03-11-2019, 09:57 | #4021 (permalink) | |
Junior Member Join Date: Jul 2013 Location: Bangladesh
Member: 1979369 Status: Offline Thanks Meter: 7 | Quote:
Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0001398A1F444082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): E9B7398A Firmware version: 0137.02 "UK Edition" status: On Last launched Application: 0031 v.0127 => Activations: - 00: Infinity-Box/Dongle v.0137 please sir help me | |
03-11-2019, 11:57 | #4022 (permalink) |
Freak Poster Join Date: Nov 2009 Location: MOROCCO
Member: 1164285 Status: Offline Sonork: 100.1648187 Thanks Meter: 296 | === DongleManager [Infinity] v1.72 [11/03/2019 11:51:56] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0003A67118201292 Box/Dongle found: [BEST] Reading... Serial No (S/N): A543A671 Firmware version: 0122.02 === Process started: 11/03/2019 11:51:57 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 plaes unlock my dangle |
03-12-2019, 20:17 | #4023 (permalink) |
Insane Poster Join Date: Sep 2004 Location: Austria Linz Age: 42
Member: 83772 Status: Offline Thanks Meter: 22 | === DongleManager [Infinity] v1.72 [3/12/2019 20:14:08] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0005898B18201292 === Process started: 3/12/2019 20:14:08 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
03-13-2019, 07:30 | #4024 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Do you have any problem with it ? | |
03-13-2019, 07:35 | #4025 (permalink) | |
- Run DongleManager - Update Dongle firmware now IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
03-13-2019, 07:45 | #4026 (permalink) | |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
03-13-2019, 09:40 | #4027 (permalink) |
Insane Poster Join Date: Mar 2005 Location: Backi Petrovac
Member: 129300 Status: Offline Thanks Meter: 20 | HI Would you be kind enough to delete two old activations that I do not use to make room for new ones? I would like to delete: -Micro-Box -GB-Key -GB-Key (Activation) === DongleManager [Infinity] v1.72 [3/13/2019 09:27:36] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 6 HWID: 0001DFB0FF021982 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 0761DFB0 Firmware version: 0137.02 "UK Edition" status: Off Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v.0137 - 03: [BEST] v.0122 - 05: Content Extractor v.0122 - 06: #6 - 07: #7 - 08: #8 - 0D: #13 => External Activations: - SPT - Micro-Box - GB-Key - GB-Key (Activation) |
03-14-2019, 09:07 | #4028 (permalink) | |
It's no problem to remove it but we can not refund. Also I am not sure is it will be possible in future to re-activate it. Please confirm, do you really want to remove mentioned activations pernmanently ? Also your card is from year 2005, iit's 14 years old. it's really old card and nobody knows how long it will be alive. Probably best way to leave this old card "as is" and buy another new Infinity-Box/Dongle, it's much cheaper than box - https://www.infinity-box.com/price/ What is your final instruction ? | |
03-14-2019, 09:41 | #4029 (permalink) |
Member: 129300 Status: Offline Thanks Meter: 20 | I do not want a refund or reactivation of the mentioned ones. So you can freely delete them. The activations I want to delete: -Micro Box -GB-Key -GB-Key (Activation) And I would like to ask if there is a possibility to just replace the old one for a new smart card while staying with the existing activations and serial number of the card? Or how it goes? |
03-14-2019, 14:31 | #4031 (permalink) | |
waiting for your final instruction. | |
03-14-2019, 16:25 | #4033 (permalink) |
Junior Member Join Date: Nov 2003 Location: Timisoara Age: 49
Member: 43216 Status: Offline Thanks Meter: 2 | please help === DongleManager [Infinity] v1.72 [14-Mar-19 17:22:02] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0103746115BF1292 === Process started: 14-Mar-19 17:22:02 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
03-15-2019, 05:22 | #4034 (permalink) |
Junior Member Join Date: Dec 2016 Location: Uzbekistan_Bukhara_Kogon Age: 32
Member: 2667082 Status: Offline Thanks Meter: 0 | Hi infinity TEAM, Please help me. === DongleManager [Infinity] v1.72 [15.03.2019 9:09:30] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0101A87020881292 === Process started: 15.03.2019 9:09:31 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. |
