iPad , iPod , Apple TV iPad 1 , iPad 2 , iPad 3 , iPad Mini , iPad 4 / iPod Classic , iPod Nano , iPod Touch / Apple TV |
06-15-2021, 21:59 | #16 (permalink) |
Freak Poster Join Date: Jan 2010 Location: türkiye
Member: 1207296 Status: Offline Sonork: 100.1609587 Thanks Meter: 74 | apple Now updates security patches but it won't happen later maybe there will be a solution soon (But for now the best method jailbreak and bypass method) restore original address then jailbreak and bypass attached file is available a thank you please. And thanks Waseem Tech.. https://mega.nz/file/IhYDwK4D#fVFG37...TAAZf9K1UwchMI |
The Following User Says Thank You to akkose_iletisim For This Useful Post: |
06-19-2021, 19:56 | #17 (permalink) |
Freak Poster Join Date: Nov 2011 Location: IRAN Age: 39
Member: 1691551 Status: Offline Sonork: 100.1622582 Thanks Meter: 53 | If your ipad is gsm first change to wifi remove board id resistor Device go to dfu mode Write wifi model sn bt mac Restore with wifi version Done |
06-24-2021, 19:44 | #18 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277735 Status: Offline Thanks Meter: 215 | If you remove resistor now you HAVE to change WiFi chip on air 2 up, the swap drivers dos not work anymore. Best way is just to bypass iPads, can get all functions without messing about, Apple will start to block SN change as they have on mini 4s. |
The Following User Says Thank You to P3T3 For This Useful Post: |
06-26-2021, 17:54 | #19 (permalink) |
Member: 1207296 Status: Offline Sonork: 100.1609587 Thanks Meter: 74 | All ipad icloud remove change sn purple mode ipad pro 1 9.7 ipad A1822/a1823 change wifi ic ipad air A1567/a1566 change wifi ic have All iapd sn number clean activaiton all ok www.kilityok.com |
The Following 2 Users Say Thank You to akkose_iletisim For This Useful Post: |
06-30-2021, 10:31 | #20 (permalink) | |
Member: 2277735 Status: Offline Thanks Meter: 215 | Quote:
Sorry A8 are blocked, yes can rite to all iPad but they wont activate, even with clean details! | |
06-30-2021, 16:56 | #22 (permalink) | |
Member: 1207296 Status: Offline Sonork: 100.1609587 Thanks Meter: 74 | Quote:
change sn number A8 for model: ipad air2/ipad mini4/ ipad mini 4 gsm change wifi ic/ipad 5 A1822/A1823 change wifi ic/ipad pro A1673/A1674 change wifi ic ipad pro 10.5/ann gsm change wifi ic/ipad 12.9 1 generation and gsm chang wifi ic/ ipad pro 12.9 2 generation and gsm change wifi ic all test ok ok ok ok ok | |
07-04-2021, 09:00 | #28 (permalink) |
Member: 2277735 Status: Offline Thanks Meter: 215 | |
07-04-2021, 12:41 | #30 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,131 | I mean even iPad WiFi only device can’t activate with new serial , is that bug fixed Ex : iPad Air WiFi only |
The Following User Says Thank You to Mr.3. For This Useful Post: |
