Old 11-16-2008, 21:18   #1 (permalink)
Member: 54500
***** G629 socket to Infinity box
***** G629 I would like to make it join on INFINITY BOX Pin Finder.
How let me do it?
I do not have a socket to it, only a factory usb cable.
Please help Infinity Support.
Old 11-17-2008, 10:20   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What is this phone connector type ?
Old 11-17-2008, 11:27   #3 (permalink)
Member: 54500
There is a socket that I cannot identify on him unfortunately.
Pinfinder is not socket like this.
May he not be on the panel?
Old 11-17-2008, 11:39   #4 (permalink)
Member: 130995
Hello,
Do you see any kind of connector at bottom side of phone ?
Old 11-17-2008, 12:06   #5 (permalink)
Member: 54500
"Press and HOLD Power button now !
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:3803:0004
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01"
NO reading FULL FLASH!
What is it necessary to put in another place?
Old 11-17-2008, 12:35   #6 (permalink)
Member: 54500
READ GENERAL INFORMATION :
Action: read information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6225, E03
Hardware version: M1234525_GEMINI_HW
Software version: MAUI.GEMINI.W08.12"
Software date: 2006.06.14
Barcode: GC629G_S09178033E 10
imei: 354752010000792
imei: 135790246811220
Finished, time used: 7 sec
Power off phone now !
Old 11-17-2008, 16:13   #7 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
Did you tried with lower baud speed???
Old 11-17-2008, 16:28   #8 (permalink)
Member: 130995
@GSMagic
As I can see you have found the pinout and you can connect phone with software.
What is the problem now ?
I do not see any errors in log, I see only truncated log text.
Please, make detailed problem description so we will be able to understand how to help you.
Old 11-17-2008, 16:53   #9 (permalink)
Member: 54500
==== log: [2008.11.17. 16:48:01] ====
COM5 selected
module v2.69
Device: Autodetect 6205-6227 NOR
Action: read NOR flash
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN
ver. sw 2: MAUI.GEMINI.W08.12, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00710000
Detected eeprom/ffs address is non-standard: 00710000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address confirmed by user: 00710000
detecting eeprom/ffs size...
eeprom/ffs size: 008F0000
ffs chip: 00
eeprom/ffs area: 00000000:00710000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]...
warning: wrong data size at 0x00001C00, retry...
read error recovered
warning: wrong data size at 0x00007400, retry...
warning: wrong data size at 0x0000C800, retry...
file saved: D:\Program Files\InfinityBox\ChineseMiracle\flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]_20081117-164854.B0M.bin
Finished, time used: 36 sec
Remove/Install battery now
Old 11-17-2008, 16:55   #10 (permalink)
Member: 54500
The Mobile : ***** G629 (chinese clone)
No read full flash!
Whether why?
Old 11-17-2008, 18:45   #11 (permalink)
Member: 130995
Hello,
Please, explain what is the problem !
As I can see from log backup was done and file was saved: D:\Program Files\InfinityBox\ChineseMiracle\flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]_20081117-164854.B0M.bin
So, what is the problem, we need to know more information !
Also, what cable you have used ?
Old 11-17-2008, 18:46   #12 (permalink)
Member: 130995
Hello,
Old 11-17-2008, 22:14   #13 (permalink)
Member: 54500
read error recovered !!!!!!!!!!!!!!!!
He cannot read the content.
0 bytes are the rescued data.
The cable is perfect.
The log a file implies the mistake.
Somebody else has a problem like this on the internet.
But we the trouble? The Infinity-box Chinese Miracle.exe does not know this telephone???
Old 11-17-2008, 22:57   #14 (permalink)
Member: 130995
Man... I become little bit angry because you have ignored my questions.
Infinity-Box is The best software for this kind of phones, if phone can be booted (in your case it was) this means that Infinity-Box know this model and can repair it !
If you unable to use software well you must read documentation and ask advices from experienced users and programmers !
My question again: What cable you have used ?
I ask you about this because many Chinese zero-quality factories produce now zero-quality cables based on Prolific chip, and many greedy people buy this kind of cheap crap, as a result in many cases this kind of cables can not be used well with high-quality software and as a result many "zero quality cable lovers" start to talk about bugs in our software, but in fact all problems is a result of "saved money" and low-quality cables !
Do you understand now why you must make an answer or easy question ?
Old 11-17-2008, 23:14   #15 (permalink)
Member: 54500
Your answer was big strong one.
I did nearly 150 pieces of telephone Infinity box.
Infinity Plus,Pinfinder adaptor, RJ45 cable and the cable soldering the telephone is for inside.
I write a Hungarian and Slovak language into it,with full translation.
Maximally in detail.
I did all of the telephones until now with these cables.
All the best quality cable,that the you I bought from resellers.
For example GSMSERVER.COM.
I am sorry for it if you look at this much for unfortunate one.
Indulgence, that I asked altogether.
Infinity-Box Serial Number (S/N) is your key to Infinity-Box support... .:Mahmoud El-masy:. Infinity-Box 29 10-28-2012 10:42
to infinity box, new flash file not in support area, i uploaded it to mediafire KhalIman Infinity-Box 1 03-13-2010 21:16
to infinity-box team hevernage Infinity-Box 1 06-20-2005 21:38
UPDATE: 05 MAY 2005. Nec-E101 Support added to Infinity Box Infinity-Box Infinity-Box 9 05-05-2005 21:54
NEC E101 Direct Unlock Solution added to Infinity Box Infinity-Box NEC 9 05-05-2005 19:23
Page generated in 0.28590 seconds with 9 queries
