03-10-2007, 12:26 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: PAKISTAN
Member: 203615 Status: Offline Thanks Meter: 55 | 1110 signal drop i have nokia 1110 its signal drop after 5seconds 1 i used the differents pm fils but not solve 2 i changed the pa 3times but problem remain the same plz help with thanks with perfect solution zahid |
03-10-2007, 12:57 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: guangzhou,CHINA & delhi,INDIA
Member: 399779 Status: Offline Thanks Meter: 125 | first erase then flash with good pm..........if no good.....in some set i have also faced same problem where uem ic was at fault......luck bro |
03-11-2007, 08:48 | #4 (permalink) |
No Life Poster Join Date: Aug 2005 Location: SILIGURI Age: 46
Member: 170589 Status: Offline Thanks Meter: 1,848 | Did you write the good pm how do u know that was a good pm look i am giving you the good pm path your set will be 100%%%%%%%%%%%%%% ok just read the good pm from the running set it will ask for the starting adress put " 0 " and end adress " 66 " save it and write to urs damage phone it will be ok |
03-11-2007, 13:14 | #6 (permalink) |
Member: 203615 Status: Offline Thanks Meter: 55 | bro thanks all of them but my problem not solve read above post carefully in which i have already used the good pm 6times and also changed the pa 4times zahid |
08-30-2007, 19:06 | #11 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | Hi zahid use this PM because I also face same problem like this & solved by writing this file in 4 sets good luck |
1110 network drop in some second | Arjun mishra | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 12-26-2009 20:37 |
8210 ,signal drops . | ags28 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-15-2002 17:31 |
Signal Drop Solution for 6210 | schwantz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 03-26-2002 22:46 |
Repair signal dropping after IMEI ch! | gyuszko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-11-2002 15:35 |
3210 no signal dropped???? | eureka8888 | Nokia Hardware & Hardware Repair | 3 | 08-25-2001 19:13 |
