Smart-Card/Dongle/Box update fixes and solutions Please post here Infinity Dongle or Infinity Smart-Card problem. - copy/paste ONLY TEXT - no pictures and/or video - DO NOT update your Smart-Card many times - you can kill Smart-Card Previous threads are HERE and HERE and HERE and HERE and HERE https://cdn.infinity-box.com/ico/tg48.png https://cdn.infinity-box.com/ico/yt48.png https://cdn.infinity-box.com/ico/fb48.png https://cdn.infinity-box.com/ico/fb48.png https://cdn.infinity-box.com/ico/tw48.png https://cdn.infinity-box.com/ico/discord48.png https://cdn.infinity-box.com/ico/ios2-48.png https://cdn.infinity-box.com/ico/j48.png https://cdn.infinity-box.com/ico/inst48.png https://cdn.infinity-box.com/ico/file-folder_48t.png |
smart card configuration mismatch CM2MT2 closed while trying EMI config to read info. === DongleManager [Infinity] v1.81 [30/03/2021 11:56:04] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00047873FF021982 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): 467F7873 Firmware version: 0145.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0145 => Activations: - 00: Infinity-Box/Dongle [CM2] v0145 - 03: Infinity [BEST] v0122 - 07: #7 => Options: - Infinity-Box/Dongle [CM2] - Infinity [BEST2] - Infinity SM |
Reboot PC Update dongle firmware after that Before run Infinity exe delete fault.bin file from CM2 folder (if any) |
=== DongleManager [Infinity] v1.80 [4/1/2021 15:19:55] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: GsmEasy S-Reader 0 HWID: 00001CF121F34082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 32EA1CF1 Firmware version: 0147.02 === Process started: 4/1/2021 15:19:56 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
1. Read NOTE - https://www.infinity-box.com/support/?s=2 https://cdn.infinity-box.com/card/error-66.jpg 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. 3. Update dongle with Infinity DongleManager.exe https://cdn.infinity-box.com/card/how-to-update.jpg 4. Delete fault.bin file (if you have it in CM2 folder) https://cdn.infinity-box.com/card/fault-bin.png 5. Run Infinity exe |
good team please Dongle identification data damaged Dongle identification data damaged. Dongle identification data damaged Dongle identification data damaged my dongle not work please helpe me === DongleManager [Infinity] v1.81 [01/04/2021 16:23:03] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000053121344082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): FD140531 Firmware version: 0147.02 === Process started: 01/04/2021 16:23:04 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
thank you good team my dongle go back successfully thank you good team my dongle go back successfully Quote:
=== DongleManager [Infinity] v1.81 [4/3/2021 12:40:52] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0001397F1F444082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): E898397F Firmware version: 0147.02 === Process started: 4/3/2021 12:40:53 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
i use my dongle on secondary laptop and then it is not working as showing "Smarcard M === DongleManager [Infinity] v1.80 [05/04/2021 21:33:57] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000354D176D4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 6F1D354D Firmware version: 0147.02 === Process started: 05/04/2021 21:33:59 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2" === DongleManager [Infinity] v1.80 [05/04/2021 21:40:33] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000354D176D4082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 6F1D354D Firmware version: 0147.02 Box/Dongle misconfiguration Diagnostic code: 62 "UK Edition" status: Off Last launched Application: 0030 v.0147 => Activations: - 00: Infinity-Box/Dongle v0147 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM Activation #0: Infinity-Box/Dongle [CM2]; S/N: 6F1D354D; Firmware Version: 0147; Registered: 28-May-2018; Expired: 11-May-2022; Support: Active i have not found any "fualt.bin" file in my any PC CM2 installation directory. |
Please upload file fault.bin to mega.nz and post link here. File is at /InfinityBox/CM2MT2/ or /InfinityBox/CM2SP2/ or /InfinityBox/BEST/ folder I suggest you restore file from recycle bin |
Found everywhere fault.bin in CM2 MT2 folder and CM2 SP2 or BEST2 also my PC's recycle bin is clear |
Please do as per this instruction step 7. now https://forum.gsmhosting.com/vbb/f29...t-run-2855041/ |
https://mega.nz/file/WuIxRYrJ#7IF_FB...oWv9ddjNaxa3GM |
