12-05-2017, 05:42 | #31 (permalink) |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | need help for J100h i am new user of easy jtag user i was try to repair j100h boot repair but show this Can't init device. Reason: CMD Timeout Error how can solve it pls help me thxxxxx |
12-05-2017, 06:04 | #32 (permalink) |
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0C004001E1xxxxxx, ,FW Ver.: 01.60 CMD Pullup Level:2155 mV CMD Active Level:3227 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. |
12-06-2017, 18:54 | #35 (permalink) |
Junior Member Join Date: Dec 2017 Location: iran-sari
Member: 2786231 Status: Offline Thanks Meter: 6 | Hi Yes your problem is voltag You need to check all voltag in vccq or vcc Vccq ... 1.8 to 3.0 Vcc ..2.8 ..to 3.3 Please test this voltag If dont work tell me again |
12-14-2017, 12:25 | #36 (permalink) |
Freak Poster Join Date: Sep 2006 Location: BANGLADESH
Member: 342931 Status: Offline Sonork: 100.1659224 Thanks Meter: 83 | j100h dead boot repair ok but no power samsung j100H software dead. dead boot repair success, but no power. still dead.please help me any one. |
12-14-2017, 14:51 | #37 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
12-27-2017, 12:36 | #40 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | tried to write boot 1-error as below Checking NAND Image : C:\Users\Admin\Desktop\10.MEDUSA\Z3X EASY JTAG SHORT CUTS\J100H DS\SAMSUNG_SM-J100H-KTU84P.J100HXXU0AOB4\Samsung_SM-J100H-KTU84P.J100HXXU0AOB4\boot1.bin Autodetected RAW data File successefuly loaded! Partition table scan: GPT: not present why this error """"GPT not present""" HOW FIX IT? |
12-28-2017, 04:58 | #41 (permalink) |
Member: 946381 Status: Offline Thanks Meter: 150 | j100h boot dead-emmc info posted-help me emmc info as below ---------- eMMC Device Information ---------- EMMC CID : 90014A483447326211010ED8E61432FA EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 03/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 249095700 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _ 249095700_20171228_0902.extcsd Done. emmc flashing tried-error as in below link http://forum.gsmhosting.com/vbb/f672...-help-2313839/ what i do as a next step? |
01-17-2018, 16:55 | #42 (permalink) |
Freak Poster Join Date: Jan 2015 Location: chandpur,bangladesh
Member: 2332758 Status: Offline Sonork: 1663896:GsmShafaiT Thanks Meter: 152 | EasyJtag Suite Classic ver.: 2.9.0.1 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 10 (build 10586), 64-bit edition. Admin rights FAIL Android Explorer ver:1.0.0.23 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.11.2 QUALCOMM Direct ver:1.0.6241.462 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA72-475B , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2660 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2122.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2660 mV Box IO Level:2800 mV CLK Rate:21000 kHz This eMMC is not Samsung! Hold Shift during operation to skip this check Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2660 mV Box IO Level:2800 mV CLK Rate:21000 kHz EMMC ROM2/3 (Boot Partitions) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2128.extcsd Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2128.extcsd Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2128.extcsd Done. Running:eMMC: Factory Format... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz Formatting eMMC card, please wait up to 3 min... Setting Service Mode... eMMC Format Done. Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz This eMMC is not Samsung! Hold Shift during operation to skip this check Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz This eMMC is not Samsung! Hold Shift during operation to skip this check Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz Sending Smart Wipe Request... Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Running:eMMC: Factory Format... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz Formatting eMMC card, please wait up to 3 min... Setting Service Mode... eMMC Format Done. Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2130.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz This eMMC is not Samsung! Hold Shift during operation to skip this check Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz EMMC ROM2/3 (Boot Partitions) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Running:eMMC: Factory Format... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz Formatting eMMC card, please wait up to 3 min... Setting Service Mode... eMMC Format Done. Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2132.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:21000 kHz This eMMC is not Samsung! Hold Shift during operation to skip this check Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:21000 kHz EMMC ROM2/3 (Boot Partitions) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2133.extcsd Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2133.extcsd Partition table scan: GPT: not present Done. extCSD file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\H4G2b _2165950698_20170316_1248.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:21000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x08] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 4.5 Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2134.extcsd Partition table scan: GPT: not present Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2134.extcsd Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1784 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2134.extcsd Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2134.extcsd Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2137.extcsd Done. Running:SAMSUNG: Remove Write Protection... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:1000 kHz This eMMC is not Samsung! Hold Shift during operation to skip this check Done. Running:SAMSUNG: Remove Write Protection... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:1000 kHz This eMMC is not Write Protected! Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:1000 kHz This eMMC is not Samsung! Hold Shift during operation to skip this check Done. extCSD file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\H4G2b _2165950698_20170316_1248.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:1000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x08] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 4.5 Done. Checking NAND Image : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM1_H4G2b_2165950698_00000000_100 00000.bin Autodetected RAW data Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Real (Hardware) Disk/Image size: 80000 sectors 256.0 MiB Soft (Partitioned) Disk/Image size: 743FBC sectors 3.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 7618526 Checking NAND Image : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM1_H4G2b_2165950698_00000000_100 00000.bin Autodetected RAW data Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Found ROM2 and automatically selected. Found ROM3 and automatically selected. Found EXT CSD and automatically selected. Real (Hardware) Disk/Image size: 80000 sectors 256.0 MiB Soft (Partitioned) Disk/Image size: 743FBC sectors 3.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 7618526 Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\H4G2b _2165950698_20170316_1248.extcsd Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM1_H4G2b_2165950698_00000000_100 00000.bin Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM2_H4G2b_2165950698_00000000_004 00000.bin Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM3_H4G2b_2165950698_00000000_004 00000.bin Running:Repair extCSD... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:1000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x08] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 4.5 Done. Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2681 mV Input file : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM1_H4G2b_2165950698_00000000_100 00000.bin Writing 0010000000 bytes to 0000000000... ROM1 (USER ROM) Write Block Failed, Reason: Write Block Verify Error Done. Done with error(s) Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2681 mV Input file : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM2_H4G2b_2165950698_00000000_004 00000.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done, time taken: 34 sec. Average Write Speed: 121 kB/s Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1794 mV CMD Active Level:2681 mV Input file : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM3_H4G2b_2165950698_00000000_004 00000.bin Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Done, time taken: 34 sec. Average Write Speed: 121 kB/s Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2681 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2141.extcsd Partition table scan: GPT: not present Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1794 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2142.extcsd Partition table scan: GPT: not present Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1784 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2143.extcsd Partition table scan: GPT: not present Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04FFB0077E49AA42, ,FW Ver.: 01.62 CMD Pullup Level:1804 mV CMD Active Level:2660 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101F252D2781248 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 4065514104 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _4065514104_20180117_2144.extcsd Partition table scan: GPT: not present Done. Checking NAND Image : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM1_H4G2b_2165950698_00000000_100 00000.bin Autodetected RAW data Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Found ROM2 and automatically selected. Found ROM3 and automatically selected. Found EXT CSD and automatically selected. Real (Hardware) Disk/Image size: 80000 sectors 256.0 MiB Soft (Partitioned) Disk/Image size: 743FBC sectors 3.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 7618526 Checking NAND Image : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM1_H4G2b_2165950698_00000000_100 00000.bin Autodetected RAW data Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Found ROM2 and automatically selected. Found ROM3 and automatically selected. Found EXT CSD and automatically selected. Real (Hardware) Disk/Image size: 80000 sectors 256.0 MiB Soft (Partitioned) Disk/Image size: 743FBC sectors 3.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 7618526 Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\H4G2b _2165950698_20170316_1248.extcsd Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM1_H4G2b_2165950698_00000000_100 00000.bin Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM2_H4G2b_2165950698_00000000_004 00000.bin Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM3_H4G2b_2165950698_00000000_004 00000.bin Running:Repair extCSD... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1804 mV CMD Active Level:2660 mV Box IO Level:2800 mV CLK Rate:1000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x08] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 4.5 Done. Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1804 mV CMD Active Level:2660 mV Input file : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM1_H4G2b_2165950698_00000000_100 00000.bin Writing 0010000000 bytes to 0000000000... ROM1 (USER ROM) Full Verify Enabled! Write Block Failed, Reason: Write Block Verify Error Done. Done with error(s) Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1804 mV CMD Active Level:2660 mV Input file : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM2_H4G2b_2165950698_00000000_004 00000.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Full Verify Enabled! Done, time taken: 68 sec. Average Write Speed: 61 kB/s Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1804 mV CMD Active Level:2660 mV Input file : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM3_H4G2b_2165950698_00000000_004 00000.bin Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Full Verify Enabled! Done, time taken: 68 sec. Average Write Speed: 61 kB/s Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\H4G2b _2165950698_20170316_1248.extcsd Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM1_H4G2b_2165950698_00000000_100 00000.bin Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM2_H4G2b_2165950698_00000000_004 00000.bin Processing file...F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM3_H4G2b_2165950698_00000000_004 00000.bin Running:Repair extCSD... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1804 mV CMD Active Level:2660 mV Box IO Level:2800 mV CLK Rate:1000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x08] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 4.5 Done. Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1804 mV CMD Active Level:2660 mV Length limit is enabled! Input file : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM1_H4G2b_2165950698_00000000_100 00000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Full Verify Enabled! Write Block Failed, Reason: Write Block Verify Error Done. Done with error(s) Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1804 mV CMD Active Level:2660 mV Input file : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM2_H4G2b_2165950698_00000000_004 00000.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Full Verify Enabled! Done, time taken: 68 sec. Average Write Speed: 61 kB/s Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1804 mV CMD Active Level:2660 mV Input file : F:\SAMSUNG\J-SERIES\J100H\BOOT REPAIR FILE\J100H\EMMC_ROM3_H4G2b_2165950698_00000000_004 00000.bin Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Full Verify Ena |
01-27-2018, 12:58 | #43 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Error: eMMc has a small size / The size of the last section was not update Error: eMMc has a small size The size of the last section was not update how to solve this problem |
