07-11-2008, 18:45 | #16 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | Regards,Vygis |
07-14-2008, 18:26 | #17 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Brazil
Member: 232960 Status: Offline Thanks Meter: 419 | Quote:
Full flash back-up sent to support. Waiting reply. thx | |
08-12-2008, 22:02 | #19 (permalink) |
Member: 232960 Status: Offline Thanks Meter: 419 | dead after flash by infinity log COM4 [VCP1] selected Device: Gradiente-GF760 "advanced chip detection" active Action: flash write "smart write" active "safe mode" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 01227E223C2200:8AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb Check hardware done Read data... Read data done Check data... Check data done Writing... Area: Firmware "safe mode" active flash: 01227E223C2200:8AEA0000000000 Write: Firmware "safe mode" is not active flash: 01227E223C2200:FFFFFF00000000 Write: Firmware Area: Eeprom "safe mode" is not active flash: 01227E223C2200:46237300000000 Write: Eeprom Writing done Finished, time used: 267 sec Remove/Install battery now ! |
08-12-2008, 22:08 | #20 (permalink) |
Member: 232960 Status: Offline Thanks Meter: 419 | here some logs in unlock function...phones ok phone 1-error in final process COM4 [VCP1] selected Device: Gradiente-GF760 Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 01227E223C2200:8AEA0000000000 flash: Amd PL256N D 16Mb Check hardware done Read data... reading Gradiente-GF760_eeprom_calibration-1... file saved: C:\Arquivos de programas\InfinityBox\HModule\backup_Gradiente-GF760_eeprom_calibration-1_20080812-170702.92E.bin reading Gradiente-GF760_eeprom_calibration-2... file saved: C:\Arquivos de programas\InfinityBox\HModule\backup_Gradiente-GF760_eeprom_calibration-2_20080812-171119.92E.bin Read data done Check data... file saved: C:\Arquivos de programas\InfinityBox\HModule\backup_eeprom_200808 12-171536.92E.bin please, wait... error: not locked or unknown eeprom Check data fail Finished, time used: 537 sec Remove/Install battery now ! phone 2 - all process ok but phone still locked COM4 [VCP1] selected Device: Gradiente-GF760 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 01227E223C2200:8AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb Check hardware done Read data... reading Gradiente-GF760_eeprom_calibration-1... file saved: C:\Arquivos de programas\InfinityBox\HModule\backup_Gradiente-GF760_eeprom_calibration-1_20080812-173103.92E.bin reading Gradiente-GF760_eeprom_calibration-2... file saved: C:\Arquivos de programas\InfinityBox\HModule\backup_Gradiente-GF760_eeprom_calibration-2_20080812-174251.92E.bin Read data done Check data... file saved: C:\Arquivos de programas\InfinityBox\HModule\backup_eeprom_200808 12-174701.92E.bin please, wait... pass-1... pass-2... Check data done Writing... flash: 01227E223C2200:46237300000000 Write: eeprom Writing done Finished, time used: 1090 sec Remove/Install battery now ! |
08-13-2008, 09:43 | #21 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | What do you mean "dead after flash" ? What was with phone before flashing ? What was the reason to flash it ? Did you tried to flash phone again ? phone-1 and phone-2: what you see at phone LCD when you insert sim card ? |
08-13-2008, 15:01 | #22 (permalink) | |
-I mean v-spec or infinity cant unlock this phone, then i try to flash it by infinity= phone dead -phone ok just for unlock. -to try change version to unlock -yes -insert code(8 digits) | |
08-13-2008, 18:51 | #23 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Do you have original flash backup ? If yes, send it to [email protected] |
08-13-2008, 19:46 | #24 (permalink) | |
Full flash back-up sent to support. 14/07/2008 Waiting news. thx | |
Gradiente GF760 No Connect | panafax_gsm | VygisToolbox | 7 | 11-20-2007 17:26 |
A Lot Of People Big Problem With Uid | Fonetec | UID - Box | 53 | 10-09-2007 18:34 |
AGAIN NEW UPDATE - support for new VERSIONS Gradiente GF760 | Gobi | VygisToolbox | 5 | 04-27-2007 19:22 |
05 Dec 2006: Gradiente GF760 model supported | InfinitySupport | Infinity-Box | 10 | 12-06-2006 01:55 |
