09-16-2014, 19:45 | #16 (permalink) | ||
No Life Poster Join Date: Jan 2013 Location: India
Member: 1873645 Status: Offline Thanks Meter: 977 | Quote:
you atteched any power device ? like usb ,charger ,battery ? if no then 1. Must Check Power Wire Vcc and Vccq.( if you are using eMMC adptor then give usb power into adptor.) 2.check eMMC for heat . 3.if still same and mobile is dead then replace new eMMC. 4.if you still got then check adptor power volt.or change and check. | ||
The Following 2 Users Say Thank You to laxmi kamlesh For This Useful Post: |
09-17-2014, 09:49 | #17 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
The Following User Says Thank You to .:MobileLife:. For This Useful Post: |
09-21-2014, 09:27 | #18 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | U ARE WRIGHT ,,BEFORE IT WAS DETECT ,BUT NOW, WITH ERROR,,,,I REPAIR NO PRODUCT NAME,,,,,BUT WHEN WRITE PIT ,NOW DEAD,,,GIVING EROR helo,,,any one,,how to recover a complete dead,i9300 CMD Pullup Level:1103 mV CMD Active Level:1423 mV eMMC Device Information EMMC CID : 15010056545530304DF12238722A7FC0 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 574124586 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_ 574124586_20140806_2314.extcsd Done. |
The Following User Says Thank You to alkhaleejmobile For This Useful Post: |
09-21-2014, 09:28 | #19 (permalink) |
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | NOW,,CAN NOT CONNECT ,,ALL WIRE ARE OK, TESTED ,WITH GLASS,, Z3X EasyJtag Software ver. 1.6.1.3 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 18FFF002C97B1C3B, ,FW Ver.: 01.50 CMD Pullup Level:1185 mV CMD Active Level:1557 mV Can't init EMMC, Reason: CARD Operation Condition Timeout Error =================================== Done. |
10-31-2014, 19:32 | #20 (permalink) |
Freak Poster Join Date: Jul 2013 Location: OMAN UAE
Member: 1982525 Status: Offline Sonork: 100.1619259 Thanks Meter: 45 | i try connect s3 no product name so like this Z3X EasyJtag Software ver. 1.5.1.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 171xxxxxxxxxxx, ,FW Ver.: 01.50 CMD Pullup Level:1381 mV CMD Active Level:1825 mV Can't init EMMC, Reason: CARD Operation Condition Timeout Error =================================== Done. what problem ,pls help me all user and supporter. Report Post |
The Following User Says Thank You to shakil+ For This Useful Post: |
11-23-2014, 08:52 | #21 (permalink) | |
No Life Poster Join Date: Sep 2013 Location: Kotla Arab Ali Khan(PAK)
Member: 2016954 Status: Offline Thanks Meter: 345 | Quote:
The Following 2 Users Say Thank You to GsmKotla For This Useful Post: |
11-24-2014, 19:44 | #22 (permalink) |
Member: 1982525 Status: Offline Sonork: 100.1619259 Thanks Meter: 45 | im also done this problam Can't init EMMC, Reason: CARD Operation Condition Timeout Error error reason 1.wrong sold 3.3v vcc |
12-04-2014, 19:35 | #23 (permalink) |
No Life Poster Join Date: Jan 2005 Location: ALGERIA Age: 53
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | Z3X EasyJtag Software ver. 1.6.5.3 Loading eMMC Addon Firmware... IO: 2850 mV Box S/N: , ,FW Ver.: 01.50 CMD Pullup Level:948 mV CMD Active Level:1433 mV Can't init EMMC, Reason: CARD Operation Condition Timeout Error =================================== Done i think pinout Vcc= 1.8v is wrong |
The Following User Says Thank You to recan21 For This Useful Post: |
12-04-2014, 19:37 | #24 (permalink) |
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | try to use this one : http://img-cdn.filefactory.com/embed/m/6dt1uyw4ovyn.png all ok device is connected : CMD Pullup Level:1969 mV CMD Active Level:2093 mV eMMC Device Information EMMC CID : 15010041464541424200BC002E7E30BA EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 03/2013 Rev.0x0 EMMC NAME: AFEABB , S/N: 3154128510 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB Extended CSD rev 1.7 (MMC Unknown) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: AFEABB_3154128510_20141104_1934.extcsd Done. |
01-19-2015, 17:41 | #25 (permalink) |
Freak Poster Join Date: Jan 2007 Location: karor lal-esan pakistan
Member: 427028 Status: Offline Sonork: 100.1639042 Thanks Meter: 63 | sm-n9005 emmc error how to sloved this error Z3X EasyJtag Software ver. 1.6.6.7 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 09006xxxxxxxxxxx, ,FW Ver.: 01.51 CMD Pullup Level:1742 mV CMD Active Level:1742 mV Can't init EMMC, Reason: CMD Timeout Error |
03-17-2015, 11:03 | #26 (permalink) |
Freak Poster Join Date: May 2002 Location: dubai
Member: 11945 Status: Offline Thanks Meter: 76 | Z3X EasyJtag Software ver. 1.7.0.1 Loading eMMC Addon Firmware... IO: 2850 mV Box S/N: 0C0C04221B4007FF, ,FW Ver.: 01.51 CMD Pullup Level:2186 mV CMD Active Level:2629 mV eMMC Device Information EMMC CID : 15010056545530304DF1CD2017185F74 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 3441432344 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3441432344_20150202_1155.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 1.7.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2186 mV CMD Active Level:2629 mV EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_3441432344_20150 202_1155.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 1.7.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2186 mV CMD Active Level:2629 mV Writing... Done! Done. Please don't forget to repair extCSD from backup!!! Processing file...C:\Users\admin\Desktop\sm-g7102 boot\N7100_ROM1_Alive_Dump_BN\N7100_Rom1_Alive_Dum p_BN.bin Z3X EasyJtag Software ver. 1.7.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2186 mV CMD Active Level:2629 mV Input file : C:\Users\admin\Desktop\sm-g7102 boot\N7100_ROM1_Alive_Dump_BN\N7100_Rom1_Alive_Dum p_BN.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Retry writing adress 0x00000000 (Attempt #1)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail !!! Write Block Failed, Reason: DATA SND CRC Error whats the problem? |
The Following User Says Thank You to badi For This Useful Post: |
03-19-2015, 09:19 | #28 (permalink) |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, Please show full log. Also try to write something into ROM1. eMMC interna firmware possibly damaged, need to see full log. Also, please press Advanced Opt->Custom Operation->Read S.M.A.R.T. Report and show log. Best Regards |
The Following User Says Thank You to vikboston For This Useful Post: |
03-19-2015, 09:49 | #29 (permalink) | |
Freak Poster Join Date: Dec 2008
Member: 930047 Status: Offline Thanks Meter: 52 | Quote:
now doing rom1 Z3X EasyJtag Software ver. 1.8.1.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0D0D0F1A515EF444, ,FW Ver.: 01.52 CMD Pullup Level:2052 mV CMD Active Level:2237 mV eMMC Device Information EMMC CID : 90014A2058494E5948140CCBAAB010E6 EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2013 Rev.0x14 EMMC NAME: , S/N: 214674096 EMMC NAME (HEX): 0058494E594800 EMMC ROM1 (Main User Data) Capacity: 2296 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: _ 214674096_20150204_1416.extcsd Done. Checking NAND Image : D:\3.z3x\9. Easy Jtag files\HTC\DESIRE_V_T328W\HTC_Desire_V_T328W_Full_D ump_Ok\T328W KMSJS000KM-B308.boot1 File successefuly loaded! Checking NAND Image : D:\3.z3x\9. Easy Jtag files\HTC\DESIRE_V_T328W\HTC_Desire_V_T328W_Full_D ump_Ok\T328W KMSJS000KM-B308.bin File successefuly loaded! Processing file...D:\3.z3x\9. Easy Jtag files\HTC\DESIRE_V_T328W\HTC_Desire_V_T328W_Full_D ump_Ok\T328W KMSJS000KM-B308.bin Z3X EasyJtag Software ver. 1.8.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2052 mV CMD Active Level:2237 mV Input file : D:\3.z3x\9. Easy Jtag files\HTC\DESIRE_V_T328W\HTC_Desire_V_T328W_Full_D ump_Ok\T328W KMSJS000KM-B308.bin Writing 00E9000000 bytes to 00000000 ...ROM1 (USER ROM) Write Length has been corrected to 0x008F800000 bytes... | |
The Following User Says Thank You to vasimj For This Useful Post: |
03-21-2015, 04:41 | #30 (permalink) |
Junior Member Join Date: Aug 2008
Member: 832152 Status: Offline Sonork: 1897 Thanks Meter: 3 | Z3X EasyJtag Software ver. 1.8.1.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0EFxxxxxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:1113 mV CMD Active Level:1608 mV Can't init device, Reason: CMD Timeout Error Done. why?? |
