11-11-2021, 17:59 | #10456 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Oppo A5S Pattern Remove Code: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM26 [MediaTek USB Port_V1632 (COM26)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&66ca680&0&7#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] Preparing device... -- Success! Preloader saved as : preloader_oppo6765_18511_211103_155516.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM26) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Manufacturer : OPPO Build Flavor : full_oppo6765_18511-user Build Desc. : full_oppo6765_18511-user 8.1.0 O11019 1616154336 release-keys Android Ver. : 8.1.0 Patch Level : 2021-04-05 Platform : mt6765 Userdata is ENCRYPTED Resetting Locks (Oppo)... - Success! ---IMPORTANT--- Start phone directly in Recovery to complete operation. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.5] |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
11-11-2021, 18:00 | #10457 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Vivo Y53 Format & Frp Code: Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM47) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4FFF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, EMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo PD1628F_EX [msm8937] [PD1628F_EX] Brand : vivo Prod.Name : PD1628F_EX Software : MMB29M release-keys, eng.compiler.20190105.211334 [Sat Jan 5 21:20:28 CST 2019] Android Ver. : 6.0.1 Patch Level : 2018-08-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 7.3 |
11-11-2021, 18:02 | #10458 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | ZTE ZMax Pro Frp Code: Device : ZTE ZMax Pro (Z981) Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1209700 [8952] 00000400 OPK_DATA : 5662CAD0CFCCC2090245A6E87006CBAAECF28FAE81C62246BCC25820C5146F8E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8952_017]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8952, EMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : ZTE Z981 [msm8952] [urd] Brand : ZTE Prod.Name : P895T20_MPCS Software : Z981V1.0.0B21, 20170802.130758 [Wed Aug 2 13:21:42 CST 2017] Android Ver. : 6.0.1 Patch Level : 2017-08-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 7.3 |
11-11-2021, 18:03 | #10459 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO A83 Format Code: Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... No existing META port found. Connect powered off phone... Make sure to leave Buttons as soon as phone is detected. Found MediaTek PreLoader USB VCOM_V1632 (Android) (COM116) on COM116 Device Path : \\?\usb#vid_22d9&pid_0006#6&66ca680&0&6#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Rebooting to META mode... Waiting for phone in META mode... Found MediaTek PreLoader USB VCOM_V1632 (Android) (COM116) on COM116 Device Path : \\?\usb#vid_22d9&pid_0006#6&66ca680&0&6#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Configuring Communication Channel... Reading phone information... CPU : MT6763 SW Ver. : MOLY.LR12A.R1.TC16.SP.V26.P58 HW Ver. : OPPO6763_C66_N1_HW Brand: OPPO Model: CPH1729 Name: OPPO A83 Platform: unknown OEM Prod.: unknown OEM Device: unknown Build Date: Fri Sep 4 00:52:36 CST 2020 Display ID: CPH1729EX_11_A.35_200903 OTA Version: M6763D_11.A.35_0350_202009032342 Patch Level: 2019-10-05 Starting Safe Factory Reset... Reset Success Operation finished If META method does not work, try Format FS in BROM mode. [UltimateMTK Ver. 4.5] |
11-11-2021, 18:05 | #10460 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Vivo S1 Pro Format & Frp Code: Device : Vivo S1 Pro (PD1945F) Operation : Format FS 2 (Vivo) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM47) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 03007300 OPK_DATA : F754F13EE91BF54295CA1FBD64D182067440B35FC41B798A539670EA259771BA Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : SDM665, UFS, 128 GB LU Count : 6 [0x01D81800] [0x00000800] [0x00000800] [0x00004000] [0x00040000] [0x00004000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Software : , eng.compil.20210901.105305 [Wed Sep 1 10:53:05 CST 2021] Android Ver. : 11 Patch Level : 2021-09-01 Preparing Data...Done Formatting Userdata......Done Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 7.3 |
11-13-2021, 12:48 | #10461 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,708 | Redmi 9A frp done Code: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM7 Port Name: MediaTek USB Port_V1633 (COM7) Path: \\?\usb#vid_0e8d&pid_0003#6&3b2e6861&2&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_k62v1_64_bsp_211111_155956.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM7) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Unable to read! Userdata is ENCRYPTED Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.4] |
The Following User Says Thank You to bk.gsm For This Useful Post: |
11-13-2021, 13:14 | #10462 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: istanbul
Member: 2171555 Status: Offline Thanks Meter: 129 | Quote:
loader not found | |
11-13-2021, 13:17 | #10463 (permalink) |
Member: 2171555 Status: Offline Thanks Meter: 129 | Operation : Format FS 2 (Vivo) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM37) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.6 Opening Port...OK Invalid response from device! Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM37) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.6 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1601300 [SDM460] 03007300 OPK_DATA : F754F13EE91BF54295CA1FBD64D182067440B35FC41B798A53 9670EA259771BA Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [SDM460]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.4 |
11-13-2021, 13:17 | #10464 (permalink) |
11-13-2021, 14:46 | #10465 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,708 | We_F10 frp done Code: Operation : Reset FRP CPU : MT6580 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.01/21/2021.12:51] Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1633 (Android) (COM18) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : WE Manufacturer : Vanzo Model : WE F10 Prod. Name : WE_F10 Device : WE_F10 Build Date : Wed Sep 19 21:00:52 CST 2018 Build Flavor : mt6580o_we613b_h31a-f10_xlj_cc_64gbitp8d3_go_wcdma_mul Build Desc. : full_we613b-user 8.1.0 O11019 20180919 release-keys Android Ver. : 8.1.0 Display ID : WE_F10_HW1_SW10 Patch Level : 2018-09-05 Platform : mt6580 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.4] |
11-14-2021, 13:38 | #10466 (permalink) |
Freak Poster Join Date: Aug 2010 Location: india, haryana,
Member: 1358048 Status: Offline Thanks Meter: 706 | Oppo A16 user lock & frp reset done Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM6 [MediaTek USB Port_V1632 (COM6)] Device Path: \\?\usb#vid_0e8d&pid_0003#5&1e6a4af9&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] Preparing device... -- Success! Preloader saved as : preloader_oppo6765_211114_174732.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM6) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Build Date : Fri Jul 23 03:14:34 CST 2021 Build Flavor : sys_oplus_mssi_64_cn-user Build Desc. : sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1626980523742 release-keys Android Ver. : 11 Display ID : RP1A.200720.011 release-keys Patch Level : 2021-08-05 Platform : MT6765 Board : oppo6765 Platform : mt6765 Userdata is ENCRYPTED Formatting Userdata... - Success! Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.5] |
The Following User Says Thank You to skakroliya For This Useful Post: |
11-14-2021, 13:38 | #10467 (permalink) |
Member: 1358048 Status: Offline Thanks Meter: 706 | Oppo A16 user lock & frp reset done Code: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM6 [MediaTek USB Port_V1632 (COM6)] Device Path: \\?\usb#vid_0e8d&pid_0003#5&1e6a4af9&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] Preparing device... -- Success! Preloader saved as : preloader_oppo6765_211114_174732.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM6) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Build Date : Fri Jul 23 03:14:34 CST 2021 Build Flavor : sys_oplus_mssi_64_cn-user Build Desc. : sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1626980523742 release-keys Android Ver. : 11 Display ID : RP1A.200720.011 release-keys Patch Level : 2021-08-05 Platform : MT6765 Board : oppo6765 Platform : mt6765 Userdata is ENCRYPTED Formatting Userdata... - Success! Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.5] |
11-15-2021, 03:29 | #10468 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Nadi
Member: 210669 Status: Online Thanks Meter: 97 | Operation : Generic ADB FRP Reset Searching for Device...Found Brand : samsung Model : SM-A217F Product : a21s Device : a21s Andriod Ver. : 11 Patch Level : 2021-09-01 PDA : A217FXXS7CUI3 Bootloader : A217FXXS7CUI3 Build ID : RP1A.200720.012.A217FXXS7CUI3 Build Date : Fri Sep 10 01:29:56 KST 2021 Resetting FRP Lock...Done Operation Finished. UltimateFRP Ver. 0.5.1 |
The Following User Says Thank You to kava For This Useful Post: |
11-15-2021, 03:29 | #10469 (permalink) |
