Old 07-05-2008, 05:26   #1 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
My Nokia Hardware Repairing Technics
1110,1112,1600,2310,2610,6030 SOME TIMES POWER ON,SOME TIMES BLUE DISPLAY,SOME TIMES HANG NOKIA LOGO
THIS HANDSETS SOFTWARE CONNECTING TIME MANY DIFFERENT ERROR SHOW.
ERROR1)
MCU ID: 0x2201
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: 25:06:2008 14:14 -> AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
BOOTING NOT COMPLETED
ERROR2)
MCU ID: 0x2201
chk Failed! Aborting!
ERROR3)
Cable is not good -> check for 68k resistor b/w bsi-gnd in connector and 3.3k resistor in serial with bsi line
ERROR4)
SOME TIMES SHOW
UPP DAMAGED OR UEM DAMAGE ERROR SHOW!!!!!!!!!!!
AM EXPLAIN HOW TO SOLVED THIS PROBLEM
1)FIRST CHECK EASY CABLE PORT
A)CLEAN OR CHANGE THIS CONNECTOR
B)CHECK PCB CONTECT PICTUER NUMBER-1
2)CHECK BATTERY CONNECTOR
A)RESOLDRING BATTERY CONNECTOR OR CHNAGE IT PICTURE NUMBER-2
3)CHECK BSI LINE
A)CHECK PICTURE NUMBER-3
4)CHECK BSI RESISTER
A)FIRST REMOVE THIS RESISTER THEN CONNECT SOFTWARE
B)SAME ERROR SHOW? CHANGE THIS RESISTER
The Following 229 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-05-2008, 05:27   #2 (permalink)
Member: 351924
5)CHECK SECOND LOCAL OSILLATOR 26Mhz CRYSTAL
A)CHNAGE THIS CRYSTAL
30%UEM PROBLEM
20%UPP PROBLEM
REGRADS
SHIJILFONOTLY&NEILTHIRUMUTTAM
NOKIA.REPAIR.MASTERS.TEAM
The Following 156 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-05-2008, 05:28   #3 (permalink)
Member: 351924
INSERT SIM SOLUTION 1110,1112,1600,2310,2610,2310
1)CHECK OR CHANGE BATTERY&SIM CARD----BOTH ITEAMS AFTER CHANGING SAME INSERT SIM PROBLEM?
2)OPEN HANDSET THEN CHECK THIS PARTS
A)BSI VOLTAGE MISSING PHONE SHOW INSERT SIM
B)CHECK EASY CABLE PORT OR PCB CONTCAT
C)CHECK VSIM LEG Ohms FIX MULTI METTER TO DIODE CHECKING MODE
a)(DIFFENT VALUE OHMS SHOW ABOVE 500ohms?----(VSIM VOLTAGE PREFECT)
b)(SAME VALUE OHMS SHOW?LIKE 200 Ohms TO 200 Ohms,(VSIM RELATED CAPACITOR SHOTAGE)40%UEM(REMOVE RED MARKED CAPACITOR)
c)NOT SHOW ANY VALUE Ohms?(UEM NOT GENARATE SIM VOLTAGE 100M PROBLEM)BUT ONE THINK VSIM PRINT MISSING NOT SHOW ohms
CHECK RED MARKED WAYS
The Following 123 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-05-2008, 05:28   #4 (permalink)
Member: 351924
D)REMOVE SIM IC THEN CHECK SIM CONNECTOR TO SIM IC WAYS
E)CHNAGE OR SHOT SIM IC
LAST CHECK UEM AND UPP
RESULT
1)SIM,BATTERY,SIM IC,SIMWAYS,CAPACITOR SHOTAGE ETC......65%
2)UEM............................................. ......20&
3)UPP............................................. ......15&
REGARDS
The Following 187 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-05-2008, 07:38   #5 (permalink)
Member: 351924
more Update Comming Soon Now Am Prepair Bb5 Handsets
The Following 30 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-05-2008, 10:14   #6 (permalink)
Member: 351924
brother this my repairing idea
1)POWER ON PHONE WITH SIM THEN GOTONETWORK SETTINGS OPTION AND USE MANNUL SEARCH OPTION.THIS TIME PHONE SHOW2 MESSAGES
1 IS NO NETWORK FOUND
2nd IS DETECTED ANY NETWORK PROVIDER NAME
1)NO NETWORK FOUND
60%HARDWARE
40%SOFTWARE
1)WRITE TESETED PM(PM FILE HERE)
2)CHECK AN****A OR AN****A PAD
3)REMOVE AN****A SWITCH THEN MAKE JUMBER LIKE THIS PICTURE
3)CHANGE RX&TX FILTER(BLUE MARKED)
4)CHANGE SECOND LOCALCRYSTAL NEAR IF IC(CAREFULL NET WORK IF IC GLUDE OVER HEAT DAMAGED THIS IC)RED MARKED
5)CHANGE FDKVCO
THIS ALL ITEAMS CHANED AND CHECKEDSAME PROBLEM?
60% UEM OR 40%UPP PROBLEM
THEN WHICH PROVIDER SIM USE SEARCHING TIME JUST SELECT AND REQUEST THIS NET WORK THIS TIME PHONE SHOW NET WORK NO ACCESS?
THIS HARDWARE PROBLEM BUT ONE THINK PM FILE PROBLEM SOME TIMES PHONE SHOW THIS ERROR(WRITE THIS PM)
1)REFLOW PA
2)CHANGE PM
75%PA PROBLEM
POST RESULT
The Following 88 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-12-2008, 11:25   #7 (permalink)
Member: 351924
1110,1110i,1112,1600,2310 NOT CHARGING STEP BY STEP REPAIRING WITH MY IDEA
1)CHECK OR CHANGE BATTERY OR CHARGER
2)SOME TIMES PM FILE PROBLEM PHONE SHOW NOT CHARGING
A)WRITE THIS PM
2)OPEN HANDSET THEN CHECK EASY CABLE PORT OR CHARGER SOCKET
A)CHANGE THIS PART
3)CHECK CHANGER INPUT RELATED ESD,CAPACITOR,FUSE AND COIL
4)CHECK BSI WAYS
The Following 64 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-12-2008, 11:25   #8 (permalink)
Member: 351924
5)REMOVE BSI LINE FILTER CAPACITOR NEAR BATTERY CONNECTOR
6)REMOVE BSI REALTED RESISTER THEN CHECK CHANGERING SAME NOT CHARGE SHOW FIX THAT RESISTER
7)CHNAGE THIS RESISTER LIKE THIS PICTURE
8)TRY TO CHNAGE BSI OR BTEMP RELATED RESISTER OR CAPACITOR
40% UEM PROBLEM PHONE SHOW NOT CHANRGING
The Following 93 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-24-2008, 16:02   #9 (permalink)
Member: 351924
Nokia N70 White Screen Reapiring Step By Step
TWO TYPES WHITE SCREEN PROBLEM
1St IS WHITE SCREEN FREEZED(non booted)
THIS TIME PHONE NOT BOOTED,POWER ON TIME JUST ENABLED DISPLAY&KEYPAD LIGHT ONLY
HOW TO CLEAR THIS PROBLEM--------AM EXPLAIN MY EXPERIANCE
A)CONNECT JAF,UFS OR MT BOX ETC.............
B)USE CHECK BUTTON
Booting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
Asic Public ID: C57A6C30A60BFE52D39FC1751D66A629FB40EB4E
HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101002200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 1E80000999865A516630285C29EAFDD6F54AA796
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
CMT Loader Ready
APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg
Loader version: 01.23.00 -> Revision: 0000
Patching APE boot step2...
APE Boot Ready
APE Flash ID: 00360098 <=> SAMSUNG -> Type not in database
APE Flash Data: 00020000000600000000000000000000
Done!
C)CHANGE PHONE MODE TO LOCAL MODE(WHITE SCREEN FREEZED PHONE MUST ENTER LOCAL MODE)
Changing mode...
Done!
D)THEN AGAIN CHANGED PHONE MODE TO TEST MODE(WHITE SCREEN PHONE NOT ENTER TEST MODE) BECOZ OMAP WORKING NOT PROPER
Changing mode...
Failed!!!
REPAIR SOLUTION
STEP1---CHECK IN PUT SMPS VOLTAGE(3.6VOLT)
A)THIS VOLTAGE MISSING? JUST MAKE THIS JUMBER
STEP2---CHECK DC/DC CONVERT COIL OUT VOLTAGE IN SAME VAULE(1.4VOLT-VCORE)
A)COIL OUT VOLTAGE NOT SHOW? CHANGE THIS COIL
STEP3---CHECK SMPS OUT PUT VOLTAGE(1.4VOLT-VCORE)
A)OUT VOLTAGE NOT SHOW? CHANGE THIS SMPS(50%SPMS PROBLEM)
STEP4---OMAP----30%
STEP5---RAP3G---20%
The Following 104 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-25-2008, 09:15   #10 (permalink)
Member: 351924
WHITE SCREEN,SOME TIMES POWER JUST SECONDS TRUN OFF,SOME TIME NOKIA LOGO HANGING ONLY SOLUTION HERE
B)USE CHECK BUTTON
Booting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Done!
SEE THIS FLASHING LOGO
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V11
CNT Flash file: NONE
APE Variant file: ?
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
Asic EM ID: 00000352
Asic Public ID: 0C800103D8654E5160FC20C285A16EB1C330C054
CMT Boot Ready
CMT Loader Ready
Operation took 0 minutes 6 seconds...
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!
THIS PROBLEM MAINLY SHOW 2 CHIP FAILING
APE DRIVER NOT DETECTED OR APE FLASH IC DAMAGE
A)APE DRIVER NOT GENARATE VDRAM(1.8V) VOLTAGE
SOLUTION
STEP1---CHECK VBATT WAYS
STEP2---CHECK APE DRIVER OUTPUT VOLTAGE C4206 TO V7602,C5000
CHANGE APE DRIVER
STEP----REFLOW OR REBALL COMBO MEMORY
50%APE DRIVER
40%COMBO MEMORY
10%OMAP
The Following 127 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-26-2008, 09:52   #11 (permalink)
Member: 351924
ufs solved nokia 1600,1110,1112,2310 etc.....network problem with software
how to check this model handset network problem HARDWARE OR SOFTWARE
see this video mannul
http://www.sendspace.com/file/k5m236
what is ur opinion
The Following 112 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-27-2008, 10:32   #12 (permalink)
Member: 351924
comming soon new model nokia same type solution
am prepairing now
The Following 37 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 08-03-2008, 09:25   #13 (permalink)
Member: 351924
Nokia N70 White Display (booted)
PHONE WHITE SCREEN BUT PHONE WORKING FINE(CALLING 100%OK)
SOLUTION STEP BY STEP
1)CHANGE DISPLAY
2)RESOLDRING OR CHANGE DISPLAY CONNECTOR
3)CHECK VI0(1.8V) OR VAUX(2.5V)
A)VIO 1.8VOLTAGE NOT SHOW MULTI METTER?
1)CHECK C4400 TO C2215 WAYS LIKE THIS PICTURE(WAYS ARE OK?)
2)CHECK OR CHNAGE L4400 COIL OR REMOVE C4400,C2215 CAPACITOR
3)AGIAN SAME VOLTAGE MISSING 100%RETU PROBLEM(VIO 1.8V GENARATED BY RETU)
REFLOW OR CHNAGE RETU
B)VAUX(2.5V) VOLTAGE NOT SHOW MULTI METTER?
1)CHECK C2216 TO C4401 WAYS LIKE THIS PICTURE(WAYS ARE OK?)
2)CHECK OR CHANGE L4401COIL OR REMOVE C4401,C2216 CAPACITOR
3)AGIAN SAME VOLTAGE MISSING 100%RETU PROBLEM(VAUX 2.5V GENARATED BY RETU)
VIO(1.8V)OR VAUX(2.5) prefect?
A) REFLOW OR CHNAGE Z4402 OR Z4403
B) SAME WHITE SCREEN PROBLEM AGAIN REMOVE 2 DISPLAY IC THEN CHECK DISPLAY CONNECTOR TO DISPLAY EMI WAYS
C)NOT SOLVED THIS PROBLEM 100%OMAP PROBLEM
The Following 92 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 08-03-2008, 12:56   #14 (permalink)
Member: 443790
Thanks Meter: 54
thanks sir please post vedio manual thanks
The Following 14 Users Say Thank You to ..::jothikrish::.. For This Useful Post:
Old 08-04-2008, 20:55   #15 (permalink)
Member: 675717
Thanks Meter: 125
B)USE CHECK BUTTON
Booting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
APE Boot Ready
Done!
Changing mode...
Done!
Changing mode...
Failed!!!
REPAIR SOLUTION
STEP4---OMAP----30%
STEP5---RAP3G---20%
N70 white screen incoming outgoing is ok.I set a original display.After four days white screen.Now i set set new one display everything is ok(also change both display ic).After 5 days customer cameback with white screen(every time in/outgoing ok).Agin i set a new one display and make n70 asusal white screen hang jumper.After 2 days white screen everything is ok.This condition what can i do.Help me
The Following 59 Users Say Thank You to manibul For This Useful Post:
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.37809 seconds with 10 queries
