Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 06-21-2009, 11:39   #1 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow What is Mcnpro Box ? F.A.Q All in one Thread (Update 11-11-2011)
Mcnpro Box F.A.Q All in one Thread:
What is Mcnpro box ?
McnPro Box is Professional Phone Software Solution, the best software for china mobile .
  • Support all chinese mobile chips such as MTK, ADI/AD, Spreadtrum, Skyworks, TI(Texas Ins), Infineon, AGERE, OM(Philips), Anyka, CDMA etc.
  • Pinfinder was included, Support automatical identification ,Scan the phone's pinouts definition in few seconds.
  • Built-in USB detection chip which make USB detection the phone more fast and more accuracy.
  • Negative / positive can be converted fully automated. It is more convenient to detect tail socket.
  • High speed serial port PL2303 and FT232 and 24pins COM which makes route unlimited.
  • Scan VCC, GND, TXD, RXD and high-voltage startup route (or low-voltage startup route).
  • Perfect over-voltage protection hardware design
  • Standalone software (no Internet connection required)
  • Chinese USB stand mode mobile phone feature supported for future
  • Automatic box hardware upgrade /repair function supported
  • It is a unibox so such some free software you can direct use
MTK(Mediatek) CPU
  • All MTK CPU based models support
  • Write/Read (Backup) Full flash for phones
  • Write/Read (Backup/ Restore) NV data for phones
  • Write/Read eeprom for phones(MTK Nor flash)
  • Write/Read firmware for phones(MTK Nor/Nand flash)
  • Smart Write function fast for flash phones(MTK Nor)
  • Automatic fix SMS backdoor (First in the world)
  • Normal Format phone(Can backup LCD data before format)
  • Manual Format phone(Can backup LCD data before format)
  • Safely Format (SSF) phone(Can backup LCD data before format)
  • Touchscreen calibration (repair phones with damaged touchscreen)
  • Can backup LCD data before format after write LCD data back to fix calibration issue
  • Can repair "No licensed to produce"
  • Direct unlock User/Pf code for phones
  • Direct read unlock User/Pf code from firmware, no need connect phone
  • Automatic firmware version detection and save original firmware version information in Log file during flash/format
  • Automatic CPU/ Chips infomation detection
  • Automatic repair/recalculate security area
  • Upgrade/downgrade phone firmware
  • Repair software-related problems
  • Via flash to repair dead phones
  • Repair "Bad Software" fault for all MTK Cpu based models
  • Can Empty board flashing(After flash chip replacement)
  • Save operation process results in Log file
  • Can backup/write Phone book by txt file
  • Reset phone settings to defaults (factory state)
  • Read/write IMEI for all MTK based models
SPD(Spreadtrum) CPU
  • All Spreadtrum CPU based models support
  • Format phone automatic or manual format both support
  • Direct unlock User code phones
  • Direct read unlock User code from firmware, no need connect phone
  • Reset phone settings to defaults (factory state) when flash
  • Read/write IMEI for all SPD based models during flash
  • Read Phone book direct from file
INF(Infineon) CPU
  • 7850 7870 7880 Infineon CPU based models support
  • Automatic repair/recalculate SIM LOCK
AGE(AGERE) CPU
  • AGERE CPU based models support
Anyka CPU
  • 3224 CPU based models support
Si4904 CPU
  • AMD/SAMSUNG INTEL CPU based models support
  • Allow don't change IMEI during flash
ADI/AD CPU
  • MSP430 Herc/Hermes CPU based models support
SKY(Skyworks) CPU
  • SKY CPU based models support
TI (Texas Ins) CPU
  • TI CPU based models support
OM (Philips) CPU
  • OM(Philips) CPU based models support. eg, 5212UP etc
CDMA (QUALCOMM)
Mstar CPU
  • Write/Read (Backup) Full flash (Nor/Nand) for phones
  • Format phone by automatic or manualy
  • Read/write IMEI (First in the world)
AD6905 CPU
  • Read/write IMEI for all AD6905 based models
About ChinaRes Editor:
This is free solution for all mcnpro box customer,Can edit your China mobile phone resource, like Language、Ringtons、Photos and Fonts, Working for China Phone Platforms like MTK、 Spreadtrum etc.
Feature:
  • Spreadtrum (Nand、Nor), MTK Supported
  • Translation by dictionary
  • Manual translation
  • Change language name in the phone menu
  • UNICODE Supported
  • Media (Photos Ringtons)and fonts Import & Export
  • Edit (Customize) Language
Package content :
- 1 pcs Mcnpro box.
- 48 pcs cable.
- 1 pcs 9V DC.
The Following 25 Users Say Thank You to Mcnbox For This Useful Post:
Old 03-23-2011, 10:33   #2 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
A : How to Install Mcnpro Box ?
B : How to activation support download section ?
  • You need register a account at support site
  • You need have a Mcnbox team Products . Eg, Mcnpro Box
  • Go to Activation page input the Box serial number (Input like MCN*************)and activation code(Input like ****-****-****-****-****), Choose your reseller ,then Press activation , everything done!
  • About Installation Serial Number
  • The Serial Number of the software is printed on a label on the back-side of the Mcnpro Box.
  • Note don't sharing it on public internet or anywhere else, it used to activate the box-related freatures !
C : How is Chinese mobile working with Mcnpro Box ?
D: Other related information for Mcnpro Box
MTK format info:
For MT6253 CPU before you format , we are high recommend backup NV data first
  • 2M: start at 1C0000, length 40000
  • 4M:start at 3F0000, length 10000
  • 4M:start at 380000, length 80000
  • 8M-1M:start at 700000, length 100000
  • 8M(For 0.5M):start at 780000, length 80000
  • 16M(For 2M):start at E00000, length 200000
  • 16M(For 1.5M):start at E80000, length 180000
  • 16M(For 1M): start at F00000, length 100000
  • 16M(For 0.5M):start at F80000, length 80000
  • 16M:start at E50000 , length 1A0000
MT6228
  • 64M: start at 2000000 , length 2000000
  • 128M:start at 2000000 , length 6000000
  • 132M:start at 2000000 , length 6000000
SPD 6600D
  • 8M: start at 700000 , length 7FFFFF
  • 16M:start at E00000 , length FFFFFF
Best regards !
Mcnbox
If you still have some problem of that , please send email to Mcnbox[at]yahoo.com.
The Following 4 Users Say Thank You to Mcnbox For This Useful Post:
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.16625 seconds with 9 queries
