08-21-2008, 08:02 | #16 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | http:///showpost.p...42&postcount=2 Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
08-21-2008, 09:33 | #18 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ chimeto, Check this link, please. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
08-30-2008, 18:20 | #19 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: -worldwide-
Member: 592460 Status: Offline Thanks Meter: 110 | Quote:
The importance is simple to have a working cable. It is very easy to build this cable. Just search this forum or even google to find the correct cable schematic. br | |
09-03-2008, 16:04 | #20 (permalink) |
Freak Poster Join Date: May 2001
Member: 4615 Status: Offline Thanks Meter: 0 | I know how the unlock procedure works I allready unlocked a lot of c115, c116, .... with smart clip but j100 doesnt work when I press unlock button on clip yellow led goes on but when I press power on button on phone smart clip went off an swiches on in start mode (green and red led) I tried 3 different cabels all factory made but nothing |
09-04-2008, 07:29 | #21 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ surfer2go, Does the battery of the phone fully charged? What power supply you use with the Smart-Clip? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-04-2008, 14:38 | #23 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ surfer2go, Please ensure that the power supply provides stable output, the cable work properly and run unlock procedure once again. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-05-2008, 20:12 | #24 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Germany
Member: 753732 Status: Offline Thanks Meter: 252 | Now i have buy this cable for J100i http://www.service4handys.de/index.p...G121/a_A001325 If i connect the J100i RJ45 cable to the Smart-clip, the Smart-Clip switches off, If i connect other Cable to the smart-clip everything is OK, Only with the J100i Cable. I cant unlock it... I use a universal Adapter with 7,5 , 9 , 12 V , |
09-06-2008, 08:43 | #25 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ powerplay83, More likely that the cable you have is faulty. Did you try to use another cable? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-07-2008, 16:14 | #26 (permalink) |
Member: 753732 Status: Offline Thanks Meter: 252 | [quote=Mr.Tinkertrain;3631887]@ powerplay83, More likely that the cable you have is faulty. Did you try to use another cable? Yes i havebuy 2 cables one is this: http://www.service4handys.de/index.p...G121/a_A001325 and this http://www.handy-style.de/index/cat163/2633 both cables are for the smart-clip and for j100i |
09-08-2008, 10:15 | #27 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ powerplay83, Check the pinout of the cable here and compare it with the one you have. The cable you have is defective. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-11-2008, 10:29 | #29 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ fonelab, Please tell us what code exactly the phone asks for. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Smart-Clip Team Need Your Help about V9 Unlocking with Smart-clip TP ........ | ZoHaiB_(FoneGSM) | Smart-Clip | 2 | 06-23-2008 15:59 |
smart-clip doesnt work | speedstarrr | Smart-Clip | 1 | 02-20-2008 08:26 |
panasonic g60 unlocked with smart-clip | chowdary | Smart-Clip | 18 | 05-27-2006 18:50 |
v975 canot unlock with smart clip | crysst | Smart-Clip | 5 | 07-29-2005 11:54 |
C925 cant get Unlock with Smart Clip?? | Amir-SkillZ | Smart-Clip | 1 | 05-03-2005 10:28 |
