Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 01-14-2010, 09:00   #1 (permalink)
Member: 920356
Thanks Meter: 3
fg 2010 edition box problem
Furious Team, Please Help
I bought brand new Furious Gold Box
I follow this instruction and install in freshly formatted/installed OS pc
Q: What OS (operating system) are your softwares compatible ?
A: Windows XP/2K/Vista.
Q: I just got my box and i would like to install drivers. What to do ?
A: There are two drivers to install on first use. First get FG_FTDIDRIVER.rar from support, extract in one folder and after connect box to usb cable. In this moment windows will request this driver and just point him the correct directory. After get from support FG_SMARTCARDDRIVER.zip, extract in one fodler, right click on ini file and choose install. End these operations by resetting pc.
Q: What is the next step after installing drivers ?
A: download latest maintainance tool
extraxt on new folder, run the maintenance exe tick format & execute selected operation to double size the dongle volume after finish tick generate licence then click on execute selected operation, after the licence has been generated click on go to support area, you'll be logged in automaticly to support area
go to download area >> setup, download the latest installer and make sure to download the latest beta modules, install furious installer and exract beta modules on furious installer folder make sure to put the generated key inside the installer folder.
Here comes the problem
run the maintenance software, it worked fg box detected
exit the sofware then run again
no card-reader(s) found, WHY?
removed fg box from cable
then reconnect box after several minutes, run software it work again
exit software then run again, no card-reader(s) found WHY?
Any solution for this?
Remember i install the software in a newly format pc, so probably no conflict in driver
I also use the latest maintenance software from support
Old 01-14-2010, 09:45   #2 (permalink)
FTEAM_MODERATOR's Avatar
Member: 1144248
Sonork: 100.1574721
Thanks Meter: 3,936
Hi Nataraki
Your Drivers are not Installed correctly , can you Please Post screen shot for your Divce Manager
Old 01-14-2010, 11:03   #3 (permalink)
Member: 920356
Thanks Meter: 3
kindly check the screen shot of my device manager at the link below
i can't upload it in other imagehosting
my internet connection here is tooooooo slow
http://www.mypicx.com/01142010/my_device_manager/
Old 01-14-2010, 12:29   #4 (permalink)
Member: 920356
Thanks Meter: 3
please please please...
really need to solve this problem
Old 01-14-2010, 12:42   #5 (permalink)
Member: 1006514
Thanks Meter: 640
box drivers are installed ok ! but check smartdcard drivers i think u didn't install it
Old 01-14-2010, 12:52   #6 (permalink)
Member: 920356
Thanks Meter: 3
thanks...
but why software is running at first
after software exits, then run again
no card-reader(s) found or PROTECTION ERROR!
Old 01-14-2010, 13:09   #7 (permalink)
Member: 1006514
Thanks Meter: 640
change the usb cable or plug it on another usb port ( don't use hub)
Old 01-14-2010, 13:21   #8 (permalink)
Member: 132881
Thanks Meter: 105
i had the same problem that it could not even read card.if you have the gut like me open your furious and check if the small dongle is sitting properly.just unplug and replug that dongle'it will definitely work.
Old 01-14-2010, 15:04   #9 (permalink)
Member: 1144248
Sonork: 100.1574721
Thanks Meter: 3,936
If Win7 then means you must open as admin and vista nearly sure the same
Old 01-14-2010, 16:59   #10 (permalink)
Member: 1006514
Thanks Meter: 640
i don't think he's runnig win7/vista if you see his screenshot , it's a winXP
Old 01-15-2010, 03:02   #11 (permalink)
Member: 920356
Thanks Meter: 3
@toptech
mine is 2010 edition
its a built in pcb according to my reseller
I'm using winXP
Old 01-15-2010, 06:16   #12 (permalink)
Member: 920356
Thanks Meter: 3
Anymore idea on how to solve this problem?
To Furious Team, Is this not a hardware problem?
Old 01-15-2010, 08:36   #13 (permalink)
Member: 1144248
Sonork: 100.1574721
Thanks Meter: 3,936
It can be that the dongle it's half unplugged. Contact your reseller if he allow you to open box and recheck dongle connection
Regards
Furious Support
Old 01-15-2010, 08:59   #14 (permalink)
Member: 920356
Thanks Meter: 3
Regards
Furious Support
mine is 2010 edition, no dongle 'coz its "dongle built-in pcb" according to my reseller
Old 01-15-2010, 09:44   #15 (permalink)
Member: 1144248
Sonork: 100.1574721
Thanks Meter: 3,936
Well it has dongle but it's inside the box. So tell him
Regards
Furious Support
@@@..Hot solution exe.by mobi_soft--2010 Edition...@@@ mobi_soft Nokia Hardware & Hardware Repair 27 04-04-2010 13:38
rap3gv3_2nd.fg RAP3Gv3_algo.fg - possible edit this loaders ? *Diablo* GSM Programming & Reverse Engineering 5 02-14-2010 23:18
Nokia Lcd Finder Version-3 [Christmas and New Year Gift]by Mehmood Riaz -2010 edition izhanji Nokia Hardware & Hardware Repair 0 12-24-2009 12:00
fg box problem mobilshopprimi FuriousGold 0 11-27-2008 16:38
Page generated in 0.66207 seconds with 9 queries
