11-17-2008, 23:43 | #17 (permalink) |
Junior Member Join Date: Feb 2004 Location: Hungary Age: 48
Member: 54500 Status: Offline Thanks Meter: 1 | What cable you have used ???????? Rj 45 cable,what I received INFINITY SLIM PLUS and PIN FINDER. There is not electronics in the cable. But I answered this already. The driver the box is attached. Possibly recount beside each other? |
11-17-2008, 23:47 | #18 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I can not see from log that cable you have used, so it was a reason of my question. If you still have problems with flash reading I suggest you to make so short wires as possible, double check that cable has good contacts and that battery is enough charged. Also double check that PinFinder has enough power from box: check voltage at unibox pin-1, it should be +5v, in other case see PinFinder manual page 20. In some cases you can improve connection if you solder 2 resistors (22k each): one from +V to Rx and other from +V to Tx. |
11-18-2008, 00:09 | #19 (permalink) |
Member: 54500 Status: Offline Thanks Meter: 1 | All right. He managed to understand each other. Thank you. I bribed it the language editor. Made to very many types Hungarian and translation with a Slovak language. It would be helped in the translations with pleasure to infinity Support. |
11-18-2008, 14:20 | #21 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you have some time, try to solder wire Rx/Tx/Gnd directly to phone from box (without PinFinder). I am not sure that this may helps, but let's try if you can do it. |
11-18-2008, 23:53 | #23 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, There is no problems with PinFinder but in some cases it may be problem with not good phone quality. Your situation is the only one that I know with this kind of results and I think it's because of bad luck but not because of PinFinder problems. |
Infinity-Box Serial Number (S/N) is your key to Infinity-Box support... | .:Mahmoud El-masy:. | Infinity-Box | 29 | 10-28-2012 10:42 |
to infinity box, new flash file not in support area, i uploaded it to mediafire | KhalIman | Infinity-Box | 1 | 03-13-2010 21:16 |
to infinity-box team | hevernage | Infinity-Box | 1 | 06-20-2005 21:38 |
UPDATE: 05 MAY 2005. Nec-E101 Support added to Infinity Box | Infinity-Box | Infinity-Box | 9 | 05-05-2005 21:54 |
NEC E101 Direct Unlock Solution added to Infinity Box | Infinity-Box | NEC | 9 | 05-05-2005 19:23 |
