Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 03-14-2007, 14:50   #1 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
New Way To Measurement Without Oscilliscope And Other Hi-fi Equipment
Changing The Way To Measure It Almost Changes The Way To Check The Component
Following There Will Be Guide How To Measure
Old 03-14-2007, 15:26   #2 (permalink)
Crazy Poster
Member: 387679
Thanks Meter: 16
where is that guide which you are talking about
Old 03-15-2007, 06:22   #3 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
As We Measure By Taking Negative Probe To The Ground And Positive Probe To The Position Where We Have To Measure While In Voltage, But In Case Of Ohms (contunity Test Or Track Check) We Measure From The Receive Point To Target Point
Maximum Cases There Are Track Brocken Which We Don't Know The Source Point Even Many Track Are From Below The Ic Where Our Multimeter Probe Dosen't Reach
So My Solution Is That We Will Measure The Point By Taking The Positive Probe To The Ground And Negative Probe To The Target Point There Will Be A Value Shown In A Ohms Range We Must Note It From Good Set
The Following User Says Thank You to yashtel For This Useful Post:
Old 03-15-2007, 08:17   #4 (permalink)
Member: 45992
Thanks Meter: 38
you cannot make a good repair like this,except in open circuit or short circuit cases
The Following User Says Thank You to taikuko For This Useful Post:
Old 03-15-2007, 12:53   #5 (permalink)
Member: 136511
Yashtel, you are right about this. But usually it's better to use diode measuring function on multimeter, because you test ESD protection diodes inside some IC. This way it's possible to check many IC input/output connecion. data or address bus.. But still osciloscope is essential equipment.
The Following User Says Thank You to diehard For This Useful Post:
Old 03-15-2007, 13:33   #6 (permalink)
Member: 133465
Thanks Meter: 15
how possible it is men? what about the Ic's that are detach from pcb can it be possible to trace whether the ic is good or not?
The Following User Says Thank You to donex74 For This Useful Post:
Old 03-15-2007, 15:36   #7 (permalink)
CPUKILLER's Avatar
Member: 76257
Thanks Meter: 77
100% correct using this method for the last 14 years--regards --cpukiller
The Following 2 Users Say Thank You to CPUKILLER For This Useful Post:
Old 03-15-2007, 15:38   #8 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
Is ok this kind of checking , i use it and find broken traks in percent about 90% .
The Following User Says Thank You to Ionel For This Useful Post:
Old 03-16-2007, 08:05   #9 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
As In Sony Ericsson Sets There Are Many Problem Of No ***** Speech Generally On Older Set These Problem Are Due To Mic But In Newer Sets There Is One Special Interface Ic For Mic That Is Would Damage
But I Found That Generally That Ic Dosen't Damage And We Dont Need To Change 70%
It Is How That In A Mic Point There Are Two Connections When We Put The Positive Probe To A Ground And Negative Probe To The Mic Position Than We Found The Value Shown In A Ohms Range Approx. 900 Ohms And Another One Approx. 1400 Ohms In That Case I Usually Clean Very Nicely Mic Ic Than I Dried It Up And Finally I Put The Switch Oil (generaally Avaliavle In The Radio Tv Spares Shop) Over The Mic Ic That Can Go Below The Ic And Keep It For About Ten To Fif**** Minute The Switch Oil Can Remove The Rust From Below The Ic Then I Heat It Up The Switch Oil Burnt It Up And The Rust Come It Out From The Ic And Little Bit Of Short Between The Legs Of The Ic Usuallu Removes.
Now Time To Clean And Dried It Up And Test It 70% Success On This Proccess.
The Following 5 Users Say Thank You to yashtel For This Useful Post:
Old 03-16-2007, 08:08   #10 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
IN ABOVE LINES WRITTEN THAT WE WILL GET In A Mic Point There Are Two Connections When We Put The Positive Probe To A Ground And Negative Probe To The Mic Position Than We Found The Value Shown In A Ohms Range Approx. 900 Ohms And Another One Approx. 1400 Ohms IF NOT THAN IT MIGHT BE IC DAMAGE, BUT I TRY THE SAME ABOVE PROCCESS TO GET THE VALUE IT MIGHT BE OK
Old 03-16-2007, 08:15   #11 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
Whear As In Case Of Sonyericsson Keypad And Joy Stick Either The Joystick Is Damage Or Not Or Keypad Ic Is Damage.
According To The Formulae Every Connection Of Joystick And Keypad Valued In Ohms Range Approx. 745 Ohms.
When We Change The Keypad Ic Either It Is Correctly Fitted Or Not I Have To Check By Putting The Lcd Back Body And Battery And On The Set With Sim Check The Keypad And Joy Stick.
Sticky And Long Proccess.
If It Is Correctly Fitted Than Than Every Point Will Show Approx. 745 Ohms And We Pack It Confidently.
The Following 2 Users Say Thank You to yashtel For This Useful Post:
Old 03-16-2007, 08:19   #12 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
In Nokia Sets Every Connections Of Keypad Shows Approx. 600 Ohms By Putting Positive Probe One The Ground And Negative Probe One Every Connections Of The Keypad.
Old 03-16-2007, 08:21   #13 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
In Nokia Sets Mic Connecions Are Like Sony Ericsson One Is Approx. 900 Ohms And Another One Is Approx. 1400 Ohms If It Is Not There Than Some How The Track Is Open
Old 03-25-2007, 08:44   #14 (permalink)
Member: 44625
Thanks Meter: 36
@yashtel,
Keep up the good work! These tips are useful to anyone who is into mobile phone repairs, and they work.
Trion
The Following User Says Thank You to Trion For This Useful Post:
Old 03-27-2007, 19:23   #15 (permalink)
Member: 432679
Thanks Meter: 118
this tips r very usefull to the memebers.
thks yash
The Following User Says Thank You to syed.n For This Useful Post:
FPS-10, SX4 and other original Nokia Equipment GsmProf Sell ur Old and Used Stuff 4 04-09-2008 15:47
New way to find pinout solution - Hope it will help other members GuruKids Infinity-Box 7 01-06-2008 09:41
The correct ways to unlock W810, W800 and other?? dynamic-gsm HWK 2 11-19-2007 12:49
How to flash V360 ,l6 ,and other new models without tp?? basim Motorola P2k 3 10-25-2006 02:15
...::: New online update server and new way to enter Support Area :::... zulea Phoenix Black Box 46 01-04-2006 13:27
Page generated in 0.26368 seconds with 10 queries
