04-08-2010, 14:14 | #3646 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Software engine version: 1.0.0.3884 Searching phone ... MODEL : CU720 COMPILED DATE : Mar 26 2008 12:40:00 RELEASE DATE : Oct 3 2007 23:00:00 FIRMWARE INFO : CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US IMEI : 01148700275598-7 BLUETOOTH ADDR : C3 A5 6C 6B 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:05 |
04-08-2010, 14:42 | #3647 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | T156 ay done HERE IS LOG Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081033522437 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_P1.2PU01V01.01_353081033522437_16.14.49_08. 04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:44 |
04-08-2010, 14:54 | #3648 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Software engine version: 1.0.0.3884 Searching phone ... MODEL : U900 COMPILED DATE : Nov 13 2006 15:43:00 RELEASE DATE : Nov 13 2006 12:00:00 FIRMWARE INFO : U900-MSM6250A-V11e-NOV-13-2006-H3G-IT IMEI : 35930400291634-7 BLUETOOTH ADDR : DD E7 3C 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35930400291634700 BLUETOOTH ADDR: [OK] DDE73C561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:38 |
04-08-2010, 15:13 | #3649 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Huawei T156 unlocked \ Connect phone powered on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034820459 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_P1.2PU02V01.01_353081034820459_19.12.49_08. 04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:07 |
04-08-2010, 16:35 | #3650 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | t156 done here is log Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038178805 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_P1.2PU03V01.01_353081038178805_20.22.51_08. 04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:55 |
04-08-2010, 16:52 | #3651 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Huawei G1157 unlocked Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039089936 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039089936_20.50.53 _08.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:50 |
04-08-2010, 19:22 | #3653 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | BB 8520 unlock done Searching for usb device ... Reading info ... IMEI: 358472031****** Calculating ... MEP: MEP-07723-005 MEP2 CODE: 2206469172219336 MEP3 CODE: 8293597779232018 MEP4 CODE: 4311873058907637 MEP5 CODE: 1445653908418022 MEP6 CODE: 7225173507489500 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:52 |
04-09-2010, 10:22 | #3654 (permalink) |
No Life Poster Join Date: Mar 2007 Location: /Fr/Ch\Ro\ Age: 39
Member: 467911 Status: Offline Thanks Meter: 351 | BB 8220 Belgique Searching for usb device ... Reading info ... IMEI: 356*********** Calculating ... MEP: MEP-04103-001 MEP2 CODE: 8734089208007398 MEP3 CODE: 4380410881488517 MEP4 CODE: 2376005393213742 MEP5 CODE: 6653955846914250 MEP6 CODE: 1738136555305676 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:49 free1600 |
04-09-2010, 10:23 | #3655 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | g1157 done here is log Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039416378 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039416378_19.02.28 _08.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:46 |
04-09-2010, 12:07 | #3659 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | Huawei U5700 (b-mobile) Unlock DONE !! using HUAWEI module pack 2 ================================================= Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00EC:0078 Nand init done; Reading; Imei : 35795501028844-1 Reading; SP saved to: SP_35795501028844_649_18.03.35_09.04.2010_HUAWEI.b in Erasing; Writing; Unlocked ! Done ! Time needed - 00:00:27 |
04-09-2010, 12:07 | #3660 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | G1157 done HERE IS LOG Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334037116103 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334037116103_20.05.41 _08.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:44 |
