11-10-2016, 17:06 | #46 (permalink) |
Junior Member Join Date: May 2007
Member: 514209 Status: Offline Thanks Meter: 6 | easy jtag error i am using win 8 can it possible this error becoz of that please help thanks in advance |
The Following User Says Thank You to nikhilmahale For This Useful Post: |
03-21-2017, 14:54 | #47 (permalink) | |
Freak Poster Join Date: Jan 2010 Age: 14
Member: 1214273 Status: Offline Thanks Meter: 136 | Quote:
The Following User Says Thank You to online-nokia For This Useful Post: |
05-01-2017, 06:19 | #48 (permalink) |
Junior Member Join Date: Mar 2016 Location: peshawer pakistan
Member: 2551593 Status: Offline Sonork: 100.1677645 Thanks Meter: 24 | Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0D000xxxxxxxxxxx, ,FW Ver.: 01.58 CMD Pullup Level:3186 mV CMD Active Level:3248 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. |
The Following User Says Thank You to altafgsm For This Useful Post: |
05-02-2017, 09:43 | #49 (permalink) |
Junior Member Join Date: Mar 2016 Location: Маха&#
Member: 2553586 Status: Offline Thanks Meter: 0 | Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 10009018080F5578, ,FW Ver.: 01.58 CMD Pullup Level:2691 mV CMD Active Level:2774 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Ready Timeout Error [Box Internal Failure] Done. Help!!! |
05-02-2017, 10:02 | #50 (permalink) | |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Quote:
Please, disconnect everything from box output and try to detect eMMC. If get same error, means box pcb soldering problem. Best Regards | |
05-12-2017, 17:47 | #52 (permalink) |
Junior Member Join Date: May 2017
Member: 2715451 Status: Offline Thanks Meter: 1 | Please the teacher ,,, I am new user easy jtag ,,, I bought this box to fix hp oppo ,, but i have difficulty to use direct emmc always out read cmd eror ,,, what box is not support or there is problem? Its support chart that there is a pinout for oppo r1001 ... Always out reading I've tried full upp resitor 100 ohm to d.o and cmd, but the result remains the same |
05-13-2017, 04:15 | #53 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | [QUOTE=hari nugroho;12496130]Please the teacher ,,, I am new user easy jtag ,,, I bought this box to fix hp oppo ,, but i have difficulty to use direct emmc always out read cmd eror ,,, what box is not support or there is problem? Its support chart that there is a pinout for oppo r1001 ... Always out reading I've tried full upp resitor 100 ohm to d.o and cmd, but the result remains the same[/Q do you use adopter? if yes then what is the model? |
05-23-2017, 09:02 | #54 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: Esam Telecom Age: 43
Member: 696206 Status: Offline Sonork: 100.1597401 Thanks Meter: 262 | Quote:
CMD Pullup Level: 1567 mV CMD Active Level: 2371 mV Can't init device. Reason: CARD Data FIFO Timeout Error HiPower mode is OFF CMD Pullup Level: 2103 mV CMD Active Level: 2536 mV EMMC Device Information : EMMC CID: 90014A483847347592010535540A34AA EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture Name: SKHYNIX EMMC NAME: H8G4u , S/N: 0535540A , rev. 01 EMMC NAME (HEX): 483847347592 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H8G4u_0535540A_20170522_135935.extcsd EMMC Init completed. Error reading at address: 000000000000 ... Retry #1 GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 Partition: nvram, [000000800000 - 000001000000], size: 000000800000 Partition: lk, [000001000000 - 000001200000], size: 000000200000 Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 Partition: secro, [000001400000 - 000001B00000], size: 000000700000 Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 Partition: EFS, [000002800000 - 000003000000], size: 000000800000 Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 Partition: recovery, [000005800000 - 000006800000], size: 000001000000 Partition: boot, [000006800000 - 000007800000], size: 000001000000 Partition: md1img, [000007800000 - 000009800000], size: 000002000000 Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000 GPT header successfully parsed Brand = samsung Model = SM-G532G Phone platform = mt6737t Mediatek platform = MT6737T Android release = 6.0.1 Firmware version = MMB29T.G532GDXU1APJ7 Firmware date = Wed Oct 26 23:36:39 KST 2016 | |
09-23-2018, 12:32 | #58 (permalink) |
Freak Poster Join Date: Dec 2014 Location: RAJSHAHI
Member: 2308219 Status: Offline Sonork: 100.1657074 Thanks Meter: 36 | Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 Mhz Can't init device. Reason: CMD Timeout Error |
09-23-2018, 16:31 | #60 (permalink) |
No Life Poster Join Date: Feb 2014 Location: Live on earth
Member: 2133627 Status: Offline Sonork: 100.1611605 Thanks Meter: 36 | Setting interface to EasyJtag2/ISP Setting bus width to 4 Bit Setting frequence to 24 Mhz CMD Pullup Level: 1837 mV CMD Active Level: 1888 mV Can't init device. Reason: CMD Timeout Error |
