Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
11-27-2011, 12:20 | #76 (permalink) |
Major Poster Join Date: Mar 2006
Member: 240778 Status: Offline Thanks Meter: 3 | |
12-03-2011, 17:55 | #77 (permalink) |
Insane Poster Join Date: Aug 2011 Location: Johannesburg .southafrica
Member: 1627353 Status: Offline Sonork: TWISTER 93179 Thanks Meter: 3 | hello with much glad to u. pls i may need an asistment from u , if only u care i;m a jonior member i'm in great distress pls i need u to help me out, pls y. i'll be glad to meet u on line pls . when was that? this my email,,,,,[email protected] i' l apreciate ur understanding and ur little time . to meet u .pls accept my invitation . my regards to all gssforum members and administrators '' thanksssss |
01-06-2012, 17:01 | #78 (permalink) | |
Freak Poster Join Date: Aug 2010 Location: Kabyle Algeria
Member: 1365226 Status: Offline Thanks Meter: 19 | Quote:
if they have' nt you can test them on board if they are in parallel with IC do not put the positive probe in the ground, when measuring for example resistors you need also to remove components when you need to check for shortin in the PCB , for example remove coil that are in serie with IC's to know if it cause the shorting Last edited by AhmedHosting; 01-06-2012 at 17:09. | |
09-04-2012, 08:06 | #79 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india
Member: 687718 Status: Offline Sonork: 100.1603913 Thanks Meter: 121 | Hi all i am using this (positive probe on ground) method since 2004. And i repair thousands of sets by this method. I have made own theory about it but my problem is i dont know english very well so i am unable to translate my theory for you guys. If any indian people need this theory in hindi language can contact me on 09907432714 |
09-15-2012, 13:01 | #80 (permalink) |
Junior Member Join Date: Aug 2012 Location: Yuma Az
Member: 1802236 Status: Offline Thanks Meter: 0 | I wanted to say thanks for the info, I'm a self starter and I love doing this type of work. Started as a hobby and I'm trying to make it full time. Not sure how to do the thanks box. |
11-27-2012, 20:05 | #81 (permalink) | |
11-27-2012, 20:09 | #82 (permalink) | |
01-08-2015, 11:00 | #83 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | "When We Change The Keypad Ic Either It Is Correctly Fitted Or Not I Have To Check By Putting The Lcd Back Body And Battery And On The Set With Sim Check The Keypad And Joy Stick." Kindly elaborate with possible image or manual diagram for more clarity ? Awaiting for your good job ? Thanks, BR, amit123 |
07-18-2023, 13:49 | #85 (permalink) | |
Junior Member Join Date: Jul 2016 Location: Maguindanao, Philippines Age: 27
Member: 2602888 Status: Offline Sonork: Not Using Thanks Meter: 2 | Quote:
FPS-10, SX4 and other original Nokia Equipment | GsmProf | Sell ur Old and Used Stuff | 4 | 04-09-2008 15:47 |
New way to find pinout solution - Hope it will help other members | GuruKids | Infinity-Box | 7 | 01-06-2008 09:41 |
The correct ways to unlock W810, W800 and other?? | dynamic-gsm | HWK | 2 | 11-19-2007 12:49 |
How to flash V360 ,l6 ,and other new models without tp?? | basim | Motorola P2k | 3 | 10-25-2006 02:15 |
...::: New online update server and new way to enter Support Area :::... | zulea | Phoenix Black Box | 46 | 01-04-2006 13:27 |
