader) buf_addr:2FC300,buf_size:6000,start_sector:1779C (bootloader) HWIO_SDC1_MD_REG_ADDR=0xA86000A0 (bootloader) HWIO_SDC1_NS_REG_ADDR=0xA86000A4 (bootloader) HWIO_SDC3_MD_REG_ADDR=0xA86000B0 (bootloader) HWIO_SDC3_NS_REG_ADDR=0xA86000B4 (bootloader) phys_to_virt(HWIO_SDC1_MD_REG_ADDR)=0xD32000A0 (bootloader) phys_to_virt(HWIO_SDC1_NS_REG_ADDR)=0xD32000A4 (bootloader) phys_to_virt(HWIO_SDC3_MD_REG_ADDR)=0xD32000B0 (bootloader) phys_to_virt(HWIO_SDC3_NS_REG_ADDR)=0xD32000B4 (bootloader) HWIO_SDC1_MD_REG_ADDR=0xA86000A0 (bootloader) HWIO_SDC1_NS_REG_ADDR=0xA86000A4 (bootloader) HWIO_SDC3_MD_REG_ADDR=0xA86000B0 (bootloader) HWIO_SDC3_NS_REG_ADDR=0xA86000B4 (bootloader) phys_to_virt(HWIO_SDC1_MD_REG_ADDR)=0xD32000A0 (bootloader) phys_to_virt(HWIO_SDC1_NS_REG_ADDR)=0xD32000A4 (bootloader) phys_to_virt(HWIO_SDC3_MD_REG_ADDR)=0xD32000B0 (bootloader) phys_to_virt(HWIO_SDC3_NS_REG_ADDR)=0xD32000B4 (bootloader) [ERR] Cmd5 polling status timed out, MCI_STATUS: 0x400000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0x400000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0x400000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0x400000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd55 polling status timed out, MCI_STATUS: 0x400000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) sdcc_init_memory_device done (bootloader) HWIO_SDC1_MD_REG_ADDR=0xA86000A0 (bootloader) HWIO_SDC1_NS_REG_ADDR=0xA86000A4 (bootloader) HWIO_SDC3_MD_REG_ADDR=0xA86000B0 (bootloader) HWIO_SDC3_NS_REG_ADDR=0xA86000B4 (bootloader) phys_to_virt(HWIO_SDC1_MD_REG_ADDR)=0xD32000A0 (bootloader) phys_to_virt(HWIO_SDC1_NS_REG_ADDR)=0xD32000A4 (bootloader) phys_to_virt(HWIO_SDC3_MD_REG_ADDR)=0xD32000B0 (bootloader) phys_to_virt(HWIO_SDC3_NS_REG_ADDR)=0xD32000B4 (bootloader) Finish write sector address 1779C ... (bootloader) clearsimlocktype: UnlockSimLockbySmartCard success!!! Execution time is 23156(ms) OKAY Operation finished Reading CID information ... (bootloader) cid: HTC__032 Execution time is 15(ms) OKAY Read information completed. Phone DISconnected BR. |
