09-30-2020, 09:04 | #181 (permalink) |
No Life Poster Join Date: Jul 2013 Location: ROGER/BELL/TELUS/NTT/AU KDDI Age: 38
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Oppo a31 cph2015 (2020) pattern unlock done with graet umt king Code: Opening Device...Done Physical Details: Chip Size : 0xE8F800000 [58.24 GB] Sector Size : 0x0200 Sector Count : 0x0747C000 Reading Partition Table...OK GPT Details: Sector Size : 0x0200 Part Count : 44 Reading Device Information...OK Device : OPPO Android Ver. : 9 Patch Level : 2020-06-05 Formatting Userdata in Safe Mode...Done Turn on device to finalize operation. Operation Finished. |
The Following User Says Thank You to UnlockwithCode For This Useful Post: |
09-30-2020, 09:05 | #182 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Samsung j200g usb device not recognized frp remove done with great umt king Code: Opening Device...Done Physical Details: Chip Size : 0x1D2000000 [7.28 GB] Sector Size : 0x0200 Sector Count : 0x00E90000 Reading Partition Table...OK GPT Details: Sector Size : 0x0200 Part Count : 25 Reading Device Information...OK Device : samsung SM-J200G [exynos3] [j2lte] Software : LMY47X.J200GDCU2ARL1, J200GDCU2ARL1 [Wed Dec 19 21:24:52 KST 2018] Android Ver. : 5.1.1 Patch Level : 2017-08-01 Resetting FRP...Done Operation Finished. |
09-30-2020, 11:10 | #183 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Samsung j700f recover/frp done with great umt king Code: Device: Any Samsung Operation: Flash Firmware Port: COM21 : SAMSUNG Mobile USB Modem #3 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI7580 [HiSpeed] Sending Partition [BOOTLOADER]... Done Sending Partition [CM]... Done Sending Partition [BOOT]... Done Sending Partition [RECOVERY]... Done Sending Partition [SYSTEM]... Done Sending Partition [RADIO]... Done Sending Partition [CACHE]... Done Sending Partition [HIDDEN]... Done Closing Session... Done Operation Finished. Elapsed Time: 04:26 [Ultimate Samsung Flasher v1.5] Device: Samsung Device Operation: Reset FRP (New Method) Port: COM21 : SAMSUNG Mobile USB Modem #3 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI7580 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:14 [Ultimate Samsung Flasher v1.5] |
10-02-2020, 18:53 | #184 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Realme c2 rmx 1941 pin lock remove done with great umt king |
10-14-2020, 07:36 | #185 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Sam j200g Frp Reset Done With Great Umt King Code: Device: Samsung Device Operation: Reset FRP (New Method) Port: COM56 : SAMSUNG Mobile USB Modem #6 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI3475 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:13 [Ultimate Samsung Flasher v1.5] |
10-14-2020, 07:37 | #186 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | TECNO IN1 Pro FFS/FRP REMOVE DONE WITH GREAT UMT KING Code: Brand : Tecno Model : IN1 Operation : Format FS Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM44) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : TECNO Manufacturer : TECNO MOBILE LIMITED Model : TECNO IN1 Pro Prod. Name : H398 Device : TECNO-IN1-Pro Android Ver. : 8.1.0 Display ID : IN1Pro-H398J-O-181019V213 Patch Level : 2018-10-05 Userdata is ENCRYPTED Formatting userdata... - Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.2] Brand : Tecno Model : IN1 Operation : Reset FRP Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM44) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : TECNO Manufacturer : TECNO MOBILE LIMITED Model : TECNO IN1 Pro Prod. Name : H398 Device : TECNO-IN1-Pro Android Ver. : 8.1.0 Display ID : IN1Pro-H398J-O-181019V213 Patch Level : 2018-10-05 Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.2] |
10-14-2020, 07:39 | #187 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Xiaomi Redmi Note 4 PATTERN REMOVE DONE WITH GREAT UMT KING Code: Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] [mido] Brand : xiaomi Prod.Name : mido Software : AL1512-mido-build-20191107001817, V11.0.2.0.NCFMIXM [Thu Nov 7 00:18:07 WIB 2019] Android Ver. : 7.0 Patch Level : 2018-12-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 6.1 |
10-14-2020, 07:40 | #188 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Xiaomi Redmi Note 4 MI ACC REMOVE DONE WITH GREAT UMT KING Code: Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] [mido] Brand : xiaomi Prod.Name : mido Software : AL1512-mido-build-20191107001817, V11.0.2.0.NCFMIXM [Thu Nov 7 00:18:07 WIB 2019] Android Ver. : 7.0 Patch Level : 2018-12-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 6.1 |
10-14-2020, 07:41 | #189 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | vivo 1724 PATTERN LOCK/FRP REMOVE DONE WITH GREAT UMT KING Code: Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM35) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4FFF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1724 [msm8937_64] Brand : vivo Prod.Name : msm8937_64 Software : OPM1.171019.011 release-keys, eng.compil.20180926.200120 [Wed Sep 26 20:01:20 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-09-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 6.1 |
10-14-2020, 07:42 | #190 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Xiaomi Redmi Note 4 FFS/FRP/MI ACC REMOVE DONE WITH GREAT UMT KING Code: Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM35) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] [mido] Brand : xiaomi Prod.Name : mido Software : AL1512-mido-build-20180112234639, V9.2.1.0.NCFMIEK [Fri Jan 12 23:46:37 WIB 2018] Android Ver. : 7.0 Patch Level : 2017-12-05 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 6.1 Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM35) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] [mido] Brand : xiaomi Prod.Name : mido Software : AL1512-mido-build-20180112234639, V9.2.1.0.NCFMIEK [Fri Jan 12 23:46:37 WIB 2018] Android Ver. : 7.0 Patch Level : 2017-12-05 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 6.1 |
10-14-2020, 07:44 | #191 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Nokia ta 1011 frp remove done with great umt king Code: Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM35) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : A57FDEEB0D02233786D8DDCA8A9889D62F92D43EE56EAC9966024663C39A5B06 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8909_051]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : FIH FIH-E1M-FIH [msm8909] [E1M] Brand : FIH Prod.Name : E1M_00WW_FIH Software : 00WW_0_68R, 00WW_0_68R [Wed Oct 30 22:53:36 CST 2019] Android Ver. : 7.1.1 Patch Level : 2019-11-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 6.2 |
10-14-2020, 07:45 | #192 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Xiaomi Redmi Note 8 RESTART ON LOGO DONE WITH GREAT UMT KING 1 Code: Device : Xiaomi Redmi Note 8 Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : SDM665, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 8 [ginkgo] Brand : xiaomi Prod.Name : ginkgo Software : PKQ1.190616.001, V11.0.6.0.PCOINXM [Tue Sep 8 19:55:56 WIB 2020] Android Ver. : 9 Patch Level : 2020-08-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 6.2 Device : Xiaomi Redmi Note 8 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : SDM665, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 8 [ginkgo] Brand : xiaomi Prod.Name : ginkgo Software : PKQ1.190616.001, V11.0.6.0.PCOINXM [Tue Sep 8 19:55:56 WIB 2020] Android Ver. : 9 Patch Level : 2020-08-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 6.2 Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM35) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : SDM665, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512 Writing [qupv3fw.elf] -> [qupfw] ...Done Writing [qupv3fw.elf] -> [qupfwbak] ...Done Writing [vbmeta.img] -> [vbmeta] ...Done Writing [vbmeta.img] -> [vbmetabak] ...Done Writing [xbl_config.elf] -> [xbl_config] ...Done Writing [xbl_config.elf] -> [xbl_configbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [storsec.mbn] -> [storsec] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [km4.mbn] -> [keymaster] ...Done Writing [km4.mbn] -> [keymasterbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [abl.elf] -> [abl] ...Done Writing [abl.elf] -> [ablbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [BTFM.bin] -> [bluetoothbak] ...Done Writing [misc.img] -> [misc] ...Done Writing [imagefv.elf] -> [imagefv] ...Done Writing [imagefv.elf] -> [imagefvbak] ...Done Writing [uefi_sec.mbn] -> [uefisecapp] ...Done Writing [uefi_sec.mbn] -> [uefisecappbak] ...Done Writing [xbl.elf] -> [xbl] ...Done Writing [xbl.elf] -> [xblbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [logfs_ufs_8mb.bin] -> [logfs] ...Done Writing [metadata.img ] -> [metadata]...Done Writing [dtbo.img] -> [dtbo] ...Done Writing [dtbo.img] -> [dtbobak] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [dspso.bin] -> [dspbak] ...Done Writing [persist.img] -> [persist] ...Done Writing [boot.img] -> [boot] ...Done Writing [boot.img] -> [bootbak] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [NON-HLOS.bin] -> [modembak] ...Done Writing [cust.img ] -> [cust]...Done Writing [vendor.img ] -> [vendor]...Done Writing [system.img ] -> [system]...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Setting Bootable Storage Drive to 0...Done Resetting device...Done Operation Finished. QcFire Ver. 6.2 |
12-01-2020, 07:35 | #193 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Redmi 5 Done With Great Umt King Code: Operation : Read Pattern Lock Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM35) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_009]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 [msm8953] [rosy] Brand : Xiaomi Prod.Name : rosy Software : N2G47H, V9.5.14.0.NDAMIFD [Wed May 30 22:50:10 WIB 2018] Android Ver. : 7.1.2 Patch Level : 2018-05-01 Android 6.x and higher are not supported, please use [Reset Locks] function. Operation Finished. QcFire Ver. 6.2 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM35) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_009]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 [msm8953] [rosy] Brand : Xiaomi Prod.Name : rosy Software : N2G47H, V9.5.14.0.NDAMIFD [Wed May 30 22:50:10 WIB 2018] Android Ver. : 7.1.2 Patch Level : 2018-05-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 6.2 |
12-01-2020, 07:39 | #194 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | vivo y91i done with great umt king Code: Selected model: Vivo Y91C [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Keep VOL+ button untill inserting USB cable. Detected : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE Sending loader..... BBCHIP MT6765 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051443633 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Phone have OTP partition. Modem version: MOLY.LR12A.R2.MP.V23.P200 Starting helio frp, not disconnect phone untill done [HELIO][frp]Format partition, please wait... [0]FRP Reset Done. [helio]Wait untill phone will start charging. [0]All done. |
12-01-2020, 07:40 | #195 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Infinix Note 4 (X572) Done with great umt king Code: Brand : Infinix Model : Note 4 (X572) Operation : Read Info Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM22) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Infinix Manufacturer : Infinix Model : Infinix X572 Prod. Name : H5312 Device : Infinix-X572 Board : x572_h5312 Platform : mt6753 Android Ver. : 8.1.0 Display ID : X572-H5312E-O-IN-181016V89 Patch Level : 2018-09-05 Userdata is ENCRYPTED Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.2] Brand : Infinix Model : Note 4 (X572) Operation : Format FS Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM22) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Infinix Manufacturer : Infinix Model : Infinix X572 Prod. Name : H5312 Device : Infinix-X572 Board : x572_h5312 Platform : mt6753 Android Ver. : 8.1.0 Display ID : X572-H5312E-O-IN-181016V89 Patch Level : 2018-09-05 Userdata is ENCRYPTED Formatting userdata... - Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.2] |
