12-25-2010, 15:39 | #7501 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | samsung b-159 3rd unlock done module v1.41 Device: Samsung-SCH-B159 operation: DE-26 boot unlock (Force mode) Phone should be Switched ON ! connecting... samsung b159 boot mode... Patching in progress... patching done... Wait reconnecting for restart... Done... Phones should be restart now if not take out the battery... Finished, time used: 21 sec COM2 [VCP0] selected module v1.41 Device: Samsung-SCH-B159 operation: UART unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 24 sec |
The Following 2 Users Say Thank You to JINDALGSM™ For This Useful Post: |
12-25-2010, 15:44 | #7502 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | samsung b-159 4th unlock done COM24 [sacumdm0] selected module v1.41 Device: Samsung-SCH-B159 operation: DE-26 boot unlock (Force mode) Phone should be Switched ON ! connecting... samsung b159 boot mode... Patching in progress... patching done... Wait reconnecting for restart... Done... Phones should be restart now if not take out the battery... Finished, time used: 19 sec COM2 [VCP0] selected module v1.41 Device: Samsung-SCH-B159 operation: UART unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 24 sec |
12-25-2010, 15:47 | #7503 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | samsung b-159 5th unlock done COM24 [sacumdm0] selected module v1.41 Device: Samsung-SCH-B159 operation: DE-26 boot unlock (Force mode) Phone should be Switched ON ! connecting... samsung b159 boot mode... Patching in progress... patching done... Wait reconnecting for restart... Done... Phones should be restart now if not take out the battery... Finished, time used: 21 sec COM2 [VCP0] selected module v1.41 Device: Samsung-SCH-B159 operation: UART unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 24 sec |
The Following 3 Users Say Thank You to JINDALGSM™ For This Useful Post: |
12-25-2010, 15:53 | #7504 (permalink) |
Freak Poster Join Date: Jul 2005 Location: EGYPT/CAIRO Age: 43
Member: 162544 Status: Offline Thanks Meter: 17 | ==== log: [23/12/2010 03:45:33 م] ==== COM4 [VCP1] selected module v1.39 Device: LG-KP135 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 353955020489884 file saved: C:\Program Files\InfinityBox\LGA\eeprom_353955020489884_LG-KP135_20101223-154603.B1E.bin .... Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 30 sec Remove/Install battery now ! |
The Following User Says Thank You to mn4 For This Useful Post: |
12-25-2010, 15:54 | #7505 (permalink) |
Member: 162544 Status: Offline Thanks Meter: 17 | COM4 [VCP0] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" active "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 355995016450894 current otp imei: 355995016450621 file saved: C:\Program Files\InfinityBox\LGA\eeprom_355995016450894_LG-KG110_20101206-205835.B1E.bin ........ version: 602-03V10b20KG110P40 Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) calibration area skipped flash: 01227E22212200:FEEA0000000000 flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 57 sec Remove/Install battery now ! |
12-25-2010, 15:55 | #7506 (permalink) |
Member: 162544 Status: Offline Thanks Meter: 17 | module v1.78 Device: LG-GB102 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +3 j Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20100929-183526.B1E.bin loading data... data loaded imei: 35399903721050300 reading eeprom-security_35399903721050300... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903721050300_20100929-183528.B1E.bin reading eeprom-complete_35399903721050300... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903721050300_20100929-183529.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 22 sec Remove/Install battery now ! |
12-25-2010, 15:55 | #7507 (permalink) |
Member: 162544 Status: Offline Thanks Meter: 17 | COM4 [VCP0] selected module v1.78 Device: LG-KE970 Checking data, wait... Action: write flash write: Firmware KE970P40-ARB-V10h-XXX-XX_AUG-01-2007_firmware.B1M.bin skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack write: FFS-2/File system KE970P40-ARB-V10h-XXX-XX_AUG-01-2007_file_system.B1S.bin skip: Eeprom Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static_20101002-161928.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static2_20101002-161928.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-security_35030526000000100_20101002-161930.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20101002-161931.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Write Done Finished, time used: 31 min 0 sec Remove/Install battery now ! |
12-25-2010, 15:56 | #7508 (permalink) |
Member: 162544 Status: Offline Thanks Meter: 17 | COM4 [VCP2] selected module v1.78 Device: SFR-227 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -EG-P108B1V1.0.0B05 VDF-P108B1B03-FrPtAr-EG08 g3xAV3.0 May 20 20 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\SFR-227_eeprom-static_20101003-170736.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\SFR-227_eeprom-security_20101003-170738.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\SFR-227_eeprom-complete_20101003-170740.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\SFR-227_lock-area_20101003-170742.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 29 sec Remove/Install battery now ! |
12-25-2010, 15:57 | #7509 (permalink) |
Member: 162544 Status: Offline Thanks Meter: 17 | COM4 [VCP0] selected module v1.78 Device: ZTE-225 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -EG-P108A2V1.0.0B07 19 20 11 VDF-P108A2B06-ArFr-EG04 g3dBV2.0 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-static_20101004-130126.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-security_20101004-130129.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-complete_20101004-130131.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_lock-area_20101004-130134.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 41 sec Remove/Install battery now ! |
12-25-2010, 16:31 | #7510 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | read/check information success Code: COM17 [VCP1] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8D03:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE500908A0400009FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.49F08FAF.[AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23.BIN_BD6390C1].rpl rom info detection finished device-id: 49F08FAF rom info ver: 04 sw version: AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23.BIN project-id: A11+_V07.12.52.H23, C19063BD code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00C00000 standard ffs/eeprom offset confirmed: 00C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00C00000-00FFFFFF firmware area: 00000000-00BFFFFF detecting ffs/eeprom structure pass 1... ................... ffs/eeprom: detect std location pass #1... ......................................... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23.BIN detecting firmware build... ......................................... firmware date/time: 2008-01-11 11-58 hw1: AHONG25_06B_HW done detecting product-id... ................................................................ done detecting languages... ............................. language parameters detected detected languages: En file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23__system_log_49F08FAF_BD6390C1_20101010-172250.B0X.bin Finished, time used: 3 min 36 sec Remove/Install battery now ! Loading file v.02... backup_flash[AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23.BIN]_20080530-120611.B0M.bin loaded usb bootloader (file) is absent rom info ver: 04 sw version: AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23.BIN project-id: A11+_V07.12.52.H23, C19063BD code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2008-01-11 11-58 hw1: AHONG25_06B_HW Last edited by alamgir80; 12-25-2010 at 16:39. |
The Following User Says Thank You to alamgir80 For This Useful Post: |
12-25-2010, 16:32 | #7511 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | Dead repair success Code: COM32 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8FA2:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.5ACE2513.[JRDSZ23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.F271A0_DZ_JT47_091026_02.BIN_50697760].rpl ==================== New firmware found (v.3.24, database date: 01.10.2010): JRDSZ23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.F271A0_DZ_JT47_091026_02.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 5ACE2513 rom info ver: 05 sw version: JRDSZ23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.F271A0_DZ_JT47_091026_02.BIN project-id: F271A0.DZ.JT47.091026.02, 60776950 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: JRDSZ23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.F271A0_DZ_JT47_091026_02__ffs... file saved: C:\Users\AlaM\Desktop\JRDSZ23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.F271A0_DZ_JT47_091026_02__ffs_20101009-115744.B0E.bin flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFF0043:2088C400000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\JRDSZ23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.F271A0_DZ_JT47_091026_02__system_log_5ACE2513_50697760_20101009-115904.B0X.bin Finished, time used: 5 min 45 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-26-2010, 05:58 | #7512 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Haier C5000 unlocked --------------------------------------------------------- HARDWARE : HA5000MV COMPILE : Mar 12 2009 (17:33:26) REALEASE : Dec 18 2006 (19:00:00) SW Version : HA5000MV06 Haier C5000 --------------------------------------------------------- Phonce code : 0000 Finished, time used: 3 sec HA5000MV06 Haier C5000 version 06 selected.. Sending command... patching in progress... Done... Phones should be restarting now... Finished, time used: 13 sec |
The Following 3 Users Say Thank You to akashub For This Useful Post: |
12-26-2010, 08:38 | #7513 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM6 [VCP0] selected module v3.25 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:C603:0009 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BV_C001_1_0836_MP_V6 Version: HEXING25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35701300233809 connection Ok detecting structure #1... 1 5 6 8 9 10 12 13 14 done 178 byte(s) read 166 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 2255 Finished, time used: 15 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
12-26-2010, 10:34 | #7514 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | COM2 [VCP1] selected module v1.78 Device: Zong-A136 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check parameters Done backup critical area ... reading eeprom-static... file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20101210-171313.B1E.bin loading data... data loaded reading eeprom-security... file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20101210-171314.B1E.bin reading eeprom-complete... file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20101210-171316.B1E.bin reading additional data... file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20101210-171319.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 26 sec Remove/Install battery now ! |
The Following User Says Thank You to c_ahmad79 For This Useful Post: |
12-26-2010, 10:47 | #7515 (permalink) |
Freak Poster Join Date: Jan 2010 Location: MX-KEY is the BEST NOKIA TOOL
Member: 1217818 Status: Offline Thanks Meter: 31 | NOKIA 2700c DEAD uSB FLASHING SUCESS Files Set for Flashing : MCU : rm561__09.95.mcusw PPM : rm561__09.95.ppm_ssa_h CNT : rm561__09.95.image_ssa_h_blac Flashing phone now... Check files done... -> SWversion check skipped : UserIni mode selected Backup CRT308 data... CRT308 Backup Created... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\Program Files\Best_v1.09\Best\Backup\Cert\358262035888167. rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 0C3000193E0068502008853DE8789BFDAAFFFC60 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: 3EA22A1DDA660002E56108DB5072A10F8709443F Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm561__09.95.image_ssa_h_blac ConvertImage: Page Size is 128K, no need convert Loader len: 308032, CHK: FFA3 ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm561__09.95.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:50 Write : Processing rm561__09.95.mcusw Total 1256 [1256/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:59 MCU Write done ===Flashing [PPM]=== Erase : Processing rm561__09.95.ppm_ssa_h Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:11 Write : Processing rm561__09.95.ppm_ssa_h Total 326 [326/0/0] blocks to write, writing... TIME : Write time : 00:00:15 PPM Write done ===Flashing [CNT]=== Erase : Processing rm561__09.95.image_ssa_h_blac Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:06:31 Write : Processing rm561__09.95.image_ssa_h_blac Total 568 [568/0/0] blocks to write, writing... TIME : Write time : 00:00:27 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:12:16 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.95 02-04-10 RM-561 (c) Nokia IMEI: 358262035888167 PPM version : V 09.95 02-04-10 RM-561 (c) Nokia SSA Product code: 0579811 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:13:15 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following 2 Users Say Thank You to kills For This Useful Post: |
