GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
11-13-2007, 14:20 | #1891 (permalink) |
Junior Member Join Date: Nov 2007
Member: 629941 Status: Offline Thanks Meter: 0 | And guess what!? I got a very nice SIGNED sis. But of course that (not my IMEI) will not work on my E-90. So please can BU or someone else make a new cert for me for IMEI 353659012350225 and please tell me wich route66 version (v7.3.486 or v7.3.545)to use with E-90? Thank u very much! Lee |
11-13-2007, 16:41 | #1892 (permalink) |
Member: 630652 Status: Offline Thanks Meter: 0 | Route 66 activation has failed As suggested by BuMobiles, I tried a soft reset on my n95 8gb. When it restarted should the progs still be there? Also i removed route 66 and reinstalled to no avail. Please help Thanks |
11-13-2007, 17:17 | #1893 (permalink) |
Member: 626635 Status: Offline Thanks Meter: 0 | HI BUMOBILES Could you please make a new cert for me for my N95 8GB IMEI # 356983010418215 and also let me know which version of route66 I should use to make it compatible with internal GPS. v7.3.486 or v7.3.545. Thanks for all your help in advance. Pkaayaa |
11-13-2007, 17:26 | #1894 (permalink) | |
No Life Poster Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | Quote:
http://rapidshare.com/files/69452272...s._SIGNED_.sis thanks b.u mobiles | |
11-13-2007, 18:06 | #1896 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Over Here
Member: 613875 Status: Offline Thanks Meter: 61 | Quote:
11-13-2007, 18:11 | #1897 (permalink) | |
Junior Member Join Date: Oct 2007
Member: 621148 Status: Offline Thanks Meter: 0 | Quote:
Need Route66.Mobile.v7.3.545.cracked.unsigned signed. My cert: http://forum.gsmhosting.com/vbb/atta...7&d=1194893894 Thanks | |
11-13-2007, 18:15 | #1898 (permalink) | |
Freak Poster Join Date: Aug 2001 Location: UK Age: 57
Member: 5831 Status: Offline Thanks Meter: 2 | Could you please clarify something for regarding these installations 1. do i need a specific .cer file created by you for the imei of the phone? to allow me to sign an application to that phone using the "Sign Your Apps" program . Or does the software that you have posted allow us to create our own .cer files? I have spent ages looking for the .cer files & assume this is the only answer? Regards REPAIRMAN Quote:
11-13-2007, 20:33 | #1900 (permalink) |
Member: 628437 Status: Offline Thanks Meter: 1 | Route66.Mobile.v7.3.545.cracked.unsigned cer pls hi i need someone to create a cert file for me for Route66.Mobile.v7.3.545.cracked.unsigned i have the tools to sign it but not to create the cer file, IMEI 356962010746718....thx |
11-13-2007, 20:51 | #1901 (permalink) |
Member: 630716 Status: Offline Thanks Meter: 0 | Hi, Right, i have tried doing this by myself and resisted temptation of bothering you guys too much but i have become stuck: 1. have made the .cer file 2. downloaded b.u tools if i open either version 1 or 2 , i can see the app thats needs to be sighned but in step 2 "click on the certificate" its not in the box?? I have made sure the .csr file is in the same folder as the b.u tools but no luck any ideas guys? I know im nearly there , i have a feeling this is the last hurdle Thanks a bunch Nick |
11-13-2007, 20:58 | #1902 (permalink) | |
Member: 630716 Status: Offline Thanks Meter: 0 | Quote:
right, its created 2 files for me a .sis and a xxxx.cer file what next? many thanks nick | |
11-13-2007, 22:16 | #1903 (permalink) |
Member: 629306 Status: Offline Thanks Meter: 0 | Many thanks BuMobiles Many thanks BuMobiles. I downloaded the signed file and could installed successfully on my n95. It shows "No GPS!" though, but it could be problem of the satellite signal. Cheers BuMobiles. |
11-13-2007, 22:44 | #1904 (permalink) | |
Member: 629941 Status: Offline Thanks Meter: 0 | Quote:
Excuse me, i solved it myself! The cer file you provided me with was "double" zipped. I unzipped the file and got a result with no extension. That was the one i worked with. But i had to unzip that one too, then got another file with no extension. This one i renamed to XXXXXX.cer and Voila! I found it out by downloading a random other cer file from this trhead and opened it with notepad. I noticed so much difference inside that i knew i did something wrong. It is now up and running! Maybe you can answer my last question. Whats the best version of route66 to use on my e90? But hey! Thanx for the cer! Owe u one | |
11-13-2007, 23:39 | #1905 (permalink) | |
Member: 503346 Status: Offline Thanks Meter: 2,582 | 7.3.545 Quote:
Need crack for route 66 mobile 7 for n95 and australia maps. | carulli | Nokia Multimedia | 3 | 04-04-2009 11:14 |
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) | aapkae | Nokia Multimedia | 0 | 03-16-2009 10:01 |
Route 66 Wms Latest Uk Maps ??? | markcoopz | GPS devices , Navigators & Maps | 0 | 03-18-2007 13:34 |
Denmark map for TT 5.2 or Route 66 mobile 7 | lordb24 | Nokia Multimedia | 0 | 01-15-2006 21:12 |
Route 66 Mobile 2005 and GPS BT Receiver | fido59 | Nokia Multimedia | 1 | 10-11-2005 07:34 |
