Old 08-18-2015, 16:07   #1 (permalink)
Member: 2332758
Sonork: 1663896:GsmShafaiT
Thanks Meter: 152
Post here successfully job with Z3X-BOX Samsung (2018-2022)
SGH-X460 UNLOCK DONE BY Z3X
Connect PHONE BY E700 CABLE
CLICK READ INFO
BR,
GSM-SHAFAIT
The Following 13 Users Say Thank You to gsmshafait For This Useful Post:
Old 10-07-2015, 14:59   #2 (permalink)
josuan's Avatar
Member: 1939108
Thanks Meter: 44
N920T repair succeed done
Operation: Write CERT
Selected model: SM-N920T
Software version: 22.8
Waiting ADB device... OK
Reading phone info...
Model: SM-N920T
Android version: 5.1.1
Product code: SM-N920TZKATMB
Phone version: N920TUVU1BOH4
PDA version: N920TUVU1BOH4
CSC version: N920TTMB1BOH4
CSC country code: USA
CSC sales code: TMB
HW version: REV0.2
Phone S/N: RF8G724HKCL
Modem board: SHANNON333
RF cal date: 20150727
IMEI:
Checking Super user right... true
Checking certificate file... OK
KEY ID: 0448
Initializating zTool... OK
Running zTool, please wait... OK
Reading nv data... OK
Checking NV data... OK
Calculating... OK
Writing nv data... OK
Rebooting phone... OK
Write CERT done
Done with Samsung Tool PRO v.22.8
The Following 14 Users Say Thank You to josuan For This Useful Post:
Old 10-07-2015, 16:58   #3 (permalink)
Member: 174853
Thanks Meter: 84
Where is the cert file ?
The Following 2 Users Say Thank You to virtue For This Useful Post:
Old 01-15-2016, 03:10   #4 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
SM-J100Y unlock DONE
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock.
If phone ask codes after unlocking, use:
PUK - 12345678
PIN - 00000000
Operation: Unlock
Selected model: SM-J100Y
Software version: 24.1
Model: SM-J100Y
Android version: 4.4.4
Product code: SM-J100YZWAOPP
Phone version: J100YDXU0AOC1
PDA version: J100YDXU0AOC1
CSC version: J100YOPP0AOC1
CSC country code: Australia
CSC sales code: OPP
HW version: MP 0.100
Phone S/N: R28GA3EKQAL
Modem board:
RF cal date: 20151029
IMEI: 358926061661041
Analysing SEC file... OK
Initialization AT RIL... OK
Bypass MSL... OK
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.24.1
thankz Z3X Team
The Following 10 Users Say Thank You to Deni's For This Useful Post:
Old 02-09-2016, 01:42   #5 (permalink)
Member: 2319987
Thanks Meter: 10
SM-N910T 5.1.1 write cert done..
KEY ID:****
Please, allow USB debugging on phone... OK
Model: SM-N910T
Product code: SM-N910TZWATMB
Phone version: N910TUVU2DOK2
PDA version: N910TUVU2DOK2
CSC version: N910TTMB2DOK2
CSC sales code: TMB
HW version: REV1.1
Phone S/N:********
Modem board: *******
RF cal date: 2015.10.05
IMEI:
Bypass MSL... OK
Checking for compatible phone and cert... OK
Phone KEY ID: *****
Writing CERT... OK
Checking CERT status... OK
Done with Samsung Tool PRO v.24.2
The Following 5 Users Say Thank You to earth2345 For This Useful Post:
Old 03-17-2016, 14:04   #6 (permalink)
Member: 888420
Sonork: 100.1611861
Thanks Meter: 394
G928F Unlock done Z3X
G928F S6 edge plus 5.1.1 UNLOCK DONE With Z3x
PROCEDURE
1. ENABLE OEM
2. DOWNLOAD Root File
https://www.4shared.com/file/NY3tPIy...KLSI-ODIN.html
3. Put Phone to DOWNLOAD MODE
4. Open Odin3_v3.10.6 and select root file
After root unlock via Z3x
The Following 7 Users Say Thank You to PlayGsm For This Useful Post:
Old 03-21-2016, 13:29   #7 (permalink)
Member: 926208
Thanks Meter: 71
unlock is ok after root 5.0.1 thank you men
The Following 4 Users Say Thank You to khassene01 For This Useful Post:
Old 04-22-2016, 17:10   #8 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
does any one tested it?
The Following User Says Thank You to GSM SNIPER For This Useful Post:
Old 04-22-2016, 17:12   #9 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
try to read IMEI ? is-it good?
Old 07-01-2016, 04:15   #10 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
Samsung Galaxy S SC-02B IMEI Repair Done
Samsung Galaxy S SC-02B IMEI Repair Done With z3x
In my Set No IMEI After update
but with the help of z3x Box All Done
1. Flash with z3x this firmwre SC02BOMKL4_SC02BDCMKL4 (Download From support Area)
2. After Flash IMEI ok automatic. But not Registered on Network
3 Now write Modem file "Modem_SC02BOMJJ1_patched.zip" file (download From Support Area)
And All Done
Thanks z3x Team
The Following 7 Users Say Thank You to sr8787 For This Useful Post:
Old 07-29-2016, 08:31   #11 (permalink)
partycrasher131's Avatar
Member: 749754
Sonork: partycrasher131
Thanks Meter: 134
J710gn unlock done
J710GN UNLOCK DONE FINALLY THANX TO Z3X
NLOCK INSTRUCTIONS:
READ CODES:
5. Press 'Read codes' to read security codes.
DIRECT UNLOCK:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button.
Operation: Unlock
Selected model: SM-J710GN
Software version: 26.2
Searching Samsung modem... detected COM23
Reading phone info... OK
Model: SM-J710GN
AP Version: J710GNDXU1APG1
CSC Version: J710GNOLB1APG1
CP Version: J710GNDXU1APG1
Product code: SM-J710GZDUXME
Phone S/N: RF
Imei: 35
Unique number: C00
Reading data from phone... OK
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.26.2
The Following User Says Thank You to partycrasher131 For This Useful Post:
Old 08-06-2016, 10:55   #12 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 66
Samsung G928F unlock done 100%
Searching Samsung modem... detected COM508
Model: SM-G928F
AP Version: G928FXXS2BPG1
CSC Version: G928FOXX2BPF1
CP Version: G928FXXU2BPE6
Product code: SM-G928FZDATPH
Phone S/N: RF8GB2JXWXH
Imei: 354750074186851
Unique number: 0915F9D9E2D72704
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.26.3.1
A phone must be root! You can root with cf auto root
The Following 5 Users Say Thank You to zangoako For This Useful Post:
Old 08-06-2016, 18:12   #13 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
Model: SM-G928F
Unlocking... OK
Unlock done
No need for root if you direct unlock
The Following 4 Users Say Thank You to souma_k For This Useful Post:
Old 08-16-2016, 09:39   #14 (permalink)
jordachi's Avatar
Member: 730652
Thanks Meter: 74
samsung g828f unlock
Yes but unlock without root :
Directly unlock with read codes not work
Searching Samsung modem... detected COM89
Model: SM-G928F
AP Version: G928FXXS2BPG2
CSC Version: G928FVFG2BPB6
CP Version: G928FXXU2BPF1
Product code: SM-G928FZDACNX
Phone S/N: R58G80F4X1R
Imei: xxxxxxxxxxxxxx
Unique number: xxxxxxxxxxxxx
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.26.4
The Following 4 Users Say Thank You to jordachi For This Useful Post:
Old 02-06-2017, 11:47   #15 (permalink)
skyulock's Avatar
Member: 757064
Sonork: 11111111
Thanks Meter: 365
Samsung wp sgh-i187 phone unlock successfull
USB cable:
1. Phone must be powered on.
2. Type ##634#, then type *#7284# and choose 'QC RmNetComposite' option.
3. Apply confirmation and wait till phone reboot.
4. Connect USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
Operation: Unlock
Selected model: SGH-I187
Selected port: COM78 USB Serial Port
Software version: 27.7
Reading IMEI... Ok
IMEI: 35628SKYULOCK
Unlocking... Ok
Reseting... Ok
Unlock done
Done with Samsung Tool PRO v.27.7
The Following 4 Users Say Thank You to skyulock For This Useful Post:
Page generated in 0.16978 seconds with 9 queries
