09-28-2011, 16:20 | #14341 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO Phone found! Series 40 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone detected , SP_CODE_LEN : 15 Done! Core version : 1.29 Rev : 1.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm561__09.98.image_ctv_au_black Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.29\Backup\Cert\3519 94041649608_SIM.rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 23500110D1AE4950A88E2B632A49D1676A921C6A CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: 3EA22A1DDA660002E56108DB5072A10F8709443F Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm561__09.98.image_ctv_au_black ConvertImage: Page Size is 128K, no need convert Loader len: 308032, CHK: 0549 ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm561__09.98.image_ctv_au_black Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:18 Write : Processing rm561__09.98.image_ctv_au_black Total 696 [696/0/0] blocks to write, writing... TIME : Write time : 00:00:44 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:04:03 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.98 06-09-10 RM-561 (c) Nokia IMEI: 351994041649608 PPM version : V 09.98 06-09-10 RM-561 (c) Nokia T Product code: 0579321 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Done! Elapsed: 00:04:55 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
09-28-2011, 20:56 | #14342 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | My first Infineon 1800 phone unlocked using BEST. Hash was reade with BEST tool. Anyhow it was one of the hardest to find code at 91%. Thanks for great work. Looking for improvements to this software so that it will be the really BEST for Nokia. 9ea136362dd4d09628ac0877b21cb125da04c602:003548570 436191400:020009070203010801060209060109 |
The Following User Says Thank You to byteforce For This Useful Post: |
09-28-2011, 23:25 | #14343 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Ganimedes
Member: 1067814 Status: Offline Sonork: 100.1618982 Thanks Meter: 82 | COM6 [VCP0] selected module v4.01 Action: "sp-unlock" unlock method: smart fast Model: ZTE-A261 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0103:0003 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: ES-DM-CLARO-P103B9LFV1.0.1B02 Version: ES-DM-CLARO-P103B9LFV1.0.1B02 44 byte(s) read imei: 35803402067317 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
09-29-2011, 00:19 | #14344 (permalink) |
Member: 1067814 Status: Offline Sonork: 100.1618982 Thanks Meter: 82 | COM6 [VCP0] selected module v4.01 Device: Alcatel-508A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:99C0:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.E9E64302 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_21A5C110].rpl ==================== New firmware found (v.4.01, database date: 19.08.2011): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E9E64302 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 10C1A521 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 36J provider: 508A-2ARGDO3 customization: CP36NB10 customization: XP36NB10 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP36NB10 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->08749954 ..................security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 file saved: c:\InfinityBox\MModule\backup_security\Alcatel-508A__system_log_E9E64302_21A5C110_20110928-191625.B0X.bin Finished, time used: 2 min 51 sec Remove/Install battery now ! |
09-29-2011, 00:26 | #14345 (permalink) |
Member: 1067814 Status: Offline Sonork: 100.1618982 Thanks Meter: 82 | COM6 [VCP0] selected module v4.01 Action: read unlock codes Model: Alcatel-508A Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:99C0:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: MAUI.08A.W08.36.SP1.V34 Version: JRD23_08A_HW 80 byte(s) read imei: 01207700676899 connection Ok 186 byte(s) read 38 byte(s) read Phone lock: On Phone code: 1222 174 byte(s) read reading data... warning: wrong packet cs 1898 byte(s) read warning: unknown lock version: 2A000500 error: operation failed ! Finished, time used: 17 sec Remove/Install battery now ! |
09-29-2011, 09:00 | #14346 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Bulgaria,Assenovgrad Age: 46
Member: 591325 Status: Offline Thanks Meter: 151 | COM6 [VCP0] selected module v3.95 Action: read unlock codes unlock method: read codes Model: ZTE-R221_16mb Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:557C:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: BG-MTEL-R9SM-P109A17V1.0.0B01 Version: ZTENJ23D_09A_HW ==================== New firmware found (v.3.95, database date: 20.06.2011): BG-MTEL-R9SM-P109A17V1.0.0B01 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei: 86853300403516 connection Ok 192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 180 byte(s) read reading data... 972 byte(s) read lock[1] code: + 333996275381 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 21 sec Remove/Install battery now ! |
09-29-2011, 10:24 | #14347 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core version : 1.29 Rev : 1.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-320_35.0.001_PR.C0R PPM : RM-320_35.0.001_PR.v22 CNT : RM320_31.0.002_025_zzz_U03_uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL2 Simlock read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.29\Backup\Cert\3595 42019228657_SIM.rpl Check communication with phone.... ADL Boot req Communication verify done... Preparing... Gathering phone info... RAP_BOOT: 0B01010302010000 RAP_PUBLIC: 0400010A43C901584D77FE50CD643DC4131F7920 CMT_ROOTKEY: CAEEBB65D3C48E6DC73B49DC5063A2EE RAP_PAPUBKEY: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 APE_ROOTKEY: BA8710A7E1CD5A2909B9A875DB27AA24 Check communication with phone... CMT Loader len: 214912, CHK: 6F71 Sending CMT boot.... APE Loader len: 1573888, CHK: 2831 Sending APE boot.... Boot done TIME : Boot time : 00:00:12 Reboot.... Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL Server confirm flashmode! ADL : Auth Ok ADL : ASIC CMT select Ok ADL : ASIC APE select Ok ===Flashing [MCU]=== Erase : Processing RM-320_35.0.001_PR.C0R Found 3 areas to erase Erasing area 0x00080000 - 0x007CF385, NOR, CMT Result: 0000 Erasing area 0x00000000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00880000 - 0x00FDFFFF, NOR, CMT Result: 0000 Found 8 areas to erase Erasing area 0x00000200 - 0x0000AFFF, NAND, APE Result: 0000 Erasing area 0x0000B800 - 0x000AFFFF, NAND, APE Result: 0000 Erasing area 0x00000000 - 0x00000FFF, NAND, APE Result: 0000 Erasing area 0x0000D800 - 0x0000E9FF, NAND, APE Result: 0000 Erasing area 0x00080000 - 0x000BFFFF, NAND, APE Result: 0000 Erasing area 0x000E0000 - 0x0045FFFF, NAND, APE Result: 0000 Erasing area 0x004C0000 - 0x0073FFFF, NAND, APE Result: 0000 Erasing area 0x00A40000 - 0x06F3FFFF, NAND, APE Result: 0000 Partitioning : Ok [5] TIME : Erase time : 00:01:46 Write : Processing RM-320_35.0.001_PR.C0R Total 441 [68/373/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] APE : Writing Hash CERT [X-LOADER] APE : Writing Hash CERT [KEYS] APE : Writing Hash CERT [PRIMAPP] APE : Writing Hash CERT [X-LOADER] APE : Writing Hash CERT [KEYS] APE : Writing Hash CERT [PRIMAPP] APE : Writing Hash CERT [SOS+XZIP] APE : Writing Hash CERT [PASUBTOC] APE : Writing Hash CERT [PAPUBKEYS] APE : Writing Hash CERT [SOS+UPDAPP] APE : Writing Hash CERT [SOS+CORE] APE : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:02:00 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-320_35.0.001_PR.v22 Found 1 areas to erase Erasing area 0x05140000 - 0x06F3FFFF, NAND, APE Result: 0000 Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-320_35.0.001_PR.v22 Total 71 [0/71/0] blocks to write, writing... APE : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:18 PPM Write done ===Flashing [CNT]=== Erase : Processing RM320_31.0.002_025_zzz_U03_uda.fpsx Found 1 areas to erase Erasing area 0x06F40000 - 0x0F87FFFF, NAND, APE Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM320_31.0.002_025_zzz_U03_uda.fpsx Total 145 [0/145/0] blocks to write, writing... TIME : Write time : 00:00:39 CNT Write done ================= ADL : End flashing ADL : Close CMT session Ok ADL : Close APE session Ok Flashing done! Total flash time : 00:04:45 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N95 8GB Software Info: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia IMEI: 359542019228657 Ape Version: 35.0.001 Product code: 0553640 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:05:39 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
09-29-2011, 10:24 | #14348 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.004_PR_004 Device mode : Production mode Read info Ok Check : Processing ADC5AE0E_RX-51_2009SE_3.2010.02-8.003_PR_F5_003_ARM.bin BLK_INF : kernel BLK_VER : 2.6.28-20094803.3+0m5 ========== BLK_INF : rootfs BLK_VER : RX-51_2009SE_3.2010.02-8.003_PR_003 ========== BLK_INF : cmt-2nd BLK_VER : BB5_09.36 ========== BLK_INF : cmt-algo BLK_VER : BB5_09.36 ========== BLK_INF : cmt-mcusw BLK_VER : rx51_ICPR82_09w47 ========== BLK_INF : 2nd BLK_VER : 1.4.14.4.4+0m5 ========== BLK_INF : xloader BLK_VER : 1.4.14.4.4+0m5 ========== BLK_INF : secondary BLK_VER : 1.4.14.4.4+0m5 ========== Check : File Is Ok ! Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Maemo Phone not found Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Maemo Phone not found Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Maemo Phone not found Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.004_PR_004 Device mode : Production mode Read info Ok Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.004_PR_004 Device mode : Production mode Read info Ok Processing NOL part File : ADC5AE0E_RX-51_2009SE_3.2010.02-8.003_PR_F5_003_ARM.bin NOL Part program error! Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.004_PR_004 Device mode : Production mode Read info Ok Processing APE part File : ADC5AE0E_RX-51_2009SE_3.2010.02-8.003_PR_F5_003_ARM.bin Processing : kernel , 2.6.28-20094803.3+0m5 Kernel flash Ok Processing APE part File : ADC5AE0E_RX-51_2009SE_3.2010.02-8.003_PR_F5_003_ARM.bin Processing : rootfs , RX-51_2009SE_3.2010.02-8.003_PR_003 RootFs flash Ok Processing CMT part File : ADC5AE0E_RX-51_2009SE_3.2010.02-8.003_PR_F5_003_ARM.bin Processing : cmt-2nd , BB5_09.36 Processing : cmt-algo , BB5_09.36 Processing : cmt-mcusw , rx51_ICPR82_09w47 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_3.2010.02-8.003_PR_003 Switch CMT request Ok CMT : Erasing... CMT : Program... CMT : Program Finished! Executing PostFlash : RX-51_2009SE_3.2010.02-8.003_PR_003 Executing PostFlash : Reset RD Flags Executing PostFlash : Reboot Done! Elapsed: 00:01:39 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following 2 Users Say Thank You to saeedullah_khan For This Useful Post: |
09-29-2011, 10:59 | #14349 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Connected phone - Nokia 6300 Software ver : V 07.21 05-11-08 RM-217 (c) Nokia. IMEI : 357999034867251 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR61_08w10 APE Test: PPM : V 07.21 05-11-08 RM-217 (c) Nokia. MEA CNT : Product SN : CMI030008 Product code : 0551881 Base Prd.code: 0555543 Module code : 0203166 Long Prod.SN : Hardware info======= HWID : 0614 Retu : 32 Tahvo : 53 Batery: 4679 mV Camera: CMT BT: Error APE BT: 06cc-P9.1 APE HW: Error LCDVer: Error RF ic : 17211721 Lock info =========== IMEI : 357999034867251 IMEI spNet : IMEI svNet : Conf key : FFFFFFFFFFFFFFFF Provider key : FFFFFFFFFFFFFFFF --------------------- = > SL Error detected = > SP Data Corrupted!!! Use Repair SL for Unlock/Repair phone!!! --------------------- Provider : Unknown Provider Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Repair SL procedure started... Phone Imei: 357999034867251 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 24400213093C8C564209F35DACCAA83B5675426C CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 24400213093C8C564209F35DACCAA83B5675426C hash= BAF3A9C3DBFA8454937DB77F2B8852B1 key= 0264DEBCC3751A0CB1D64601EB6F2B53D3348707 Init Service mode... Wait... Key file updated... Check phone mode... Phone already in Test mode, skip change... Writing SimLock Data... Ok Writing SimLock Key... Ok Done! Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! - > Do REPAIR SDD , Local SX4 if needed SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! Reading Phone Info.... Connected phone - Nokia 6300 Software ver : V 07.21 05-11-08 RM-217 (c) Nokia. IMEI : 357999034867251 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR61_08w10 APE Test: PPM : V 07.21 05-11-08 RM-217 (c) Nokia. MEA CNT : Product SN : CMI030008 Product code : 0551881 Base Prd.code: 0555543 Module code : 0203166 Long Prod.SN : Hardware info======= HWID : 0614 Retu : 32 Tahvo : 53 Batery: 4671 mV Camera: CMT BT: Error APE BT: 06cc-P9.1 APE HW: Error LCDVer: Error RF ic : 17211721 Lock info =========== IMEI : 357999034867251 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! Connect phone on selected interface... |
09-29-2011, 11:01 | #14350 (permalink) |
No Life Poster Join Date: Oct 2005 Location: QQ id 2593032292
Member: 189673 Status: Offline Sonork: 100.1592062 Thanks Meter: 351 | successful repair = > SL Error detected = > SP Data Corrupted! Connect phone on selected interface... Backup Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : F451CFD452DE0A1A53007DACC91555697F309494 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0590010F26EE6A505563967780F56695DDB3EC0B CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 30600 byte(s) IMEI : 358634015858149 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 30600 byte(s) APE : Read NPC certificate... Cert size : 0 byte(s) APE : Read CCC certificate... Cert size : 0 byte(s) APE : Read HWC certificate... Cert size : 0 byte(s) APE : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! Init Service mode... Wait... CRT308 Backup Created NPC Certificate saved... VARIANT Certificate saved... RPL saved : C:\InfinityBest\BEST\Backup\Cert\358634015858149_C RT.rpl Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Connect phone on selected interface... User ACCEPTED FULL ERASE Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : F451CFD452DE0A1A53007DACC91555697F309494 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0590010F26EE6A505563967780F56695DDB3EC0B CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! Full Erase started... Asic : CMT , Sub : NOR Erase Area 0x00000000-0x00FFFFFF Using TimeOut : 10 min ( 600 sec ) Erasing, wait..... CMT : Erase Ok Done .... Core version : 1.29 Rev : 1.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx PPM : N73_rofx_4.0839.42.2.1_PRD.V05 Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : F451CFD452DE0A1A53007DACC91555697F309494 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0590010F26EE6A505563967780F56695DDB3EC0B CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00080000 - 0x00731951 CMT , NOR , Area : 0x00000000 - 0x0005FFFF CMT , NOR , Area : 0x001E0000 - 0x001FFFFF CMT , NOR , Area : 0x00880000 - 0x00FEFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok Found 4 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0007FFFF APE , NAND , Area : 0x00080000 - 0x000FFFFF APE , NAND , Area : 0x00100000 - 0x0025FFFF APE , NAND , Area : 0x003C0000 - 0x04E1FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:04 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Write : Processing N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ADL] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [SOS*UPDAPP] APE: Writing Hash CERT [SOS+UZIP] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [ADL] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [SOS*CORE] APE: Writing Hash CERT [SOS+ROFS] APE: Writing Hash CERT [SOS+ROFX] Total writen 1770 blocks TIME : Write time : 00:05:55 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing N73_rofx_4.0839.42.2.1_PRD.V05 Found 1 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x03920000 - 0x04E1FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Write : Processing N73_rofx_4.0839.42.2.1_PRD.V05 APE: Writing Hash CERT [SOS+ROFX] Total writen 2071 blocks TIME : Write time : 00:02:32 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Init Service mode... Wait... Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Check phone mode... Phone in Error mode Seting Local mode... wait... Connect phone on selected interface... ..... Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) Variant Data found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : F451CFD452DE0A1A53007DACC91555697F309494 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0590010F26EE6A505563967780F56695DDB3EC0B CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... Switching to CMT... CMT : NPC erase Ok Writing NPC... Ok CMT : VARIANT erase Ok Writing VARIANT... Ok Done! ......... Phone found! Series 60 Device detected! read info... - Ok Unlock procedure started... Phone Imei: 358634015858149 Checking locks... Unable to read Lock table... PA_SL phone detected... Key file exists, no need to read... NCK unlock failed, will try direct RPL Phone Imei: 358634015858149 Key file exists, no need to read... Operating mode is OK, no need change... Writing SimLock Data... Ok Writing SimLock Key... Ok Unlock Done! .......... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia N73 Software ver : V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. IMEI : 358634015858149 Ape Ver : APE Var : APE ADSP: DSP Ver : scarfe_mc.05wk46v50p2 APE Test: PPM : CNT : Product SN : SBH144666 Product code : 0529607 Base Prd.code: 0527006 Module code : 0202855 Long Prod.SN : Hardware info======= HWID : 6000 Retu : 15 Tahvo : 22 Batery: 4543 mV Camera: CMT BT: APE BT: APE HW: LCDVer: RF ic : 17211721 Lock info =========== IMEI : 358634015858149 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] |
The Following User Says Thank You to sameera For This Useful Post: |
09-29-2011, 11:33 | #14351 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | c2-3 rm-702 successfully flashed Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia N73 Software ver : V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. IMEI : 355718028900320 Ape Ver : APE Var : APE ADSP: DSP Ver : scarfe_mc.05wk46v50p2 APE Test: PPM : CNT : Product SN : CDG787587 Product code : 0577467 Base Prd.code: 0560819 Module code : 0203819 Long Prod.SN : Hardware info======= HWID : 8200 Retu : 15 Tahvo : 22 Batery: 4678 mV Camera: CMT BT: APE BT: APE HW: LCDVer: RF ic : 17211721 Lock info =========== IMEI : 355718028900320 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : Ok Step2 : Ok End format... ================================== Formating drive : D now... Step1 : Ok Step2 : Ok End format... ================================== Done! N73 contact retailer done |
The Following User Says Thank You to Riteshgpt60 For This Useful Post: |
09-29-2011, 11:34 | #14352 (permalink) |
Member: 1086393 Status: Offline Thanks Meter: 771 | c2-03 rm-702 successfully flashed Code: Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Reboot.... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : SGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.44_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! ===Flashing [CNT]=== File : 64B697C1_rm702__06.52_002.image_mh1_ctv_in_9k4z2 Image : package_mh1_ctv_in.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:00:56 Write , Start : 0x424C0000 , Len : 0x00C20000 Flashing , wait ... Region flash done, time : 00:00:17 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip Flashing done! Total flash time : 00:11:37 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 06.51 15-07-11 RM-702 (c) Nokia IMEI: 357011044444444444444 PPM version : V 06.51 15-07-11 RM-702 (c) Nokia MH1 Product code: 059K4Z2 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:01:48 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following 2 Users Say Thank You to Riteshgpt60 For This Useful Post: |
09-29-2011, 13:48 | #14353 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | COM5 selected module v4.01 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:4D73:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.4.01, database date: 19.08.2011): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.BG-MTEL-R9SM-P109A17V1_0_0B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.BG-MTEL-R9SM-P109A17V1_0_0B01.BIN project-id: BG-MTEL-R9SM-P109A17V1.0.0B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00880000 standard ffs/eeprom offset confirmed: 00880000 detecting ffs/eeprom size... ffs/eeprom size: 00780000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00880000-00FFFFFF firmware area: 00000000-0087FFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ................... ffs/eeprom: detect std location pass #1... .................................. ffs/eeprom: detect ext location pass #1... .......................... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.BG-MTEL-R9SM-P109A17V1_0_0B01__ffs... file saved: C:\InfinityBox\MModule\ZTENJ23D_09A_PCB01_GPRS_MT6 223_S00.BG-MTEL-R9SM-P109A17V1_0_0B01__ffs_20110929-033511.B0E.bin flash: C2227E22212201:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: C2227E22212201:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 10 min 6 sec Remove/Install battery now ! |
09-29-2011, 13:54 | #14354 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 16800102EC800052A1C01B6F4AFD63B3BCDAD328 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 11.24.0 Processing RAWLOADER... FLIC : 005800EC Req : XSR 1.6 Use URAPIDOv11_XSR17_alg.fg , Rev : 2.0 Ver : 11.24.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:00 CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : C49131EB98702B6A39D7F285B1FF2D9BE1D6F863 CFL : RAPIDO Mode - FLASH CRT (NPC/CCC/HWC...) can't be readed CFL: Close_Session Content: 000300000000030000000300000000 CFL: Reboot Wait, reconneting... SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok CRT308 Backup Created SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.29\Backup\Cert\3569 18030451598_SIM.rpl All done, Disconnecting Elapsed: 00:00:25 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone detected , SP_CODE_LEN : 15 Done! Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Formating drive : D now... Step1 : OK Step2 : OK End format... ================================== Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:08 Reading Phone Info.... Connected phone - Nokia N97 mini Software ver : V ICPR72_09w28.6 09-09-09 RM-555 (c) Nokia IMEI : 356918030451598 Ape Ver : v 10.0.020 APE Var : v 10.0.02010.0.020.01.0110.0.020.209.02 APE ADSP: 256 DSP Ver : ICPR72_09w26 APE Test: rm555ENO_09w24v0.040 PPM : CNT : RM555_014_000_M001 Product SN : C8B747983 Product code : 0591466 Base Prd.code: 0580176 Module code : Long Prod.SN : 0 Hardware info======= HWID : 5412 Retu : 16 Tahvo : 22 Batery: 3980 mV Camera: CMT BT: APE BT: APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 356918030451598 IMEI spNet : 3A 65 19 08 03 54 51 09 IMEI svNet : 33 65 19 08 03 54 51 09 F1 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created User code : Crypted UserDataExLevel : Low [Gallery] Done! |
09-29-2011, 14:49 | #14355 (permalink) |
No Life Poster Join Date: Nov 2007 Location: INDIA
Member: 629327 Status: Offline Sonork: 100.1663374 Thanks Meter: 537 | ==== log opened: [3/28/2011 1:35:48 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.73 S/N: 41EF:0116 Wait... Device: LG-GB125 Ready Device: ZTE-125 COM1 ready WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? operation aborted WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [3/28/2011 1:36:16 PM] ==== COM1 [Serial0] selected module v1.73 Device: ZTE-125 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: -IN-P108A1V1.0.0B05 Jul 17 2007 Jul 17 2007 09 48 59 09 48 59 VD Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20110328-133633.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z125_eep65535.cfg error: can't load database v.11 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20110328-133634.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20110328-133640.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 23 sec Remove/Install battery now ! |
