05-06-2007, 04:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | Problems with testpoint on A1000 Smart-Clip instructions are often unclear so can anyone answere these question by experience, not by what smart-clip site says: 1) Will it work if button 1+2 is pressed before connecting battery? 2) Will LED on phone light up when done correctly, or should it be unlit at all times if done correctly? No matter what i do, LED will light up, and pressing button 1+2 makes no difference - nothing is detected. BUT, if i press 1+2 before connecting battery, LED does not light, and as soon as i release buttons, PC will detect "Flash Operating System Interface". If i press the buttons again, it will detect "Flash Interface". Where is the problem - usb-cable (pin 13-14 shorted), or testpoint connection problem? How can i know that the usb cable is correct? |
05-08-2007, 00:45 | #3 (permalink) |
Member: 105625 Status: Offline Thanks Meter: 44 | Nevermind.. I got it unlocked now. But of course, not using the method described at smart-clip.com. I had to do this: Connect testpoint Press and hold a+b Connect battery Release a+b Press and hold a+b again Click search |
The Following 4 Users Say Thank You to James_S For This Useful Post: |
05-08-2007, 09:59 | #5 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Here is tested and 100% working method.
Please ensure that all steps are performed correctly strictly following the manual. Do not make too long pauses between each step. Best Regards GSMServer team |
09-15-2007, 08:36 | #7 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Miftahudin, We recommend to use standard TP for unlock procedure. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-05-2008, 08:45 | #10 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ hrkgloballinks, Please explain what problem you have in more details. In case if the set can not be recognized by PC/SmartMoto, ensure that the cable work properly and the connector is clean. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
problem with testpoint cable V-spec | Matrix rev | J.A.F. V-SPEC | 2 | 03-28-2008 14:48 |
MTBox PRO problem with Testpoint | DonaldDuck69 | MT-BOX | 6 | 08-21-2007 08:00 |
Myc-4 problem with testpoint | neluturap | SAGEM JTAG UNLOCKER | 4 | 04-11-2006 12:47 |
Problems with testpoint! | phone_abuser | Sony Ericsson | 0 | 08-31-2004 00:24 |
T180 - dead - problem with testpoint | tozitom | Motorola Old Legacy (EMMI) | 0 | 04-08-2004 19:49 |
