09-17-2015, 17:35 | #91 (permalink) |
Product Supporter Join Date: Feb 2012 Location: KB GSM STORE
Member: 1727711 Status: Offline Sonork: 100.1590443 Thanks Meter: 1,331 | HTC Explorer (Pico) S-OFF & SUPER CID DONE 1: Just Insert Clip Flex Inside SD Slot 2: Put Phone in Fastboot Mode 3: Open Exe Go To Direct Mode & Change What You Wanna Do see pics below for more details you can contact me @ skype : kbgsmlab Br |
09-20-2015, 07:22 | #93 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | I unlocked My HTC_ONE_M7 from UK successfully,,,,But one set from Jappan not done...even i did S-OFF & Changed CID successfully but still no service where do i wrong ??? BR |
09-24-2015, 10:15 | #94 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Please don't use this thread to report problem or ask questions, it's not frequently monitored. As to your question - your phone is HTV21, which will be supported in next release. | |
09-24-2015, 11:13 | #95 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | This issue of @sunshine4u, post #92 is same issue that have damaged one HTC one S, after S-OFF+Supercid phone Stuck in Logo....flashed other FW with success but always phone damaged...what happen??? Time ago i've thinked was only one my problem, but now seeing other HTC with same issue i'm a little worried....Phones was working 100% first of this S-OFF and Supercid...please ceck where's Bug becouse i've also changed Touch and ceck Hw side and is all ok. BR allumts |
09-24-2015, 12:47 | #96 (permalink) | |
09-24-2015, 13:11 | #97 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Ops sorry, my mystake reading speed...sorry but is that when i not get out of my shop only one phone NOT Repaired i'm angry...anyway all other are benn managed with success...only this cannot understand... BR allumts |
10-30-2015, 14:52 | #100 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Paris Age: 36
Member: 670113 Status: Offline Sonork: 100:1615871 Thanks Meter: 44 | HTC One Max Sprint Unlock Done solution HTC One Max SPRINT UNLOCK (only work with S-OFF) 1) go to the tab "SD mode editor" enable new sec (Security S-OFF). 2) click save to driver. 3) disable S-ON with cable Y and XTC2CLIP 4) once deactivated S-ON go to the tab "SPRINT" 5) Please connect phone in FASTBOOT (vol_down + pwr) 6) click GET SPC Code 7) when you have the SPC click OS 8) enable mode adb 9) go dial write ##3424#, select DM ON 10) click refresh, select port diag 11) click unlock 12) restart the phone Trying to connect in Sprint mode... Trying to connect on COM91 Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Please wait, generating unlock hash... Process finished SUCCESSFULLY Please restart your phone for the changes to take effect Phone DISconnected |
The Following User Says Thank You to lovelyboy For This Useful Post: |
11-01-2015, 14:28 | #102 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | HTC M8 S-OFF + SUPERCID+ IMEI REPAIRED ONLY 3 MIN.s in DIRECT MODE, SUCCESS (sorry Bad quality Photo) XTC2CLIP Connetcted Directly in Sd Card Slot and Phone to Pc Procedure with Xtc2Clip with Phone in "Bootloader first" HERE RESULT OF FULL PROCEDURE IN M8, IMPORTANT: PHONE HAVE LEAVED OFFICIAL, so Receive Update itc... BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
11-02-2015, 14:38 | #103 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | htc One Unlock Super Cid Done!!!!! |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
11-04-2015, 11:51 | #104 (permalink) |
Junior Member Join Date: Jun 2007
Member: 520070 Status: Offline Thanks Meter: 1 | Thanks for the quick response. My two clips work again. Super servis for Xtc2clip. Thanks again to xtc2clip Product Manager. |
The Following User Says Thank You to nevada1960 For This Useful Post: |
11-12-2015, 08:22 | #105 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: *#0011# NG
Member: 1736804 Status: Offline Sonork: @kanokh / @imeione Thanks Meter: 451 | HTC 610 S-Off OKAY HTC 610 S-Off writesecureflag 0 OKAY Quote:
The Following User Says Thank You to kanokh For This Useful Post: |
