04-16-2021, 07:49 | #46 (permalink) | |
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Update dongle with Infinity DongleManager.exe OR 1. Insert Infinity Smart-Card into another Card-Reader (dongle or box). Good result gives Alcor Card-Reader - - 2. Update dongle with Infinity DongleManager.exe | |
04-17-2021, 10:43 | #47 (permalink) |
Major Poster Join Date: Jul 2016
Member: 2599500 Status: Offline Thanks Meter: 6 | Probably last attempt was interrupted or wrong Smart-Card connected. === DongleManager [Infinity] v1.81 [17/04/2021 10:27:20] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: FT SCR2000 0 HWID: 0000CCE018434082 === Process started: 17/04/2021 10:27:20 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
04-17-2021, 11:12 | #48 (permalink) | |
04-17-2021, 14:57 | #49 (permalink) | |
Junior Member Join Date: May 2008 Location: Morocco
Member: 779949 Status: Offline Thanks Meter: 0 | hello please solve this problem.. Quote:
04-17-2021, 16:39 | #50 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, 1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Update dongle with Infinity DongleManager.exe OR 1. Insert Infinity Smart-Card into another Card-Reader (dongle or box). Good result gives Alcor Card-Reader - - 2. Update dongle with Infinity DongleManager.exe |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
04-17-2021, 18:39 | #51 (permalink) | |
Member: 779949 Status: Offline Thanks Meter: 0 | I have win 10 64b, sme error Quote:
04-18-2021, 11:36 | #53 (permalink) |
Junior Member Join Date: Dec 2009 Location: Rajakhera, Dholpur, Rajasthan
Member: 1176693 Status: Offline Thanks Meter: 10 | === DongleManager [Infinity] v1.81 [18-04-2021 16:04:13] === Box/Dongle type selected: Infinity [BEST] Card-Reader: FT SCR2000 0 HWID: 0009748418201292 === Process started: 18-04-2021 16:04:13 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 pls help me |
04-18-2021, 12:25 | #54 (permalink) | |
04-19-2021, 16:05 | #55 (permalink) |
Junior Member Join Date: Oct 2015 Location: UA
Member: 2479810 Status: Offline Thanks Meter: 1 | help please, dongle misconfiguration === DongleManager [Infinity] v1.81 [Пн 19.04.21 18:04:54] === Box/Dongle type selected: Infinity [BEST] Card-Reader: FT SCR2000 0 HWID: 01046983147D1292 Box/Dongle found: Infinity [BEST] Reading... Serial No (S/N): 62A16983 Firmware version: 0122.02 === Process started: Пн 19.04.21 18:04:57 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
04-19-2021, 18:54 | #56 (permalink) |
Freak Poster Join Date: May 2007
Member: 501877 Status: Offline Thanks Meter: 495 | Server answer:[0031] Dongle identification data damaged. === DongleManager [Infinity] v1.81 [19.04.2021 20:49:27] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000D8CCFF021982 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 0DEAD8CC Firmware version: 0147.02 === Process started: 19.04.2021 20:49:30 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 I use vb.net only on the home pc, it makes this error twice, I definitely do not use a sharing program. my card full actived => Activations: - 00: Infinity-Box/Dongle [CM2] v0147 - 02: #2 v0122 - 03: Infinity [BEST] v0122 - 08: #8 - 0C: #12 - 0F: #15 => Options: - Infinity-Box/Dongle [CM2] - Infinity [BEST2] - gb-key - gb-key (activation) - grt - amt |
04-19-2021, 22:51 | #57 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: 1. Delete fault.bin file (if you have it in CM2 folder) 2. Install latest Infinity software updates 3. Run DongleManager 4. Update Dongle firmware | |
04-19-2021, 22:54 | #58 (permalink) | |
\microsoft visual studio 10.0\team tools\tracedebugger tools\intellitrace.exe now update dongle firmware | |
04-20-2021, 05:21 | #59 (permalink) |
Junior Member Join Date: Jul 2016 Location: Bulawayo, Zimbabwe
Member: 2593138 Status: Offline Thanks Meter: 9 | === DongleManager [Infinity] v1.81 [20/4/2021 06:17:34] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000A415217A4082 === Process started: 20/4/2021 06:17:34 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
04-20-2021, 08:29 | #60 (permalink) | |
Update it once again now | |
