05-02-2020, 19:27 | #64 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,933 | Quote:
05-02-2020, 21:59 | #70 (permalink) |
No Life Poster Join Date: May 2013 Location: Earth
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | All my setup and exe opens except this spd2 new version I uninstalled and installed previous one still not opening The exe works fine before I update card and open My dongle keeps on blinking light as if it wanted to open at the End light goes off |
05-02-2020, 22:25 | #71 (permalink) |
Insane Poster Join Date: Feb 2020 Location: ................
Member: 2948043 Status: Offline Thanks Meter: 3 | hi ... now; i know exactly my problem. firstly, cm2spd 2.05 / cm2scr 1.06 does not open because the protection is active . just need uninstall it (spd/scr) + delete folder + then restart system, after that install it again .... and before run it you need add to exclusions.. only. 2nd pc, new system + without antivirus, but the problem in the ( deep freeze).. cm2spd 2.05 / cm2scr 1.06 will not open with it. thank you infinity team. |
The Following User Says Thank You to khalillll For This Useful Post: |
05-02-2020, 23:15 | #75 (permalink) |
Member: 2948043 Status: Offline Thanks Meter: 3 | Confirmed . If the system is protected by deep freeze cm2spd 2.05 / scr 1.06 will not open. The error file (fault.bin = 35 octets) is created . good luck. |
