08-24-2009, 22:53 | #17 (permalink) |
Insane Poster Join Date: Apr 2006
Member: 267789 Status: Offline Thanks Meter: 5 | Facoly Moulnisky I tried several times unsuccessfully I think you want a good solution to problem Did you update the firmware of your box again? BR Alex how to give me the tutorial Just click on box maintance and afterward on the "spanner" for maintance box BR Alex This is the answer Box Maintenance procedure started at 00:09:25 Box Open Error -> Security problem #1 Box Maintenance Error -> No connection was established, or box is not in needed mode Before doing click on box maintance unplug the box and plug it again on the usb cable. BR Alex I tried several times unsuccessfully same error you showed the logs before or different? before AND different Did the software see the box or not? Last edited by moulnisky; 08-24-2009 at 23:47. |
The Following User Says Thank You to facoly For This Useful Post: |
08-27-2009, 07:19 | #20 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Valladolid-Spain Age: 52
Member: 48936 Status: Offline Thanks Meter: 20 | Hi i have the same problem too, but when i execute cyclone from another location, for example where i have extract cyclone 7828nck, i run cyclone box main module from here, the soft detects the box in main mode and beguin the self test, but when i try to unlock, always error BB5 Unlock Failed -> Failed to Boot / Prepare Phone What is the problem? |
The Following User Says Thank You to rmarratia For This Useful Post: |
08-27-2009, 11:18 | #21 (permalink) |
Member: 48936 Status: Offline Thanks Meter: 20 | Finally solved. The problem was, after uninstall cyclone, donīt delete cyclone folder First uninstall cyclone. Second delete folder c:archivos de programa/cyclone after that, follow exactly instructions from here: http://forum.gsmhosting.com/vbb/showthread.php?t=705358 And now cyclone is working OK. |
09-12-2009, 08:22 | #23 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 50
Member: 178616 Status: Offline Thanks Meter: 90 | cyclone box give this error after upgrading hi plz help me yesterday i upgrade my box to new active super dct4 .activate ok and used 50 credits and after that my box not connecting for rpl service and always give eror when check credits.... this error Cyclone Server Send Command Error -> Code: 500, Box is not registered, support is not allowed then Failed to Check Credits -> Server transaction failed plz help me how to solve this problem |
09-12-2009, 08:59 | #24 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | Quote:
10-02-2009, 12:44 | #30 (permalink) |
Freak Poster Join Date: Aug 2005 Location: india. Age: 52
Member: 173509 Status: Offline Sonork: 100.1584320 Thanks Meter: 96 | hi supporter pls solve this,:::Initializing security card... Security Card Reset Error -> Possible error: Unknown error 0x4E Initialization has failed -> Security card was not found!"" i always get this error.when try for 10-15 times its start sometime.sometime after get info from the phone when try to flash suddenly it gives this error.i follow all instruction.now im tired with this box.i dont understand where is problem.so pls give me some accurate guideline to solve this problem. anyway thanx. br:shabbir-cellcare. |
problem with my cyclone box.box is not in needed mode | samih127 | Cyclonebox | 18 | 06-12-2010 06:05 |
Box is not in needed mode [SOLVED] | renren | Cyclonebox | 2 | 01-19-2010 22:38 |
::solve:: box is not in needed mode | mr khalid | Cyclonebox | 6 | 09-15-2009 08:36 |
Cyclone team (not connected) box is not in needed mode | tims | Cyclonebox | 17 | 06-29-2009 03:54 |
Box is not in needed mode. | masterunlock | Cyclonebox | 5 | 03-24-2009 16:44 |
