07-23-2021, 13:03 | #241 (permalink) |
No Life Poster Join Date: Jul 2013 Location: ROGER/BELL/TELUS/NTT/AU KDDI Age: 38
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Tecno kb2 frp reset done with great umt king Code: Brand : Tecno Model : KB2 Operation : Reset FRP Connection Mode : Preloader Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM26) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : TECNO Manufacturer : TECNO MOBILE LIMITED Model : TECNO KB2j Prod. Name : H613 Device : TECNO-KB2j Build Date : Fri Jul 26 14:25:03 CST 2019 Build Flavor : full_kb2_h613-user Build Desc. : full_kb2_h613-user 8.1.0 O11019 1564122330 release-keys Android Ver. : 8.1.0 Display ID : KB2j-H613G-O-190726V127 Patch Level : 2019-08-05 Board : TECNO-KB2j Platform : mt6761 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.1] |
07-23-2021, 13:05 | #242 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Samsung a107f frp reset done with great umt king Code: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM5 Port Name: MediaTek PreLoader USB VCOM_V1632 (Android) (COM5) Path: \\?\usb#vid_0e8d&pid_2000#5&212ac8fc&0&7#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Preloader Mode Detected, Trying to crash... - Success! Port: COM6 Port Name: MediaTek USB Port_V1632 (COM6) Path: \\?\usb#vid_0e8d&pid_0003#5&212ac8fc&0&7#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM6) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : samsung Manufacturer : samsung Model : SM-A107F Prod. Name : a10sxx Device : a10s Build Date : Tue Jan 21 21:19:18 KST 2020 Build Flavor : a10sxx-user Build Desc. : a10sxx-user 9 PPR1.180610.011 A107FXXU5ATA9 release-keys Android Ver. : 9 Display ID : PPR1.180610.011.A107FXXU5ATA9 Patch Level : 2020-01-01 Platform : MT6765 Board : S96116AA1 Platform : mt6765 Platform : MT6765 Board : S96116AA1 Platform : mt6765 Userdata is NOT ENCRYPTED Formatting Userdata... - Success! Seeking FRP Data... Resetting FRP... - Success! - Resetting FRP[2]... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.3] |
07-23-2021, 13:06 | #243 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Itel a44 frp reset done with great umt king Code: Brand : iTel Model : A44 Operation : Reset FRP Connection Mode : Preloader Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM13) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : Itel Manufacturer : itel Model : itel A44 Prod. Name : F3706 Device : itel-A44 Build Date : Fri Aug 9 11:35:01 CST 2019 Build Flavor : A44-user Build Desc. : A44-user 7.0 NRD90M 1565321702 release-keys Platform : mt6737m Android Ver. : 7.0 Display ID : A44-F3706-7.0-OP-V042-20190809 Patch Level : 2019-08-05 Data missing! Could not read extended information! Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.3] |
07-23-2021, 13:11 | #244 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Samsung j200g frp reset done with great umt king Code: Brand : Samsung Model : J200G Operation : Reset FRP Searching for Phone...Found Port: : COM6 : SAMSUNG Mobile USB Modem #2 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : LSI3475 [HiSpeed] Loading Data...OK Resetting FRP Data...OK Closing Session...Done ---------------- IMPORTANT ---------------- Wait for phone to turn on completely. goto Menu > Settings > Backup and Reset and do Factory data Reset. Operation Finished. UltimateFRP Ver. 0.5 |
10-13-2021, 08:54 | #245 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Code: Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... No existing META port found. Connect powered off phone... Make sure to leave Buttons as soon as phone is detected. Found MediaTek USB Port (COM17) on COM17 Device Path : \\?\usb#vid_0e8d&pid_0003#5&212ac8fc&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Mode : BROM Rebooting to META mode... Waiting for phone in META mode... Found USB Serial Device (COM33) on COM33 Device Path : \\?\usb#vid_22d9&pid_0006#5&212ac8fc&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Configuring Communication Channel... Reading phone information... Failed to read META data! CPU : MT6893 SW Ver. : MOLY.NR15.R3.TC16.PR3.SP.V1.P28 HW Ver. : OPPO_K6893V1_64_HW Brand: OPPO Model: CPH2249 Name: OPPO Reno6 Pro 5G Platform: MT6893 OEM Prod.: CPH2249 OEM Device: OP4F81 Build Date: Mon Jun 7 03:35:56 CST 2021 Display ID: CPH2249_11_A.11 OTA Version: CPH2249_11.A.11_0110_202106072201 Patch Level: 2021-06-05 Starting Safe Factory Reset... Reset Success Operation finished If META method does not work, try Format FS in BROM mode. [UltimateMTK Ver. 4.4] Last edited by Fast Unlocking; 10-13-2021 at 12:41. |
The Following 2 Users Say Thank You to UnlockwithCode For This Useful Post: |
12-03-2021, 07:58 | #246 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | oppo a5s pattern remove with great umt king Code: Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... Found MediaTek USB VCOM (Android) (COM41) on COM41 Device Path : usb\vid_0e8d&pid_200e&rev_0409&mi_01 Configuring Communication Channel... Reading phone information... CPU : MT6765 SW Ver. : MOLY.LR12A.R2.TC16.SP.V50.5.P97 HW Ver. : OPPO_O1MP6_K65V1_64_BSP_HW Brand: OPPO Model: CPH1909 Name: unknown Platform: unknown OEM Prod.: CPH1909 OEM Device: unknown Build Date: Fri Mar 19 19:50:28 CST 2021 Display ID: CPH1909EX_11_A.46 OTA Version: CPH1909EX_11.A.46_0460_202103191930 Patch Level: 2021-04-05 Starting Safe Factory Reset... Reset Success Operation finished If META method does not work, try Format FS in BROM mode. [UltimateMTK Ver. 4.6] |
12-03-2021, 08:40 | #247 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | spice f302 frp reset done with great umt king Code: Brand : Spice Model : F302 Operation : Reset FRP Connection Mode : Preloader Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM50) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Brand : newspice Manufacturer : Spice Model : Spice F302 Prod. Name : F302 Device : Spice_F302 Build Date : Thu Jun 29 00:19:58 CST 2017 Build Flavor : F302-user Build Desc. : F302-user 7.0 NRD90M 1498666799 release-keys Platform : mt6737m Android Ver. : 7.0 Display ID : F302-I371-7.0-OP-V035-20170628 Patch Level : 2017-06-05 Data missing! Could not read extended information! Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.5] |
12-09-2021, 12:41 | #248 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | vivo y15 Pattern Lock Remove Without Data Loss With Great Umt King Code: Brand : Vivo Model : Y15 Operation : Reset Locks (Vivo) Connection Mode : Preloader Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM50) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Brand : vivo Manufacturer : vivo Model : vivo 1901 Prod. Name : PD1901BF_EX Device : PD1901BF_EX Build Date : Wed Oct 28 18:03:34 CST 2020 Build Flavor : full_k62v1_64_bsp-user Build Desc. : full_k62v1_64_bsp-user 9 PPR1.180610.011 compiler10281757 release-keys Android Ver. : 9 Display ID : PPR1.180610.011 release-keys Patch Level : 2020-09-01 Platform : MT6765 Board : k62v1_64_bsp Platform : mt6765 Userdata is ENCRYPTED Resetting Locks... Reset done --- IMPORTANT --- - Disconnect phone and hold Volume UP + Power to enter Fastboot. - Press Volume Down to select Recovery and press Power Button. - Wait for phone to start. [UltimateMTK Ver. 4.6.3] |
12-14-2021, 06:05 | #249 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Vivo Y20 Pattern Remove Done 1 Click With Great Umt King Code: Model : Y20 (PD2034F) Operation : Erase Userdata Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM52) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1601300 [SDM460] 03007300 OPK_DATA : F754F13EE91BF54295CA1FBD64D182067440B35FC41B798A539670EA259771BA Initializing Protocol...OK Preparing Loader...Done Sending Loader [PD2034F]...Done Executing Loader...OK Initiazling Storage...OK Read : Protected Write : Protected Alt. Write : Blocked Erasing Userdata...Done Operation Finished. QcFire Ver. 7.4 |
The Following User Says Thank You to UnlockwithCode For This Useful Post: |
