09-28-2006, 23:42 | #92 (permalink) | |
Junior Member Join Date: Jul 2006
Member: 309290 Status: Offline Thanks Meter: 0 | Quote:
But I believe that if you use Zonly's version (page 5 of this thread, first post) you shouldn't need to play with modifying the btwsub.inf because he/she has already included every hardware to date. | |
05-08-2007, 17:10 | #93 (permalink) | |
Junior Member Join Date: May 2007
Member: 502890 Status: Offline Thanks Meter: 0 | Quote:
07-31-2007, 17:06 | #95 (permalink) | |
Junior Member Join Date: Jul 2007
Member: 557802 Status: Offline Thanks Meter: 0 | Quote:
I downloaded the exact version mentioned in the link above. Installed it. Did NOT do the patcher as for some reason, all worked well with the 5.0.1.1400 drivers. Pretty interesting (lame) to me that Jabra doesn't have vista support on their site for this adaptor. So... thanks adisor19 for taking the time to post. And for all other Vista users with Jabra adaptor, here's one confirmed working solution. | |
12-01-2007, 01:09 | #96 (permalink) |
Junior Member Join Date: Nov 2007
Member: 641444 Status: Offline Thanks Meter: 0 | Hello, I 've done step by step what phantasm4489 adviced. And i've got the error message : this installation package is not taken in charge by this kind of processor. My PC is a dell latitude D620. Could someone please help me ? |
12-01-2007, 02:37 | #97 (permalink) |
Member: 641444 Status: Offline Thanks Meter: 0 | In fact, i have no more this problem. But i have another question. If the bluetooth module of my PC doesn't support the A2DP profil, it's not possible to upgrade the module instead of using a bluetooth USB key ? Many thanks |
12-03-2007, 22:37 | #98 (permalink) |
Junior Member Join Date: Dec 2003
Member: 46369 Status: Offline Thanks Meter: 0 | its highly unlikely that the d620 built-in bluetooth module would not support a2dp at the hci hardware version level. It is a relatively new machine and if it is broadcom bases then version up to 5.1.0.1300 should load if configured well. It must only be the case of bluetooth stack support (which I think dell uses the toshiba stack but not sure).. |
05-15-2008, 15:28 | #99 (permalink) |
Junior Member Join Date: Sep 2006
Member: 353568 Status: Offline Thanks Meter: 0 | i am trieing to install my aiptek bt dongle since a few weeks without getting it working. i tried many diffrent drivers and followed many howtos from this forum but all with the same result. the device gets installed and has the name i entert in the .ini file. but the icon in the device manager still has this yellow "!". in the details of the device manager i can see a massage like "could not start device" (i have a german system so i don't know the exact message). all com-ports and bt-audio and this things are installed correctly. the bt-icon in the system tray stays always blue and red. i tried to update my xp to sp3. but still the same result please help me. |
Nokia PC Suite 6.70.22 and Widcomm 5.0.1.1400 | gsmBTjoco | Bluetooth-Software | 9 | 05-24-2009 10:39 |
Widcomm 5.0.1.802 | adisor19 | Bluetooth-Software | 121 | 05-24-2007 19:52 |
Widcomm 5.0.1.801 | luckyknight | Bluetooth-Software | 120 | 04-07-2007 13:12 |
Widcomm 5.0.1.1400/Dell truemoble 350 Error | kvernon | Bluetooth-Software | 1 | 04-05-2006 00:52 |
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 21:12 |
