06-24-2020, 14:43 | #91 (permalink) |
No Life Poster Join Date: Jul 2013 Location: ROGER/BELL/TELUS/NTT/AU KDDI Age: 38
Member: 1981870 Status: Offline Thanks Meter: 16,502 | OPPO A33f Pattern Lock Remove Done With Great Umt King Code: Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, eMMC, 16 GB LU Count : 1 [0x01D1F000] Payload Info : In: 262144 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO A33f [msm8916] [A33] Software : A33fEX_11_170531, eng.root.20170531 [Wed May 31 19:14:23 CST 2017] Android Ver. : 5.1.1 Patch Level : 2017-04-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 5.6 |
The Following User Says Thank You to UnlockwithCode For This Useful Post: |
06-24-2020, 14:44 | #92 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Samsung J200G Flash Done With Great Umt King Code: Model : Samsung Universal Operation : Flash Searching for Phone...Found Port: : COM14 : SAMSUNG Mobile USB Modem #2 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : LSI3475 [HiSpeed] Sending Partition [BOOTLOADER]...Done Sending Partition [BOOT]...Done Sending Partition [RECOVERY]...Done Sending Partition [SYSTEM]...Done Sending Partition [RADIO]...Done Sending Partition [CACHE]...Done Sending Partition [HIDDEN]...Done Closing Session...Done Operation Finished. Elapsed Time 02:44 Module Ver. 0.2 LOG Saved to !Logs\200619_143821.log |
06-24-2020, 14:45 | #93 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Micromax HS2 Pattern Lock Remove Done WIth Great Umt King Code: Device : Micromax HS2 Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 05770000 OPK_DATA : FD40BBCA56D6976B0F75F3FED2267721F5AE7166CE06C2F0C237334FFA38A8DC Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_004]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Micromax Micromax HS2 [msm8937] [HS2] Software : MMX_HS2_SW_V6_HW_V1.0_08292017, 1504060315 [Wed Aug 30 10:31:53 CST 2017] Android Ver. : 7.1.2 Patch Level : 2017-07-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 5.6 Device : Micromax HS2 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 05770000 OPK_DATA : FD40BBCA56D6976B0F75F3FED2267721F5AE7166CE06C2F0C237334FFA38A8DC Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_004]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Micromax Micromax HS2 [msm8937] [HS2] Software : MMX_HS2_SW_V6_HW_V1.0_08292017, 1504060315 [Wed Aug 30 10:31:53 CST 2017] Android Ver. : 7.1.2 Patch Level : 2017-07-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 5.6 |
06-24-2020, 14:48 | #94 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Xiaomi Redmi 5 Plus Reset Mi Account/Reset FRP Done With Great Umt King Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 Plus [msm8953] [vince] Software : ZQL1711-vince-build-20191108142512, V11.0.2.0.OEGMIXM [Fri Nov 8 14:24:59 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-10-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 5.6 Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 Plus [msm8953] [vince] Software : ZQL1711-vince-build-20191108142512, V11.0.2.0.OEGMIXM [Fri Nov 8 14:24:59 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-10-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 5.6 Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 Plus [msm8953] [vince] Software : ZQL1711-vince-build-20191108142512, V11.0.2.0.OEGMIXM [Fri Nov 8 14:24:59 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-10-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 5.6 |
06-24-2020, 14:49 | #95 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Xiaomi Redmi 5 Plus Again Pattern Lock/Frp Done With Great Umt King Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 Plus [msm8953] [vince] Software : ZQL1711-vince-build-20191108142512, V11.0.2.0.OEGMIXM [Fri Nov 8 14:24:59 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-10-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 5.6 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 Plus [msm8953] [vince] Software : ZQL1711-vince-build-20191108142512, V11.0.2.0.OEGMIXM [Fri Nov 8 14:24:59 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-10-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 5.6 |
06-25-2020, 09:01 | #96 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Samsung J210F Reset FRP (New Method) Done With Great Umt King Code: Device: Samsung Device Operation: Reset FRP (New Method) Port: COM14 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:14 [Ultimate Samsung Flasher v1.5] |
The Following 2 Users Say Thank You to UnlockwithCode For This Useful Post: |
06-27-2020, 07:27 | #97 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Oppo A71 (CPH1801) Pattern Lock Remove Done With Great Umt King Code: Device : Oppo A71 (CPH1801) Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 557BAC65705B8A8303276B9FBB8FD533DBB33EA9E55BF80B47647B8549C170B9 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_015]...Done Executing Loader...OK Formatting Userdata...Done Disconnect phone and hold Power Button to reset. Operation Finished. QcFire Ver. 5.6 |
06-27-2020, 07:36 | #98 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Samsung J200G Frp Reset Done With Great Umt King Code: Device: Samsung Device Operation: Reset FRP (New Method) Port: COM14 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI3475 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:13 [Ultimate Samsung Flasher v1.5] |
06-27-2020, 07:38 | #99 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | itel S41 Reset FRP Done With Great Umt King Code: Brand : iTel Model : S41 Operation : Read Info Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Itel Manufacturer : itel Model : itel S41 Prod. Name : S41 Device : itel_S41 Platform : mt6737m Android Ver. : 7.0 Display ID : S41-I373-7.0-OP-V052-20180518 Patch Level : 2018-05-05 Userdata is NOT ENCRYPTED Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.0] Brand : iTel Model : S41 Operation : Reset FRP Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Itel Manufacturer : itel Model : itel S41 Prod. Name : S41 Device : itel_S41 Platform : mt6737m Android Ver. : 7.0 Display ID : S41-I373-7.0-OP-V052-20180518 Patch Level : 2018-05-05 Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.0] |
06-27-2020, 07:56 | #100 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Samsung J200G Recover Done With Great Umt King Code: Model : Samsung Universal Operation : Flash Searching for Phone...Found Port: : COM14 : SAMSUNG Mobile USB Modem #2 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : LSI3475 [HiSpeed] Sending Partition [BOOTLOADER]...Done Sending Partition [BOOT]...Done Sending Partition [RECOVERY]...Done Sending Partition [SYSTEM]...Done Sending Partition [RADIO]...Done Sending Partition [CACHE]...Done Sending Partition [HIDDEN]...Done Closing Session...Done Operation Finished. Elapsed Time 02:47 Module Ver. 0.2 LOG Saved to !Logs\200627_122444.log |
07-01-2020, 08:05 | #101 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Xiaomi Redmi 4A Reset Mi Account/Reset FRP Done With Great Umt King Code: Device : Xiaomi Redmi 4A Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D5A000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4A [msm8937] [rolex] Software : N2G47H, V10.2.3.0.NCCMIXM [Wed Jun 5 18:30:47 WIB 2019] Android Ver. : 7.1.2 Patch Level : 2018-07-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 5.6 Device : Xiaomi Redmi 4A Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D5A000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4A [msm8937] [rolex] Software : N2G47H, V10.2.3.0.NCCMIXM [Wed Jun 5 18:30:47 WIB 2019] Android Ver. : 7.1.2 Patch Level : 2018-07-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 5.6 Device : Xiaomi Redmi 4A Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D5A000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4A [msm8937] [rolex] Software : N2G47H, V10.2.3.0.NCCMIXM [Wed Jun 5 18:30:47 WIB 2019] Android Ver. : 7.1.2 Patch Level : 2018-07-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 5.6 |
07-01-2020, 12:42 | #102 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Y83 Pro Reset FRP Done With Great Umt King Code: Brand : Vivo Model : Y83 Pro Operation : Reset FRP Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : vivo Manufacturer : vivo Model : vivo 1726 Prod. Name : PD1803F_EX Device : PD1803F_EX Android Ver. : 8.1.0 Display ID : O11019 release-keys Patch Level : 2019-11-05 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.0] |
07-02-2020, 10:25 | #103 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Vivo y51l imei repair done with great umt king Code: Port : COM10 : Qualcomm HS-USB Diagnostics 9025 (COM10) Baud Rate : 921600 Device : Vivo Qualcomm Operation : Repair IMEI Opening Port... OK Reading Phone Information... OK Compile : Dec 1 2017 16:32:49 Release : Jul 06 2016 23:00:00 Hw Ver. : EAAAANUZ Build : MPSS.DPM.2.0.2.c1.3-00039-M8936FAAAANUZM-1.58085.1.62764.1 IMEI [1] : 865407010000009 IMEI [2] : 865407010000009 MEID : A10000XXXXXXXXX Writing IMEI 1 [86285XXXXXXXXXX]... Done Writing IMEI 2 [86285XXXXXXXXXX]... Done Rebooting Phone... Done Please reboot maunally if does not reboot automatically. Operation Finished. Elapsed Time: 00:02 [Module Ver. 5.5] Log Saved to Logs\200702_145109.log |
07-02-2020, 15:20 | #104 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Xiaomi Redmi Note 5A Reset Mi Account Done With Great Umt King Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5A [msm8937] [ugg] Software : N2G47H, V8.5.1.0.NDKMIED [Wed Sep 27 22:59:13 CST 2017] Android Ver. : 7.1.2 Patch Level : 2017-09-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 5.6 Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5A [msm8937] [ugg] Software : N2G47H, V8.5.1.0.NDKMIED [Wed Sep 27 22:59:13 CST 2017] Android Ver. : 7.1.2 Patch Level : 2017-09-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 5.6 |
07-06-2020, 12:22 | #105 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Realme C1 1811 Pattern Lock Remove Done With Great Ultimate Emmc Umt King Last edited by Unlockinfo; 07-07-2020 at 04:29. Reason: Pic Adjust |
