Old 12-14-2008, 13:11   #1 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
***** ke850 unlocked
COM6 [VCP0] selected
module v1.58
Device: LG-KE850
Checking data, wait...
Action: unlock
read unlock codes
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0089:887E
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static_20081215-170835.B1E.bin
reading eeprom-static2...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static2_20081215-170835.B1E.bin
loading data...
data loaded
imei: 35030526000000100
reading eeprom-security_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-security_35030526000000100_20081215-170837.B1E.bin
reading eeprom-complete_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-complete_35030526000000100_20081215-170840.B1E.bin
backup critical area Done
Check memory ...
loading data...
data loaded
code: 18257914
Finished, time used: 21 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to NADEEM GONDAL For This Useful Post:
Old 12-14-2008, 13:21   #2 (permalink)
kasrawiz's Avatar
Member: 340564
Sonork: 1591034
Thanks Meter: 529
good share thanks for shareing your successful unlocking logs thanks again
Old 12-14-2008, 13:25   #3 (permalink)
SOHAIL BASHARAT's Avatar
Member: 748880
Thanks Meter: 1,705
THANKS BR GOOD INFINTY TEST REPORT
THANKS INFINTY TEAM
SOHAILKH::::d
Old 12-14-2008, 13:28   #4 (permalink)
.Wise Solution's Avatar
Member: 872776
Thanks Meter: 23
good report .
Old 12-14-2008, 13:37   #5 (permalink)
Miftahudin's Avatar
Member: 115242
Sonork: 100.1581364
Thanks Meter: 1,638
very good shairing keep it ..............
Old 12-14-2008, 13:49   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
@NADEEM GONDAL
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Old 12-14-2008, 13:53   #7 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: +92 346 5544377 (PHONE)
Thanks Meter: 2,522
it's been great !!!!!!! aah !
Lg ke850 ***** sucessfully unlocked by infinity-box:)- sahil2000ind Infinity-Box 8 10-21-2009 22:39
Problem Unlock Lg ***** Ke850... BABAK NURI MT-BOX 0 12-01-2007 11:55
problem of unlocking LG ***** KE850?? Jamal LG 2 11-21-2007 23:57
a problm with LG ***** KE850 unlocking Jamal FuriousGold 2 10-10-2007 15:40
can i unlock lg ***** ke850 speedstarrr HWK 4 09-01-2007 17:57
Page generated in 0.20712 seconds with 9 queries
