Old 12-08-2009, 10:35   #1456 (permalink)
TUR@N ALAM's Avatar
Member: 705213
Sonork: https://wa.link/aru52t
Thanks Meter: 2,735
Alcatel-S319X successes full unlock
COM17 [VCP2] selected
module v2.79
Device: Alcatel-S319X, S319A
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:27AE:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 detection finished
identification#1 protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
ffs offset/size: 00C00000/00400000
detect device identification#2...
detect device identification#2 finished
sim-lock status: disabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
security area (code #1) check...
security area (code #1) fixed
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20091208-042123.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CH16DS32
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
use default security area (code #3, part #1) pattern
..................security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20091208-042720.B0X.bin
Finished, time used: 401 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 2 Users Say Thank You to TUR@N ALAM For This Useful Post:
Old 12-08-2009, 11:16   #1457 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM6 [VCP0] selected
module v3.02
Device: Autodetect 6205-6227 NOR
write: Firmware
BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12__Nokia-N95-8GB_16m_En_Ru_Fr_Farsi_Pt_Ar.B0M.bin
skip: Customization
write: Eeprom/ffs
BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12__ffs_01.B0E.bin
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:7503:0008
status: FF
Boot Done
====> Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info protocol ver: 04
ver. sw 1: BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12.BIN
ver. sw 2: MAUI.GEMINI.W08.12, 00000000
code offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00E40000
Detected ffs/eeprom address is non-standard: 00E40000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E40000
detecting ffs/eeprom size...
ffs/eeprom size: 001C0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E40000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
====> Check firmware content ...
====> Backup required data ...
reading: BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\BOWAY25_GEMINI_PC B01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12__ffs_200912 09-040049.B0E.bin
====> Patch required data ...
====> Special operation ...
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 951 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 12-08-2009, 14:24   #1458 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
I-Mobile 101 reset ok 100% Thanks to infinity team.
COM5 [VCP0] selected
module v1.68
Device: IMobile-101 HW-A
Action: reset
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\IMobile-101 HW-A_eeprom-static_20091208-051246.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\IMobile-101 HW-A_eeprom-security_20091208-051247.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\IMobile-101 HW-A_eeprom-complete_20091208-051254.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 26 sec
The Following User Says Thank You to mbiborna For This Useful Post:
Old 12-08-2009, 16:27   #1459 (permalink)
adreesas's Avatar
Member: 752606
Sonork: 100.1587361
Thanks Meter: 110
alcatle s319x unlock with new method
module v2.98
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:06BB:A00C
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
TCL-ID detection done
rom info protocol ver: 05
TCL-ID identification
version: 16U
provider: S319X-2ARGGB1
customization: CH16CB31
customization: XH16CB31
TCL-ID identification done
ffs/eeprom address assigned: 00C00000
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, part #2) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20091208-201847.B0X.bin
Finished, time used: 197 sec
USMAN COMUNICATIONS CHAKSWARI
The Following User Says Thank You to adreesas For This Useful Post:
Old 12-09-2009, 07:32   #1460 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM3 [VCP0] selected
module v1.71
Device: LG-KG270
Action: flash write
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL CIS Open KG270 KG275 P16 07 V10e XXX-XX MAY 30 200
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091010-232734.B1E.bin
loading data...
data loaded
imei: 35286302000491200
reading eeprom-security_35286302000491200...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35286302000491200_20091010-232735.B1E.bin
reading eeprom-complete_35286302000491200...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35286302000491200_20091010-232736.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Write Done
Finished, time used: 122 sec
Old 12-09-2009, 09:06   #1461 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
SAGEM MY 150X REPAIR OK
module v1.72
Device: Sagem-my150x
Action: reset
Boot ...
e-gold: 820010
loading...
middle part...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: 537 EAI_IJ EAI_IJ_181207_1537 Ag Bh ` f
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-static_20091209-125458.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-security_20091209-125459.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-complete_20091209-125505.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 29 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 12-09-2009, 09:13   #1462 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
OLD IS GOLD
module v1.72
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091209-131104.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091209-131106.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091209-131112.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091209-131125.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 56 sec
Old 12-09-2009, 15:28   #1463 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
Cool Alcatel OT103X Sucessfully unlocked, 3pcs.
First........
COM3 selected
module v2.98
Device: Alcatel-103X, 103A
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:7412:A00C
status: 01
Boot Done
flash: 01227E221A2201:2BEA0000000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
TCL-ID detection...
ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000
ffs offset/size: 003A0000/00058000
version: 17E
provider: 103X-2ATTTP1
customization: CM17CC41
customization: XM17CC41
ffs/eeprom address assigned: 003A0000
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
max address is too big, should be recalculated: 0827D124->0826B45C
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_200912 09-141319.B0X.bin
Finished, time used: 119 sec
Second...........
COM3 selected
module v2.98
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:7C49:A00C
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
version: 17E
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_200912 09-142111.B0X.bin
Finished, time used: 90 sec
Third..........
COM3 selected
module v2.98
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:78D4:A00C
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
version: 17E
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_200912 09-142721.B0X.bin
Finished, time used: 88 sec
Thnxxx Infinity team........
The Following User Says Thank You to amanvir For This Useful Post:
Old 12-09-2009, 20:20   #1464 (permalink)
GuilleC_PMA's Avatar
Member: 86124
Sonork: 100.1604943
Thanks Meter: 111
Coral 655
module v2.98
Action: unlock
unlock method: smart fast
Model: Coral-655
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:EF03:0006
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: C2016HW_2.7_US_DIGICEL
Version: C2016_US
44 byte(s) read
imei: 35742902012506
connection Ok
157 byte(s) read
reading data...
building new data...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 10 sec
The Following User Says Thank You to GuilleC_PMA For This Useful Post:
Old 12-09-2009, 20:59   #1465 (permalink)
Nadjombe's Avatar
Member: 185608
Thanks Meter: 592
Thumbs up Soft works perfectly...
Soft works perfectly!Infinity is a Great Team...saying that perfect software is under test again!It works!!!You open new of new secu door!
Logs here:
> module version: v.
=> operation (3) started: COM4
==> get_dll_version
dll version: 38.0i
==> set_com_port
==> set_baud_rate
==> set_v24_mode
==> set_baud_rate
==> check_comm_link
==> get_ms_id
imei: 358545028131615
==> get_sw_version
sw ver: P1.2CM01V01.03:ULC2GL
==> get_sec_version
sec ver: 00.31Et(4242)
==> get_eep_version
eep version: 000C
==> get_eep_revision
eep revision: 0000
==> reading...
access result: 00
access level: 03
==> set required mode...
==> reboot...
==> reading...
lock result: 00
lock status: 020A
==> unlock...
verification result: F0600100561200FF00040105020503050405000000000000
==> restore original mode...
last error: No errors
=> operation finished
==> close_com_port
Finished, time used: 20 sec
Power Off/On phone now !
The Following User Says Thank You to Nadjombe For This Useful Post:
Old 12-10-2009, 07:40   #1466 (permalink)
Member: 977491
Thanks Meter: 82
Cool T250i unlock done.
hello friends, see this report.
COM20 [VCP0] selected
module v1.34
Device: Sony-Ericsson-T250i
"advanced chip detection" active
Action: unlock
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 20882EFFFFFFFF:20882E00000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
Check hardware done
Read data ...
reading Sony-Ericsson-T250i_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T250i_eeprom_calibration-1_20091209-231859.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 120 sec
BR, themobileshop
The Following User Says Thank You to themobileshop For This Useful Post:
Old 12-10-2009, 08:52   #1467 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 874
Action: format
Device: C113(a),C114,C115,C116,C117,C118
Connect...
Press and HOLD Power button...
connection mode: 00
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 1.0.74.E.
HW version: _E88
imei otp: 355609007929200
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _355609007929200_20091210-123758.18E.bin
imei eeprom: 355609007929200
Check Flash-2 Done
Write...
Write Done
Finished, time used: 47 sec
The Following User Says Thank You to alis For This Useful Post:
Old 12-10-2009, 08:53   #1468 (permalink)
.::adnangsm::.'s Avatar
Member: 802214
Sonork: 100.1573572
Thanks Meter: 95
Alcatel-S319X unlock
Alcatel-S319X unlock 100%ok
COM14 [VCP2] selected
module v2.96
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:0E0F:A00C
status: 01
Boot Done
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is present
TCL-ID detection...
address offset: 00000000
version: 16L
provider: S319X-2ATBNL1
customization: CH16CT30
customization: XH16CT30
ffs address assigned: 00C00000
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20091210-124310.B0X.bin
Finished, time used: 182 sec
The Following User Says Thank You to .::adnangsm::. For This Useful Post:
Old 12-10-2009, 08:55   #1469 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 874
module v1.71
Device: LG-KG270
Action: flash write
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL KG270 P16 92 V10e XXX-XX Jun 20 2007 +0
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091210-125253.B1E.bin
loading data...
data loaded
imei: 35744601043705500
reading eeprom-security_35744601043705500...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35744601043705500_20091210-125253.B1E.bin
reading eeprom-complete_35744601043705500...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35744601043705500_20091210-125255.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
Erasing: Language Pack
Writing: Language Pack
Write Done
Finished, time used: 156 sec
The Following 2 Users Say Thank You to alis For This Useful Post:
Old 12-10-2009, 09:33   #1470 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 874
Action: flash
Write: Firmware
Write: Language Pack
Write: Flex
Skip: Eeprom
Connect...
connection mode: 00
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
HW version: _E88
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _355609007929200_20091210-131115.18E.bin
Check Flash-2 Done
Write...
Writing: all flash areas
Write Done
Finished, time used: 136 sec
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.57598 seconds with 10 queries
