09-10-2011, 19:54 | #1336 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
09-16-2011, 05:28 | #1339 (permalink) |
Junior Member Join Date: Jul 2008
Member: 817864 Status: Offline Thanks Meter: 1 | i have a problem with my iphone 4 when i put it on charge it turns on when i pull out the cable it goes off i have tried changing the battery but still it dosent work do you have any idea what it could be and if possiable could u please post the power ways from battery thankyou |
09-17-2011, 10:43 | #1342 (permalink) |
Junior Member Join Date: Apr 2006
Member: 257405 Status: Offline Thanks Meter: 7 | ipod touch 4th gen hello sir, i have an ipod touch 3rd gen no power but when i replace a new batt it will works. but the problem is canot connect into itunes and could not recognize charger. can you give me an idea about this problem? tnx in advance........ |
09-19-2011, 07:31 | #1343 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Bangkok Thailand
Member: 830167 Status: Offline Thanks Meter: 82 | 3GS 8GB was water damaged. Its work well except no accept charges by and sources. Try to replace new Dock flex module or even working housing also the same result. Only show pop up the message ""charging is not supported with this accessory". Magnified the 2 Mosfet, there are the new version of handling circuit that have no the diagram. (see the picture) Anyone can advice, How to handle? |
09-19-2011, 10:17 | #1344 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1631564 Status: Offline Thanks Meter: 0 | 3gs no wifi adress hi after resolved the simcard connector/contact i have a 3gs without the wifi adress it is gree in settings and the blootooth is also gree ? how can i fix it? where is the Wifi IC . |
09-19-2011, 12:32 | #1346 (permalink) |
Member: 830167 Status: Offline Thanks Meter: 82 | Dear Wites, It was dried when come to my. But the dirty (flaky white fungus) is in mosfet area / LCD conn#1 / 3G PA / wifi hold (pic#3) / backlight fuse from 109IC and also some abit on dock conn#4. Also battery swelling like a balloon. but did replace the new batt. I think all over the board border was wet. I wash by sovent in ultrasonic pot almost 7-8 times. Remain only charging problem, It may be some parts discontinue but I can not recognize the new re-version of circuit diagram/board layout changed. Thanks, |
09-19-2011, 12:42 | #1347 (permalink) | |
Then you will try to make jumper.There are 4 prints see how they are connected on board.And post | |
09-20-2011, 07:05 | #1348 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1658206 Status: Offline Thanks Meter: 0 | I have a 3Gs 32gb water, or rather beer damaged, at first it did nothing except heat the battery. I cleaned it with a ultrasonic cleaner, replaced the battery, charge connector and LCD. now all except wifi is greyed and bluetooth is scanning but not finding anything. My question is: is reflowing the next step and which components do I need to replace if nay? |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
