04-16-2019, 09:11 | #31 (permalink) |
No Life Poster Join Date: Jul 2013 Location: ROGER/BELL/TELUS/NTT/AU KDDI Age: 38
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Succsessfully Recover Micromax Q4202 With Great Umt Tool Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Micromax Micromax Q4202 [msm8909] Software : MMX_Q4202_IND_SW_V3.0_HW_V0.2_06032017, eng.spwork.20170306.211258 [Mon Mar 6 21:19:21 CST 2017] Android Ver. : 6.0.1 Patch Level : 2017-02-01 USERDATA : Normal You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.1 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Micromax Micromax Q4202 [msm8909] Software : MMX_Q4202_IND_SW_V3.0_HW_V0.2_06032017, eng.spwork.20170306.211258 [Mon Mar 6 21:19:21 CST 2017] Android Ver. : 6.0.1 Patch Level : 2017-02-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 |
The Following User Says Thank You to UnlockwithCode For This Useful Post: |
04-16-2019, 09:12 | #32 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Succsessfully Remove Frp Gionee P7 Max With Great Umt Tool Code: Operation : Read Info CPU : MT6595 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : GIONEE Manufacturer : GIONEE Model : P7 Max Prod. Name : P7_Max Device : GIONEE_WBL5708 Board : P7_Max Platform : mt6595 Android Ver. : 6.0 Display ID : amigo3.2.0 Patch Level : 2017-02-05 Userdata is ENCRYPTED Disconnect Battery/Cable and Power On Phone. [Ver. 1.8] Operation : Reset FRP CPU : MT6595 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : GIONEE Manufacturer : GIONEE Model : P7 Max Prod. Name : P7_Max Device : GIONEE_WBL5708 Board : P7_Max Platform : mt6595 Android Ver. : 6.0 Display ID : amigo3.2.0 Patch Level : 2017-02-05 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.8] |
04-20-2019, 09:41 | #33 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Xiaomi Redmi 4X Reset Mi Account Reset FRP With Great Umt Tool Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4X [msm8937] Software : N2G47H, V10.1.1.0.NAMMIFI [Wed Nov 14 19:06:32 WIB 2018] Android Ver. : 7.1.2 Patch Level : 2018-10-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.1 Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4X [msm8937] Software : N2G47H, V10.1.1.0.NAMMIFI [Wed Nov 14 19:06:32 WIB 2018] Android Ver. : 7.1.2 Patch Level : 2018-10-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 4.1 Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4X [msm8937] Software : N2G47H, V10.1.1.0.NAMMIFI [Wed Nov 14 19:06:32 WIB 2018] Android Ver. : 7.1.2 Patch Level : 2018-10-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 |
04-24-2019, 08:42 | #34 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | LYF LS-4508 Frp Reset Done With Great Umt Tool Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LYF LS-4508 [msm8909] Software : MMB29M release-keys, eng.user.20180626.125837 [2018年 06月 26日 星期二 13:04:24 CST] Android Ver. : 6.0.1 Patch Level : 2017-06-05 USERDATA : Normal You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.1 Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LYF LS-4508 [msm8909] Software : MMB29M release-keys, eng.user.20180626.125837 [2018年 06月 26日 星期二 13:04:24 CST] Android Ver. : 6.0.1 Patch Level : 2017-06-05 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 |
04-24-2019, 08:43 | #35 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Itel A41 Frp Reset Done With Great Umt Tool Code: Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Huawei SPD FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : 1.0 Product Bootloader : Locked Bootloader is Locked. FRP Reset may fail! Removing FRP Lock... Done Operation Finished. Elapsed Time: 00:14 [Module Ver. 5.2] Log Saved to Logs\190424_123903.log |
04-24-2019, 08:44 | #36 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Xiaomi Redmi Go Frp Reset Done With Great Umt Tool Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Go Software : OPM1.171019.026.V10.2.6.0.OCLINXM, V10.2.6.0.OCLINXM [Mon Jan 14 18:10:09 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-01-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.1 Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Go Software : OPM1.171019.026.V10.2.6.0.OCLINXM, V10.2.6.0.OCLINXM [Mon Jan 14 18:10:09 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-01-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 |
04-24-2019, 08:46 | #37 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Micromax_A114 FFS Reset Ok With Great Umt Tool Code: Operation : Read Info CPU : MT6582 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Micromax Manufacturer : Micromax Model : A114 Prod. Name : A114 Device : Micromax_A114 Board : s8313a Android Ver. : 4.2.2 Display ID : ALPS.JB5.MP.V1.6 Userdata is ENCRYPTED Disconnect Battery/Cable and Power On Phone. [Ver. 1.8] Operation : Format FS CPU : MT6582 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Micromax Manufacturer : Micromax Model : A114 Prod. Name : A114 Device : Micromax_A114 Board : s8313a Android Ver. : 4.2.2 Display ID : ALPS.JB5.MP.V1.6 Userdata is ENCRYPTED Formatting userdata... Format Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.8] |
04-26-2019, 07:50 | #38 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Xiaomi Redmi Note 4 Format FS Reset Mi Account Done With Great Umt Tool Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] Software : AL1512-mido-build-20190128095656, V10.2.3.0.NCFMIXM [Mon Jan 28 09:56:54 WIB 2019] Android Ver. : 7.0 Patch Level : 2018-12-01 USERDATA : Normal You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.1 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] Software : AL1512-mido-build-20190128095656, V10.2.3.0.NCFMIXM [Mon Jan 28 09:56:54 WIB 2019] Android Ver. : 7.0 Patch Level : 2018-12-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] Software : AL1512-mido-build-20190128095656, V10.2.3.0.NCFMIXM [Mon Jan 28 09:56:54 WIB 2019] Android Ver. : 7.0 Patch Level : 2018-12-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 4.1 |
05-13-2019, 07:28 | #39 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Samsung J200G Frp Reset Done With Great Umt Tool Code: Model : J200G Operation : FRP Reset (Format UD) Searching for Phone...Found Port: : COM4 : SAMSUNG Mobile USB Modem Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : LSI3475 [HiSpeed] Loading Data...Done Sending Data...Done Closing Session...Done Operation Finished. Elapsed Time 00:08 Module Ver. 0.1 LOG Saved to !Logs\190513_110813.log |
05-20-2019, 09:59 | #40 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | LAVA Z50 Frp & Dll Image fix With Great Umt Tool Code: Brand : Lava Model : Z50 Operation : Read Info Qt: Untested Windows version 6.2 detected! , Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : LAVA Manufacturer : LAVA Model : Z50 Prod. Name : Z50 Device : Z50 Android Ver. : 8.1.0 Display ID : LAVA_Z50_1_8_V2.0_S168_20190402_ENG_IN Patch Level : 2019-04-05 Userdata is ENCRYPTED Disconnect Battery/Cable and Power On Phone. [Ver. 1.9] Brand : Lava Model : Z50 Operation : Reset FRP Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : LAVA Manufacturer : LAVA Model : Z50 Prod. Name : Z50 Device : Z50 Android Ver. : 8.1.0 Display ID : LAVA_Z50_1_8_V2.0_S168_20190402_ENG_IN Patch Level : 2019-04-05 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.9] Brand : Lava Model : Z50 Operation : Format FS (Advance) Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : LAVA Manufacturer : LAVA Model : Z50 Prod. Name : Z50 Device : Z50 Android Ver. : 8.1.0 Display ID : LAVA_Z50_1_8_V2.0_S168_20190402_ENG_IN Patch Level : 2019-04-05 Userdata is ENCRYPTED Formatting userdata... Format Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.9] |
05-24-2019, 07:58 | #41 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Micromax E460 Frp Remove Done Code: Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 60E4962A OPK_DATA : 1A68854963F4C6119C03F6DF3963E8E97CD204FE1380FE6B93B59DED18C48235 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8937_ddr.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Micromax Micromax E460 [msm8937] Software : MMX_E460_SW_V19_HW_V1.0_25072017, 1500906271 [Mon Jul 24 22:24:02 CST 2017] Android Ver. : 7.1.1 Patch Level : 2017-07-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 |
05-30-2019, 12:31 | #42 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Succsessfully Recover Intex Aqua Ace With Great Umt Tool Code: Operation : Read Info CPU : MT6735M Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM8) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : intex Manufacturer : intex Model : Aqua Ace Prod. Name : Aqua_Ace Device : Aqua_Ace Board : j5809_intex_3565u Platform : mt6735 Android Ver. : 5.1 Display ID : Intex_Aqua_Ace_V08_Indian_VAS_SER Userdata is ENCRYPTED Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 2.0] Operation : Format FS (Advance) CPU : MT6735M Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM8) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : intex Manufacturer : intex Model : Aqua Ace Prod. Name : Aqua_Ace Device : Aqua_Ace Board : j5809_intex_3565u Platform : mt6735 Android Ver. : 5.1 Display ID : Intex_Aqua_Ace_V08_Indian_VAS_SER Userdata is ENCRYPTED Formatting userdata... Format Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 2.0] |
06-01-2019, 08:49 | #43 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Succsessfully Remove Pattern Lock Oppo A71 (CPH1801) With Great Umt Tool Code: Device : Oppo A71 (CPH1801) Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 557BAC65705B8A8303276B9FBB8FD533DBB33EA9E55BF80B47647B8549C170B9 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_015]...Done Executing Loader...OK Formatting Userdata...Done Disconnect phone and hold Power Button to reset. Operation Finished. QcFire Ver. 4.2 |
06-08-2019, 06:41 | #44 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | LYF LS-4503 Recover WIth Great Umt Tool Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM70) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LYF LS-4503 [msm8909] Software : LS-4503-S10A_LYF_L11EN_210_160115, fd9d8f9 [Mon Feb 20 10:03:20 CST 2017] Android Ver. : 5.1.1 Patch Level : 2016-08-01 USERDATA : Normal You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.2 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM70) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LYF LS-4503 [msm8909] Software : LS-4503-S10A_LYF_L11EN_210_160115, fd9d8f9 [Mon Feb 20 10:03:20 CST 2017] Android Ver. : 5.1.1 Patch Level : 2016-08-01Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.2 |
06-12-2019, 06:47 | #45 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | ASUS_X00TD Frp Reset Done With Great Umt Tool Code: Port : ADB Interface Baud Rate : Not Applicable Device : Generic Operation : Motorola FRP Reset Searching for Device... Found Model : ASUS_X00TD Version : 8.1.0 Hardware : qcom Baseband : 660_GEN_PACK-1.163573.0.166136.1 SIM Card : ABSENT,ABSENT CPU : arm64-v8a Type : Unknown MEID(1) : Null/Empty Root : Not Rooted Resetting FRP Lock... Done Operation Finished. Elapsed Time: 00:06 [Module Ver. 5.3] Log Saved to Logs\190612_111453.log Last edited by UnlockwithCode; 06-12-2019 at 06:55. |
