07-27-2020, 09:27 | #136 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Update dongle with DongleManager now | |
07-27-2020, 09:28 | #137 (permalink) | |
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 File with Drivers: CardReader_Fetian_FT2K.7z File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Run DongleManager 3. Update Dongle firmware OR 1. Insert Smart-Card into another Card-Reader. Good result for today gives Alcor Card-Reader. 2. Run DongleManager - https://www.infinity-box.com/support/?r=5 3. Update Dongle firmware Only ONE update try is allowed ! In case of problem DO NOT update card again ! | |
07-27-2020, 11:03 | #138 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | === DongleManager [Infinity] v1.80 [7/27/2020 14:30:40] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0101986C14D11292 === Process started: 7/27/2020 14:30:40 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
07-27-2020, 16:38 | #139 (permalink) | |
07-28-2020, 09:45 | #140 (permalink) |
Junior Member Join Date: Feb 2008 Location: Philippines
Member: 700608 Status: Offline Thanks Meter: 3 | Please help me === DongleManager [Infinity] v1.80 [7/28/2020 16:42:24] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00001FFD7CEC4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): CAB91FFD Firmware version: 0137.02 === Process started: 7/28/2020 16:42:25 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
07-28-2020, 11:57 | #141 (permalink) | |
Please fix your PC according to instruction for error #57 - https://www.infinity-box.com/support/?r=4 After that update dongle firmware with DongleManager. | |
07-28-2020, 22:32 | #142 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi CM2MT2 2.14 ask for update FW via dongle manager but DM say FW is up to date what should i do??? Quote:
07-28-2020, 23:41 | #143 (permalink) | |
Probably your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support for 1 or 2 years - https://www.infinity-box.com/buy/ | |
07-29-2020, 05:27 | #144 (permalink) | |
Member: 700608 Status: Offline Thanks Meter: 3 | Quote:
https://mega.nz/file/MhlDyIzC#RfvAcZ...Bc4iGiOYFs7mT4 edit: after updating my cm2 is now working again .. many thanks!!! Last edited by jmserrano1210; 07-29-2020 at 05:33. | |
07-30-2020, 01:04 | #145 (permalink) |
Junior Member Join Date: Jun 2018
Member: 2842120 Status: Offline Thanks Meter: 0 | Card-Reader: Generic EMV Smartcard Reader 0 ATR: 3BFD1300008131FE45543D314A323133364B56323331DC Card Manager: SerialNumber: 01258899 ROM: Integrated Circuit Fabricator: 4790 Integrated Circuit Type: 5035 OS: Identifier: 4791 Release Date: 0078 Release Level: 3300 EEPROM: Fabrication Date: 8259 Serial Number: 01258899 Batch Identifier: 1261 Module Fabricator: 4812 Module Packaging Date: 8266 IC Card Manufacturer: 0000 IC Em******* Date: 0000 Pre Personalizer: 0444 Pre Personalization Date: 1D31 Pre Personalization Equipment Identifier: 32353838 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard . : 0125889912614812 GP Version: 2.1.1 SCP Version: 2, Option: 21 === DongleManager [Infinity] v1.80 [7/30/2020 1:02:36] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0125889912614812 Box / Dongle is not found === DongleManager [Infinity] v1.80 [7/30/2020 1:05:30] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0125889912614812 === Process started: 7/30/2020 1:05:30 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to infinity-box . com / support /?r=2 |
07-30-2020, 09:14 | #146 (permalink) | |
This Smart-Card is not an Infinity Smart-Card 1. Disconnect all other Boxes and Dongles from PC 2. Connect ONLY one Infinity Box/Dongle to PC | |
07-30-2020, 16:44 | #150 (permalink) | |
so you had wrong card connected to PC earlier. solution for "The smart card is not responding to a reset" is: Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader If problem still exist this means it's a hardware problem and you should buy new Dongle. | |
