10-31-2005, 01:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | NSDongle have problems detecting JAF-box First time i tried, i didn't get it detected. The day after it suddenly was detected, but today again, it's impossible to get it detected by NSdongle. I have tried disconnected all other USB-box devices, restarting computer, reconnecting the box 10x times, but still, NSdongle won't detect it. What can cause this? |
10-31-2005, 01:42 | #2 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
Also... PLZ make sure that you have ORIGINAL JAF box.... | |
10-31-2005, 02:46 | #3 (permalink) |
Member: 105625 Status: Offline Thanks Meter: 44 | Yes, the box is 100% original (from UnlockCellular). But it might be a faulty box, cause when i run the "JAF COM Emulator" application i get a box error. The main JAF application works fine though. Very weird... Edit: Just for your reference - a third party application called "UFS DirectCOM" which emulates Twister as a COM-port (works pretty good on NSDongle btw), finds the JAF box when searching for devices. So NSdongle should in any case be able to see the device. Connect to it and use it could be the problem though. |
10-31-2005, 12:51 | #4 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Inside my brain
Member: 97242 Status: Offline Thanks Meter: 14 | there are some problem with nsdongle and jaf-box ... today i've killed a v200, initially say "Incorrect parameters were submitted", after some tries (disconnecting cable and closing application) start to flash, when program says "power on mobile" nothing work, i had to detach cable from phone, and reconnect it, program starts but stops ad "loading flashloader", and after 1 minute "error, too many retry ... bla bla bla" Jaf is original, cable is working with UFS, phone completely working before. No problem with service job with same cable, ufs and nsdongle 3.8.1, just no way to flash, and phone killed |
10-31-2005, 15:02 | #5 (permalink) | |
Nsdongle v3.8.3 is available.Flashing dont work yet trugh JAF box.Will be added soon.For flash V200 use Serial cable or USB to serial cable. | |
10-31-2005, 22:39 | #6 (permalink) |
Member: 97242 Status: Offline Thanks Meter: 14 | now i'm using 3.83. i'ven't seen that was not possible to flash through JAF box. It's very good to do job with box without phone battery (like UFS-3). Phone is completely dead, not recognized from box (JAF or UFS-3) or Nsdongle with serial cable and 9v battery any ideas or tricks that could help? tnx |
10-31-2005, 22:53 | #7 (permalink) |
No Life Poster Join Date: Jun 2002 Location: UK/Espaņa Age: 54
Member: 12578 Status: Offline Thanks Meter: 60 | @Mirken, Please make sure battery is good in phone and try again, but last V200 we had which was dead was fixed using V200 flasher tool. Please check your PM inbox for link WBR yeldar |
I have problem With JAF BOX and UFS micro as interface | NawabN Sahoo | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 11-14-2009 13:22 |
