04-01-2006, 13:00 | #49 (permalink) |
Junior Member Join Date: Mar 2006
Member: 243561 Status: Offline Thanks Meter: 0 | Re-posting, I'll post the link in about 30 minutes when its finished uploading. - Plowna Here you go. Last edited by plowna; 04-01-2006 at 14:09. |
04-09-2006, 10:54 | #50 (permalink) |
Junior Member Join Date: Dec 2003
Member: 46438 Status: Offline Thanks Meter: 0 | 5.0.1.1400 on Vista 5342? I have an HP bluetooth in my laptop that is not recognised (no driver) by Vista. I tried installing the 1400 stack, works fine, however any time I click "Start using Bluetooth" on the bluetooth systray icon (showing in white), i click Next-Next-Finish and RunDLL hangs and vista closes the wizard... is there anything I can do here? Maybe getting the integrated BT working with the MS stack? |
04-10-2006, 02:27 | #51 (permalink) |
Junior Member Join Date: Apr 2006
Member: 256916 Status: Offline Thanks Meter: 0 | I have meet a problem for x64 windows with this version. after installation, I want to setup PIM sync of phone with outlook, but the program could not find outlook, only outlook express listed in dropdown menu, does anybody meet this problem? In win32, I know its okay. |
04-11-2006, 02:34 | #52 (permalink) |
Member: 257354 Status: Offline Thanks Meter: 0 | hey whenever i install this or any other version of widcomm and restart my pc, i get an error message saying "BTTray.exe- Unable To Locate Component This application failed to start because BtBalloon.dll was not found. Re-installing the application may fix this problem" Reinstalling doesnt. any help please? Thanks. |
04-11-2006, 02:38 | #53 (permalink) |
Member: 257354 Status: Offline Thanks Meter: 0 | the 'bluetooth configuration' in control opened and it found my dongle. my phone also finds my pc! but BTTray.exe wont open because of the problem above. how can i get BtBalloon.dll? thanks. |
04-11-2006, 19:46 | #56 (permalink) |
Member: 239924 Status: Offline Thanks Meter: 0 | http://rapidshare.de/files/17725252/..._Jabra.7z.html - full version from jabra headphone. To russians: Дистрибутив на поверку оказался странноватым. Во-первых, после установки пишет, что не могу найти btballoon.dll, при этом в дистрибутиве есть bballoon.dll - простое перименование этого файла (непосредственно в дистрибутиве, еще до инсталляции) помогает. Далее при установке на систему с русской локалью пишет, что не могу загрузить btrez.dll - помогают два варианта. Взять эту библиотеку из более старой версии драйвера (там, где русского языка еще не было), но при этом часть меню не работает (в дистрибутиве штук 17 этих файлов под разные локали, ни ни один не приводит к нормальной работе русского языка - испанский, французский и так далее работают). Либо в regional and language options WinXP установить все в english и unated states (в том числе - язык для non-unicode программ) и только после этиого ставить драйвер. В этом случае он ставтся в англоязычном варианте и работает, но не проверял что будет, когда вернешь русскую локаль. Этот глюк, мне кажется, вызван все же патчером файлов - с этой версией он, похоже, работает некорректно. Файл License.dat, что здесь пробегал и есть на гсмхосте, дает триал-период в кучу дней, что тоже не есть хорошо, так как, насколько я слышал, при этом остается ряд функциональных ограничений. версия 1200 у меня работала нормально. Исходный дистрибутив, так как он шел на диске Jabra, я положил на ........ http://rapidshare.de/files/17725252/..._Jabra.7z.html Возможно по рузультатам экспериментов сделаю готовую патченную сборку, пока же не вижу в этом смысла - со старыми патчами все работает очень криво и нужно чтобы за дело взялись профессионалы, те кто делал патчеры для файлов и лицензии. |
04-12-2006, 10:41 | #57 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Iloilo City, The Philippines
Member: 8396 Status: Offline Thanks Meter: 2 | Wow, very helpfull... eer I don't understand a thing This is an English forum. Let's keep it that way please. Пожалуйста напишите на английском языке. OK? [Babelfish it for translation.] |
04-21-2006, 21:57 | #60 (permalink) |
Junior Member Join Date: Jan 2006
Member: 216783 Status: Offline Thanks Meter: 0 | Hey guys, I have the DBT-120 dongle from D-Link. I have downloaded the patched 1400 setup. I first removed my old software from the software list in config panel then rebooted and installed the patched anycom version. I removed the VID/PID from the list and after that I unplugged and plugged in again my dongle. It perfectly says DBT-120 dongle but it also shows enumerator thing and the bluetooth sign in my taskbar is red which isn't good. It says it's not intstalled and at advanced configuration via right mouse click on the pictogram and hardware I see my dongle as hardware but also it says at status: Inactive, how to get it active? Thanks a lot guys! |
Nokia PC Suite 6.70.22 and Widcomm 5.0.1.1400 | gsmBTjoco | Bluetooth-Software | 9 | 05-24-2009 10:39 |
Widcomm 5.0.1.802 | adisor19 | Bluetooth-Software | 121 | 05-24-2007 19:52 |
Widcomm 5.0.1.801 | luckyknight | Bluetooth-Software | 120 | 04-07-2007 13:12 |
Widcomm 5.0.1.1400/Dell truemoble 350 Error | kvernon | Bluetooth-Software | 1 | 04-05-2006 00:52 |
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 21:12 |
